Hi.
I need to switch on the light by movement at the specified period of time. I have created the event:
but it doesn't work at all, if I will delete one "and", all is working fine.
Please advice.
Double "and" with "if" doesn't work
- waaren
Re: Double "and" with "if" doesn't work
Time > 08:00 and Time < 01:00 are mutual exclusiveDoMoney wrote: Thursday 17 January 2019 23:25 Hi.
Please advice.
- emme
- Domoticz version: latest
I'm not clear about the time frame in which you want le light on...
Expect it would be from 8:00am to 1:00am (so it is 8:00 ==> 24:00 and 00:00 ==> 1:00)
I would try to revert the condition:
if Burglar = on AND (Time > 8:00 OR Time < 1:00)
"We always done this way"
welby
Yep change the and between the times to OR. The time resets at midnight.
mrf68
If you only change then “and”, the alarm will go off any time after 8 am. You need to swap the Burglar=On block with Time>08:00 and then change the “and” to “or” between both time statements.welby wrote: Friday 18 January 2019 9:37 Yep change the and between the times to OR. The time resets at midnight.
welby
Really because i have this one working ok.mrf68 wrote: Sunday 20 January 2019 12:57If you only change then “and”, the alarm will go off any time after 8 am. You need to swap the Burglar=On block with Time>08:00 and then change the “and” to “or” between both time statements.welby wrote: Friday 18 January 2019 9:37 Yep change the and between the times to OR. The time resets at midnight.
- Screenshot (2).png (11.11 KiB) Viewed 833 times
mrf68
Really, it’s exact the same. You changed more than just the and to or, you rearranged some things that made it work.
