I Tryed to update but i still got same error as EdddieNjin wrote: Sunday 08 April 2018 16:36Hi,glsf91 wrote: Thursday 15 March 2018 20:21 I get:
ERROR: wrong PLAYBACK engine specified: 'castnow'
please select an engine from the following list:
Engine Version Name HomePage
mplayer 2016-12-18 MPlayer http://www.mplayerhq.hu/
castnow is working when using command: castnow coldplay.mp3
What is going wrong?
just updated izsynth to 4.9 release
Update with:
cd /usr/local/bin && wget https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth -O izsynth && chmod 755 izsynthLet's me know if it works as expected
- Implemented generic playback engine support. You can use -k to specify your playback command, and -K for the command options
Kind Regards
izSynth: make domoticz talk with many TTS engines in a easy way
- DewGew
- Domoticz version: V4.10618
Re: izSynth: make domoticz talk with many TTS engines in a easy way
- DewGew
Seems like Natrualreader engine does not work. I change to google and now it works agian.EdddieN wrote: Wednesday 11 April 2018 16:43 Hello,
Any idea why is returning an error?The folder has full permissions, etc..sudo izsynth "Door opens"
== [1/1] - izsynth Name:[Door_opens] ===========================================
Synthesizing - input:[/dev/shm/izsynth-20180411-153426/Door_opens.txt] engine:[naturalreaders] voice:[Peter] output:[/dev/shm/Door_opens.mp3] size:[4.0K] type:[text/plain] result:[ERROR]
I tried with sudo and it generates de mp3 file but still results on ERROR
- EdddieN
- Domoticz version: 4.9700
I’ll have to try, definitely easier TTS than pre recording mp3 files
11101101 - www.machinon.com
Vomera
No Naturalreaders doesnt work anymore. I think they changed the subscription plan
JuanUil
- Domoticz version: 4.11083
Naturalreaders not working with me as well
- DewGew
Natrualreaders is suppost to work now. Has anyone tested this?
Vomera
Hi, i test it again and updates to the latest version but it doesnt work:
Is it because of the subscription plan
pi@Domoticz:~/domoticz$ ./izsynth -e naturalreaders -t "Hallo hier ben ik weer"
== [1/1] - izsynth Name:[Hallo_hier_ben_ik_weer-552258153] =====================
Synthesizing - input:[/home/pi/domoticz/shm/izsynth-20190516-094155/Hallo_hier_ben_ik_weer-552258153.txt] engine:[naturalreaders] voice:[nl-nl] output:[/home/pi/domoticz/shm/Hallo_hier_ben_ik_weer-552258153.mp3] size:[4.0K] type:[text/plain] result:[ERROR]-
retikagore
Thank for the information it was very useful.
Vomera
I found an alternative, maybe someone can script something to use it ?
https://notevibes.com/
200 free characters for personal use
- Bospieper
- Domoticz version: 2022.1
Can someone help me with the error I've get when performing the the following command:
izsynth Hello World, this is a testmessage
It looks like izsynth cannot find the .mp3 file.
- izsynth.JPG (67.28 KiB) Viewed 1489 times
- Bospieper
After some trial and error I have it partualy working that is I have no errors anymore when performing izsynth commands.
The solution was to use Voicerss instead of naturalspeak.
Now I have to solve the sound problem.
I am using bluetooth BT-Speaker. It is reconigzed bij izsynth as a sounddevice. I have adjusted the izsynth config file with: alsa:device=bt_speaker
When use the command: izsynth -e voicerss -v nl-nl -t "het is $(date +%H:%M)" I hear no sound
I have a valid APIKEY for Voicerss and it is in the izsynth config file.
jin
Hi, using integrated sound card instead BT device works?
- Bospieper
That I have not tested yet, because the Pi is suited in the fuse box not nearby the room were I want to use the speaking utility
When it is importent that it should be tested for further problem solving I will try it.
Piet
Piet
