Dashticz - Module - Garbage collector Topic is solved
Re: Dashticz - Module - Garbage collector
Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
From 2019.01.01 mijnafvalwijzer doesn't work anymore ;( maybe someone knows which service works for Ede- i tried few but nothing works.
- HansieNL
@Ynco : can you check mijnafvalwijzer again? Yesterday it didn't show info here, but now it does.
Blah blah blah
No, still the same "geen gegevens gevonden". I got on my phone message that from 2019 mijn avfal wijzer stops working. i had to download new app- ACV.
- cyberclwn
I emailed with mijnafvalwijzer.nl about the garbage information of the ACV.
They said the ACV isn't working together with mijnafvalwijzer.nl anymore. So no information of ACV on mijnafvalwijzer.nl anymore.
but ACV has it own website/url:
http://www.acv-afvalkalender.nl/ which calls:
https://afvalportaal.2go-mobile.com/modules/f8e2844a-095e-48f9-9f98-71fceb51d2c3/kalender/calendar.html?294321&<street>---<number>%20%20%20---<postalcode>---EDE%20GLD---EDE
Maybe it helps you guys
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
- Domoticz version: 3
And knows if i can get it to work with the Gemeente Leiden?
Domoticz v3 - Beta Channel @ Pi3 | Harmoney Hub | MiLight Ibox2 | Google Home (1) | Google Home Mini (3)
Do you know whether Leiden provides a link to download the garbage calendar data?evildonkey wrote: ↑Sunday 20 January 2019 14:54 And knows if i can get it to work with the Gemeente Leiden?
could not find it on the website, i will send them a email.
If i put my postcode in there i can see when.Lokonli wrote: ↑Monday 21 January 2019 19:17Do you know whether Leiden provides a link to download the garbage calendar data?evildonkey wrote: ↑Sunday 20 January 2019 14:54 And knows if i can get it to work with the Gemeente Leiden?
https://gemeente.leiden.nl/inwoners-en- ... ema-afval/
You can use ical for Hilversum eo:dvwerkhoven wrote: ↑Thursday 20 December 2018 22:58 Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
- go to https://inzamelkalender.gad.nl/
- enter zipcode and housenr
- click 'naar maand- en jaarkalender'
- copy the url and configure in dashticz
- Domoticz version: 2024.3
When using garbage, my dashticz keeps saying that i need a php enabled webserver..?
I'm trying to use mijnafvalwijzer, but whatever i do, it doesnt work at all
What did i doing wrong?
Raspberry / ESP Boards / Relais / Milight / Hue / OTGW / P1 / Xiaomi / RFXCom / RFLink / ZWave / Conbee II / Z2M / MQTT / A lot of scripts and many more..
Software: Linux, Android and Windows
- HansieNL
@BarryT : Since version 2.4.6 for some functions a webserver with php is needed. It's described in the wiki.
Blah blah blah
I have nginx with php7.2 and the php-mod-curl installed..?
- HansieNL
@BarryT : have you checked if your PHP is running fine. Can you check with http://<nginx-ip>:<nginx-port>/index.php
Blah blah blah
My php info is correct and the dashticz also works correct.. its just the garbage wich gives an error
Do any one know the code for ACV afvalwijzer?
I'm going to test on another server these days, maybe the curl didnt do its job correctly...
I'll let you know asap
Okay, thnx for the tip!
Could someone give me a walk through to configure my gmail calendar (Ical) with this nice add on?
Until now i've got:
config['garbage_icalurl'] = 'https://calendar.google.com/calendar/ic ... /basic.ics';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
//gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
//pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
//Restabfallbehaelter: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
//papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
//kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
//brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
//black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
Restabfallbehaelter: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
//kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Unfortunately my Dashticz does show up, but the garbage add on shows loading and doesn't continue....
thanks in advance
Until now i've got:
thanks in advance
Und Tschjuß
