izSynth: make domoticz talk with many TTS engines in a easy way
All kinds of 'OS' scripts
jin
Post by jin »
I'm writing this post just for inform I published a new software to make domoticz talk using various TTS (Text-to-Speech) engines in an easy way:
http://www.domoticz.com/wiki/IzSynth
Two commands quick and dirty install and test guide: :) (taken from domoticz wiki)
cd /home/pi/domoticz/scripts
wget https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth && chmod 755 izsynth
./izsynth -e naturalreaders -v Peter -t "Welcome home, mr Stark" -w
If you like it and want enhance izsynth, fork it and make patches using the official github repository:
https://github.com/ugoviti/izsynth
Kind regards
Derik
Re: izSynth: make domoticz talk with many TTS engines in a easy way
Post by Derik »
mmm looks very simple...
Are there different languages?
And is there perhaps a youtube movie to see the options?
What hardware do i need?
Is there option to use more mics in different rooms?
woody4165
Post by woody4165 »
Very nice!!!
Thanks for sharing.
Which TTS does support now?
jin
Post by jin »
woody4165 wrote:Very nice!!!
Thanks for sharing.
[jin@jlt ~]$ izsynth -L
Engine            Version     Type    Provider          APIKEY  Technology  HomePage
espeak            2015-12-19  Local   eSpeak            NO      OpenSource  http://espeak.sourceforge.net
festival          2015-12-19  Local   Festival          NO      OpenSource  http://www.cstr.ed.ac.uk/projects/festival
fromtexttospeech  2015-12-19  Remote  FromtextToSpeech  NO      IVONA       http://www.fromtexttospeech.com
naturalreaders    2015-12-19  Remote  NaturalReader     YES     Custom      http://www.naturalreaders.com
sapi5             2015-12-19  Local   SAPI5             NO      Microsoft   http://www.microsoft.com/en-us/download/details.aspx?id=10121
voicerss          2016-04-18  Remote  VoiceRSS          YES     Custom      http://www.voicerss.org
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
That works great ! thank you !
1/ Check your wiki. You have some error in the command line of the "Install OS Dependencies" part.
2/ it's a shame that you can't change the volume for a text already synthetised. Isn't it possible to adjust the volume only in the playback ?
3/ I am on raspberryPi. I have failed to install wine. Did you succeed ? can you direct me to an howto ? (I think, windows sapi is the best autonomous TTS)
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
jin
Post by jin »
jmleglise wrote:Hi,
1) Thank you, fixed the domoticz wiki page:
sudo apt-get update
sudo apt-get install -y sox lame mplayer curl espeak wget
2) you can change the hardware soundcard output volume using the -W switch
example:
script://izsynth -W 90 -t "Can you hear me now?"
If you found the correct audio volume, I suggest to modify the config file, so you don't need to specify the -W switch every time:
PLAYBACK_VOLUME="90"
3) I used wine with SAPI5 only on x86 platforms, never tested Wine on ARM.... on RPi I suggest to use an online service (it's slow, depending of service engine and connection speed, only on first synth... the next playback is realtime because izsynth reuse the already synthesized audio file)
With kind regards
jmleglise
Post by jmleglise »
Another feedback : I would appreciate in a future version an option to don't keep the audio file after the playback. Indeed, some sentences will never come again. (like reading news).
(for saving some disk space)
KMTronic USB relay
jin
Post by jin »
jmleglise wrote:Hi,
jin@jlt:~$ izsynth -h | grep keep
  -w                         Overwrite the synthesized file, otherwise keep it (current: no)
otherwise you can change the default behavior via izsynth.conf file:
set:
PLAYBACK_RESYNTH="yes"
Read the domoticz wiki page to discover:
With kind regards
pvm
Domoticz version: 4.10538
Post by pvm »
Is it possible to add https://www.ivona.com/ ? A very nice (even better than google) TTS with support for many languages and also free to use
blackdog65
Post by blackdog65 »
Hi Jin,
Great idea!
I've installed this and when tested with voicerss it works but not when trying to fire a script from a button.
Any Ideas
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jin
Post by jin »
pvm wrote:Is it possible to add https://www.ivona.com/ ? A very nice (even better than google) TTS with support for many languages and also free to use
use the fromtexttospeech engine for IVONA voices...
example:
izsynth -e fromtexttospeech -v Brian22 -t "Can you hear my bright voice now?" -w
with kind regards
jin
Post by jin »
blackdog65 wrote:Hi Jin,
Great idea!
Any Ideas
Sean
Have you read carefully the wiki page? what syntax do you use in your buttons?
toreandre
Post by toreandre »
I cant get this to work.
Every engine i try i get error.
osmc@osmcsoverom:~$ $HOME/domoticz/scripts/izsynth -e voicerss -v en-us -t "I love Domoticz Home Automation System"
== [1/1] - izsynth Name:[I_love_Domoticz_Home_Automation_System] ===============
/home/osmc/domoticz/scripts/izsynth: line 99: column: command not found
ERROR: the TTS Engine 'voicerss' doesn't exist, or is not supported by the izsynth
osmc@osmcsoverom:~$ $HOME/domoticz/scripts/izsynth -e voicers -v en-us -t "I love Domoticz Home Automation System"
ERROR: the TTS Engine 'voicers' doesn't exist, or is not supported by the izsynth
osmc@osmcsoverom:~$ $HOME/domoticz/scripts/izsynth -e sapi5 -v en-us -t "I love Domoticz Home Automation System"
ERROR: the TTS Engine 'sapi5' doesn't exist, or is not supported by the izsynth
osmc@osmcsoverom:~$ $HOME/domoticz/scripts/izsynth -e espeak -v en-us -t "I love Domoticz Home Automation System"
ERROR: the TTS Engine 'espeak' doesn't exist, or is not supported by the izsynth
blackdog65
got it,
I needed the extra / and the full path i.e.
script:///home/USER/domoticz/scripts/izsynth -t "say something clever"
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jin
Post by jin »
toreandre wrote:I cant get this to work.
mmmm... interessting:
pi@raspberrypi ~ $ dpkg -S /usr/bin/column
bsdmainutils: /usr/bin/column
what distro are you running?
If it's debian based, can you execute this command?
sudo apt-get install bsdmainutils
Let's me know.. mean while I'll update the wiki with this package (I use the column command a lot).
Kind regards
jin
Post by jin »
blackdog65 wrote:got it,
this is strange... what version of domoticz are you using?
since 3.x release, we can use the relative path, like
script://izsynth
domoticz will search the command inside DOMOTICZ_HOME/scripts
any way the full path can be a solution (I don't like because the command become very long)
Thank you for sharing
toreandre
Post by toreandre »
Kind regards
Sorry, i forgot to mention my setup. Im using RPi2, domoticz 3.5051 and OSMC (debian jessie).
I keep forgetting that OSMC is a "light" version of debian so many standard packages is missing, the apt-get command solved the problem.
Thank you for your fast reply :)
toreandre
Post by toreandre »
So i stumbled on another error, any idea of what this could be? i dont have a texteditor that shows the line numbers so its difficult to locate the command that gives the error.
osmc@osmcsoverom:~$ $HOME/domoticz/scripts/izsynth -e voicerss -v nb-no -t "I love Domoticz Home Automation System"
/home/osmc/domoticz/scripts/izsynth: line 491: file: command not found
/home/osmc/domoticz/scripts/izsynth: line 487: file: command not found
Synthetizing - input:[/dev/shm/izsynth-20160428-204101/I_love_Domoticz_Home_Automation_System.txt] engine:[voicerss] voice:[nb-no] output:[/dev/shm/izsynth-20160428-204101/I_love_Domoticz_Home_Automation_System.mp3] size:[28K] type:[] result:[ERROR]
blackdog65
jin wrote:this is strange... what version of domoticz are you using?
My installation often has minor quirks that a put down to being on a cubietruck, however, I'm currently using v3.5065 which seems to have a mind of its own i.e. it will not allow itself to be upgraded viewtopic.php?f=6&t=11737 :shock: :?
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jin
Post by jin »
toreandre wrote:So i stumbled on another error, any idea of what this could be? i dont have a texteditor that shows the line numbers so its difficult to locate the command that gives the error.
mmmm... interesting :)
pi@raspberrypi ~ $ which file
/usr/bin/file
pi@raspberrypi ~ $ dpkg -S /usr/bin/file
file: /usr/bin/file
can you run:
sudo apt-get install file
izsynth is a bash script and it use many system commands to do the job, so these commands must be installed :)
just updated wiki, thanks!
let's me know is something is still missing.
kind regards
