Some ideas for this?corederoma82 wrote: Wednesday 16 January 2019 9:56Nothing....the only information that log give me is this:zak45 wrote: Sunday 06 January 2019 1:11Discovery scan the network and display information into the Domoticz log.corederoma82 wrote: Sunday 06 January 2019 0:20 I select device "discovery" and Domoticz says me that I will found it in device tab..... But there is nothing in device tab and in switches tab....
Python Plugin : Broadlink RM2 V4
corederoma82
Re: Python Plugin : Broadlink RM2 V4
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
welby
Mine actually works with IR devices i've just worked out but not RF which is what i wanted it for. So i've been playing around a bit and managed to import an already learned RF device. As per the wiki grab these three files jsonSubIr jsonButton jsonIrCode from /broadlink/newremote/SharedData/ on your phone. Put the files into the import directory of the Broadlink plugin then hit the generate button in the Broadlink import selector switch in domoticz, then the import button which is right next to it and they should appear in unused devices.
saulysss
2019-01-19 20:14:36.800 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-01-19 20:14:36.800 Status: Build Hash: a3a45906, Date: 2018-06-23 15:24:51
2019-01-19 20:14:36.801 Status: Startup Path: /home/pi/domoticz/
2019-01-19 20:14:37.097 Active notification Subsystems: gcm, http (2/13)
2019-01-19 20:14:37.120 Starting shared server on: :::6144
2019-01-19 20:14:37.085 Status: PluginSystem: Started, Python version '3.5.3'.
2019-01-19 20:14:37.099 Status: WebServer(HTTP) started on address: :: with port 8080
2019-01-19 20:14:37.116 Status: WebServer(SSL) started on address: :: with port 443
2019-01-19 20:14:37.118 Status: Proxymanager started.
2019-01-19 20:14:37.121 Status: TCPServer: shared server started...
2019-01-19 20:14:37.121 Status: RxQueue: queue worker started...
2019-01-19 20:14:39.122 Status: (Remote) Started.
2019-01-19 20:14:39.123 Status: EventSystem: reset all events...
2019-01-19 20:14:39.124 Status: EventSystem: reset all device statuses...
2019-01-19 20:14:39.326 Status: Python EventSystem: Initalizing event module.
2019-01-19 20:14:39.326 Status: EventSystem: Started
2019-01-19 20:14:39.326 Status: EventSystem: Queue thread started...
2019-01-19 20:14:39.359 Status: PluginSystem: Entering work loop.
2019-01-19 20:14:40.560 Status: (Remote) Entering work loop.
2019-01-19 20:14:40.560 Status: (Remote) Initialized version 4.1.0, author 'zak45'
Here is my log , Raspberry PI Raspbian OS based system , any ideas to make it work ? (no device appears , when i add hardware , also when try to remove hardware Domoticz hangs)
Edit: Finaly works , solution is just older 2018-04-18-raspbian-stretch-lite , and all works ....
NomenNescio
- Domoticz version: v4.9700
Since a couple of days I cannot control a Broadlink RM2 anymore with Domoticz.
The RM2 responds on IHC app but no responds with this plugin.
a piece of the log:
2019-01-22 07:12:06.320 Status: User: Ruud initiated a switch command (31/Broadlink versterker - power/On)
2019-01-22 07:12:07.336 (Broadlink versterker) Pushing 'onCommandCallback' on to queue
2019-01-22 07:12:07.398 (Broadlink versterker) Processing 'onCommandCallback' message
2019-01-22 07:12:07.398 (Broadlink versterker) Calling message handler 'onCommand'.
2019-01-22 07:12:07.398 (Broadlink versterker) onCommand called for Unit 6: Parameter 'On', Level: 0 , Connected : False
2019-01-22 07:12:07.398 (Broadlink versterker) Generate on Command for learned code stored on unit/ini :6
2019-01-22 07:12:07.398 (Broadlink versterker) Code loaded : 260098000001299313371312141114111436141213121411141114361437133713121436143614361412133713371436141114111412133713371411141114111437133713371411140005150001294913000c550001294914000c540001294914000c550001284914000c550001294913000c560001284914000c550001294913000c550001294914000c550001294814000c550001294913000d05
2019-01-22 07:12:07.398 (Broadlink versterker) <b> Command line : "C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\plugin_send.py" C:/BroadlinkRM2/BroadlinkRM2-6-6.ini </b>
2019-01-22 07:12:07.398 (Broadlink versterker - power) Updating device from 0:'Off' to have values 1:'On-73'.
2019-01-22 07:12:07.476 (Broadlink versterker) Update 1:'On-73' (Broadlink versterker - power)
2019-01-22 07:12:08.461 (Broadlink versterker) Pushing 'onCommandCallback' on to queue
2019-01-22 07:12:08.476 (Broadlink versterker) Processing 'onCommandCallback' message
2019-01-22 07:12:08.476 (Broadlink versterker) Calling message handler 'onCommand'.
2019-01-22 07:12:08.476 (Broadlink versterker) onCommand called for Unit 6: Parameter 'Off', Level: 0 , Connected : False
2019-01-22 07:12:08.476 (Broadlink versterker - power) Updating device from 1:'On-73' to have values 0:'Off'.
2019-01-22 07:12:08.539 (Broadlink versterker) Update 0:'Off' (Broadlink versterker - power)
2019-01-22 07:12:12.070 (Broadlink versterker) Pushing 'onHeartbeatCallback' on to queue
2019-01-22 07:12:12.117 (Broadlink versterker) Processing 'onHeartbeatCallback' message
2019-01-22 07:12:12.117 (Broadlink versterker) Calling message handler 'onHeartbeat'.
2019-01-22 07:12:43.055 (Broadlink versterker) Pushing 'onHeartbeatCallback' on to queue
2019-01-22 07:12:43.086 (Broadlink versterker) Processing 'onHeartbeatCallback' message
2019-01-22 07:12:43.086 (Broadlink versterker) Calling message handler 'onHeartbeat'.
2019-01-22 07:13:14.039 (Broadlink versterker) Pushing 'onHeartbeatCallback' on to queue
2019-01-22 07:13:14.101 (Broadlink versterker) Processing 'onHeartbeatCallback' message
2019-01-22 07:13:14.101 (Broadlink versterker) Calling message handler 'onHeartbeat'.
2019-01-22 07:13:45.070 (Broadlink versterker) Pushing 'onHeartbeatCallback' on to queue
2019-01-22 07:13:45.101 (Broadlink versterker) Processing 'onHeartbeatCallback' message
2019-01-22 07:13:45.101 (Broadlink versterker) Calling message handler 'onHeartbeat'.
Verstuurd vanaf mijn ASUS Chromebook Flip C101PA met Tapatalk
a piece of the log:
NomenNescio
and in red:
2019-01-22 07:20:59.133 Error: (Broadlink versterker) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'.
2019-01-22 07:20:59.133 Error: (Broadlink versterker) ----> Line 473 in C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\plugin.py, function onHeartbeat
2019-01-22 07:20:59.133 Error: (Broadlink versterker) ----> Line 757 in C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\plugin.py, function checkTemp
zak45
- Domoticz version: V2024.4
Do you have made any update on your Domoticz version ?NomenNescio wrote: Tuesday 22 January 2019 7:23 and in red:
NomenNescio
No same version of Domoticz and your plugin.zak45 wrote:Do you have made any update on your Domoticz version ?NomenNescio wrote: Tuesday 22 January 2019 7:23 and in red:
NomenNescio
stopped and activated Broadlink in hardware and it is working again. A reboot of the windows 10 machine did not solve it.NomenNescio wrote: Tuesday 22 January 2019 15:41No same version of Domoticz and your plugin.zak45 wrote:Do you have made any update on your Domoticz version ?NomenNescio wrote: Tuesday 22 January 2019 7:23 and in red:
2019-01-24 07:35:21.309 Status: (Broadlink versterker) Stop directive received.
2019-01-24 07:35:21.412 Status: (Broadlink versterker) Stopping threads.
2019-01-24 07:35:21.502 Status: (Broadlink versterker) Exiting work loop.
2019-01-24 07:35:21.502 Status: (Broadlink versterker) Stopped.
2019-01-24 07:36:31.153 Status: (Broadlink versterker) Started.
2019-01-24 07:36:32.856 Status: (Broadlink versterker) Initialized version 4.1.0, author 'zak45'
hiretabletuk
Hi Zak
This is the complete Domoticz log, afterward the resume
2018-01-30 15:16:55.189 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-01-30 15:16:55.189 Build Hash: 494fff7-modified, Date: 2017-07-30 12:19:41
2018-01-30 15:16:55.190 Startup Path: /usr/local/domoticz/
2018-01-30 15:16:55.277 Sunrise: 07:39:00 SunSet:17:15:00
2018-01-30 15:16:55.277 EventSystem: reset all events...
2018-01-30 15:16:55.461 PluginSystem: Started, Python version '3.5.1'.
2018-01-30 15:16:55.471 Active notification Subsystems: pushover (1/12)
2018-01-30 15:16:55.484 WebServer(HTTP) started on address: :: with port 8084
2018-01-30 15:16:55.512 WebServer(SSL) started on address: :: with port 8443
2018-01-30 15:16:55.514 Proxymanager started.
2018-01-30 15:16:55.515 Starting shared server on: :::6150
2018-01-30 15:16:55.516 RxQueue: queue worker started...
2018-01-30 15:16:55.516 TCPServer: shared server started...
2018-01-30 15:16:55.590 Incoming connection from: 217.xx.xx.xx
2018-01-30 15:16:57.517 EventSystem: reset all events...
2018-01-30 15:16:57.518 EventSystem: reset all device statuses...
2018-01-30 15:16:57.518 Netatmo: Worker started...
2018-01-30 15:16:57.518 Logitech Media Server: Worker started...
2018-01-30 15:16:57.554 Logitech Media Server: 2 player-switch(es) found.
2018-01-30 15:16:57.757 Python EventSystem: Module not found - Trying to initialize.
2018-01-30 15:16:57.757 Python EventSystem: Initalizing event module.
2018-01-30 15:16:57.758 EventSystem: Started
2018-01-30 15:16:57.859 PluginSystem: Entering work loop.
2018-01-30 15:16:58.224 Logitech Media Server: 279 playlist(s) found.
2018-01-30 15:16:58.520 RFXCOM: Using serial port: /dev/ttyUSB0
2018-01-30 15:16:58.775 (My br- Discover) Initialized version 4.0.0, author 'zak45'
2018-01-30 15:16:58.836 (My br- Discover) Debug log level set to: 'true'.
2018-01-30 15:16:58.836 (My br- Discover) 'Mode2':'C:/BroadlinkRM2'
2018-01-30 15:16:58.836 (My br- Discover) 'HomeFolder':'/usr/local/domoticz/var/plugins/BroadlinkRM2/'
2018-01-30 15:16:58.836 (My br- Discover) 'Mode3':'DIS'
2018-01-30 15:16:58.836 (My br- Discover) 'Mode1':'000000000000'
2018-01-30 15:16:58.836 (My br- Discover) 'Author':'zak45'
2018-01-30 15:16:58.836 (My br- Discover) 'Name':'My br- Discover'
2018-01-30 15:16:58.836 (My br- Discover) 'Port':'0'
2018-01-30 15:16:58.836 (My br- Discover) 'HardwareID':'17'
2018-01-30 15:16:58.836 (My br- Discover) 'Version':'4.0.0'
2018-01-30 15:16:58.837 (My br- Discover) 'Mode6':'Debug'
2018-01-30 15:16:58.837 (My br- Discover) 'Mode4':'no'
2018-01-30 15:16:58.837 (My br- Discover) 'Mode5':'9000'
2018-01-30 15:16:58.837 (My br- Discover) 'Key':'BroadlinkRM2'
2018-01-30 15:16:58.837 (My br- Discover) 'Address':'127.0.0.1'
2018-01-30 15:16:58.837 (My br- Discover) Device count: 2
2018-01-30 15:16:58.837 (My br- Discover) Device: 1 - ID: 79, Name: 'My br- Discover - Discovery', nValue: 0, sValue: ''
2018-01-30 15:16:58.837 (My br- Discover) Device ID: '79'
2018-01-30 15:16:58.837 (My br- Discover) Device Name: 'My br- Discover - Discovery'
2018-01-30 15:16:58.837 (My br- Discover) Device nValue: 0
2018-01-30 15:16:58.837 (My br- Discover) Device sValue: ''
2018-01-30 15:16:58.838 (My br- Discover) Device LastLevel: 0
2018-01-30 15:16:58.838 (My br- Discover) Device: 2 - ID: 80, Name: 'My br- Discover - Discovery Info', nValue: 0, sValue: ''
2018-01-30 15:16:58.838 (My br- Discover) Device ID: '80'
2018-01-30 15:16:58.838 (My br- Discover) Device Name: 'My br- Discover - Discovery Info'
2018-01-30 15:16:58.838 (My br- Discover) Device nValue: 0
2018-01-30 15:16:58.838 (My br- Discover) Device sValue: ''
2018-01-30 15:16:58.838 (My br- Discover) Connecting to: 127.0.0.1:000000000000
2018-01-30 15:16:58.838 (My br- Discover) Device Number begin to : 1
2018-01-30 15:16:58.838 (My br- Discover) Heartbeat interval set to: 30.
2018-01-30 15:16:59.095
2018-01-30 15:16:59.173 subtype = Interface Response
Bigya
Hi All,
I'm new in Domoticz. I was trying to get a Broadlink RM2 to work with the domoticz on a Pi3+/Raspbian.
I have spent a day, but the only thing I can get is the broadlink device is showing up at the Hardware menu, but failed to show up in the Devices menu.
Now I really messed up my file system, but there is my log:
2019-01-26 18:36:14.625 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/-link/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-01-26 18:36:14.625 Error: (gateway) Module Import failed, exception: 'NameError'
Can You please help me how to solve the issue?
(meantime I switch back to hassio...
jon205
- Domoticz version: 2022.2
Same here.
I've added the hardware, but I keep getting an error in the log:
I've copied the plugin.py file to several locations, nothing seems to help.
I'm running Domoticz:
Version: 4.9700
Build Hash: a3a4590-modified
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.5.1 (default, Dec 9 2016, 00:20:03) [GCC 4.9.3 20150311 (prerelease)]
on Xpenology.
Any ideas?
I've tried to follow the tutorial, but it's not working on DSM.
Regards, Jon.
2019-01-29 21:06:14.392 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2019-01-29 21:06:14.392 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2019-01-29 21:06:14.392 Error: (Broadlink) Module Import failed: ' Name: broadlink'I'm running Domoticz:
Version: 4.9700
on Xpenology.
Any ideas?
Regards, Jon.
zak45
This is not related to plugin.py but to broadlink module, framework not able to find it.jon205 wrote: Tuesday 29 January 2019 21:15 Same here.
I've copied the plugin.py file to several locations, nothing seems to help.Code: Select all
2019-01-29 21:06:14.392 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'. 2019-01-29 21:06:14.392 Error: (Broadlink) Module Import failed, exception: 'ImportError' 2019-01-29 21:06:14.392 Error: (Broadlink) Module Import failed: ' Name: broadlink'
Version: 4.9700
on Xpenology.
Any ideas?
Regards, Jon.
to verify , try to copy broadlink folder under /usr/local/domoticz/var/plugins/BroadlinkRM2/
jon205
Hey Zak, thanks for taking the time to respond. It is very much appreciated.
This is the content of the folder you are referring to:
Isn't this what you are suggesting? The broadlink folder is already there.
Or do you mean there's a broadlink folder that should be in the BroadlinkRM2 folder?
This is currently in there:
Thanks in advance!
Jon.
admin@NAS:/usr/local/domoticz/var/plugins$ ls
BroadlinkRM2 python-broadlink-masterOr do you mean there's a broadlink folder that should be in the BroadlinkRM2 folder?
admin@NAS:/usr/local/domoticz/var/plugins/BroadlinkRM2$ ls
ini plugin_http.py plugin_http.sh plugin.py plugin_send.py __pycache__Jon.
jon205
Okay, so I did copy the broadlink folder to the /BroadlinkRM2 folder:
Now the error in the logging has changed indeed, so you were right. This is now in the log:
Now I think I have to copy pyaes to that folder as well. Am I right or am I thinking too simple?
Thanks for taking the time.
Jon.
----EDIT----
I wasn't thinking too simple. You've found your way into my logfile:
I now only get an connection error.
The address is pingable and a static dhcp has been configured for the Broadlink.
I'll continue my puzzle
Jon.
----EDIT----
Another edit (almost a live-blog now
The MAC address has to be entered in small caps, not like I would expect in BIG CAPS.
Connection is working now.
Jon.
broadlink plugin_http.py plugin.py __pycache__
ini plugin_http.sh plugin_send.pyCode: Select all
admin@NAS:/usr/local/domoticz/var/plugins/BroadlinkRM2/broadlink$ ls
__init__.py __pycache__Code: Select all
2019-01-31 21:14:45.808 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2019-01-31 21:14:45.808 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2019-01-31 21:14:45.808 Error: (Broadlink) Module Import failed: ' Name: pyaes'
2019-01-31 21:14:45.808 Error: (Broadlink) Error Line details not available.Thanks for taking the time.
Jon.
----EDIT----
Status: (Broadlink) Initialized version 4.1.0, author 'zak45'
(Broadlink) Error Connecting to Broadlink device....192.168.1.100
Jon.
----EDIT----
Jon.
jon205
Okay, last question (for today)...
According to the manual, a switch called xxx- command should have been created. I only see Broadlink Discovery, Broadlink Remote and Broadlink Import. No command switch. It's not in the unused switches list, it's just not there. Could this be a missing file in the plugin folder?
Jon.
Jon.
zak45
remove all created devices, go to HW, choose the right device type and reload the plugin.jon205 wrote: Thursday 31 January 2019 22:13 Okay, last question (for today)...
Jon.
jon205
Thanks! That did the job.
Jon.
Jon.
Re: Check Temp
I have the same issue occasionally with RM mini3, I have two minis, called "Broadlink MH remote"and "Broadlink OH remote" .RueDesButtes wrote: Monday 07 January 2019 9:22 Update to Version: 4.10329
no more issue
Since few days I am facing these errors:
2019-01-07 08:55:20.789 Error: (RMPRO) Error Connecting to Broadlink device....192.168.1.26
2019-01-07 08:56:09.975 Error: (RMPRO) Error getting temperature data from Broadlink device....Timeout
2019-01-07 08:56:19.987 Error: (RMPRO) Error Connecting to Broadlink device....192.168.1.26
2019-01-07 09:00:19.962 Error: (RMPRO) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'.
2019-01-07 09:00:19.962 Error: (RMPRO) ----> Line 475 in '/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-01-07 09:00:19.963 Error: (RMPRO) ----> Line 759 in '/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
My RM is set as "Remote Control RM2/RM mini3" value="RM2",
it should not check temp
Yesterday I restarted WiFi what I think triggered the issue. Workaround is to restart Domoticz and it will be fine.
Domoticz Version: 4.10159
Broadlink Plugin version 4.1
Edit, yes problem started after WiFi restart.
Why it goes to lines 473, 757 even for this device should not check temps?
2019-02-05 21:30:17.150 Error: (Broadlink MH remote) Error getting temperature data from Broadlink device....Timeout
2019-02-05 21:30:27.179 Error: (Broadlink MH remote) Error Connecting to Broadlink device....192.168.107.190
2019-02-05 21:30:37.198 Error: (Broadlink OH remote) Error getting temperature data from Broadlink device....Timeout
2019-02-05 21:30:47.215 Error: (Broadlink OH remote) Error Connecting to Broadlink device....192.168.107.130
2019-02-05 21:31:14.788 Error: Broadlink OH remote hardware (10) thread seems to have ended unexpectedly
2019-02-05 21:31:14.788 Error: Broadlink MH remote hardware (11) thread seems to have ended unexpectedly
2019-02-05 21:35:16.788 Error: (Broadlink MH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-05 21:35:16.788 Error: (Broadlink MH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-05 21:35:16.788 Error: (Broadlink MH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
2019-02-05 21:35:17.297 Error: (Broadlink OH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-05 21:35:17.298 Error: (Broadlink OH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-05 21:35:17.298 Error: (Broadlink OH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
2019-02-05 21:35:46.807 Error: (Broadlink MH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-05 21:35:46.807 Error: (Broadlink MH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-05 21:35:46.807 Error: (Broadlink MH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
2019-02-05 21:35:47.317 Error: (Broadlink OH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-05 21:35:47.317 Error: (Broadlink OH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-05 21:35:47.317 Error: (Broadlink OH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
2019-02-06 12:25:20.004 Error: (Broadlink OH remote) Error getting temperature data from Broadlink device....Timeout
2019-02-06 12:25:30.016 Error: (Broadlink OH remote) Error Connecting to Broadlink device....192.168.107.130
2019-02-06 12:25:40.027 Error: (Broadlink MH remote) Error getting temperature data from Broadlink device....Timeout
2019-02-06 12:25:50.040 Error: (Broadlink MH remote) Error Connecting to Broadlink device....192.168.107.190
2019-02-06 12:26:11.084 Error: Broadlink OH remote hardware (10) thread seems to have ended unexpectedly
2019-02-06 12:26:11.084 Error: Broadlink MH remote hardware (11) thread seems to have ended unexpectedly
2019-02-06 12:30:19.619 Error: (Broadlink OH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-06 12:30:19.619 Error: (Broadlink OH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-06 12:30:19.619 Error: (Broadlink OH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTemp
2019-02-06 12:30:20.129 Error: (Broadlink MH remote) 'onHeartbeat' failed 'TypeError':''>' not supported between instances of 'NoneType' and 'int''.
2019-02-06 12:30:20.129 Error: (Broadlink MH remote) ----> Line 473 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function onHeartbeat
2019-02-06 12:30:20.129 Error: (Broadlink MH remote) ----> Line 757 in '/data2/domoticz/plugins/BroadlinkRM2/plugin.py', function checkTempEdit3:
Here diff to reconnect, worked fine in quick testing.
--- plugin-4.1.py 2019-02-06 12:53:05.305188810 +0200
+++ plugin.py 2019-02-06 12:52:12.662811142 +0200
@@ -470,12 +470,14 @@
# for RM2 we try to connect every 5 minutes if checkTemp is False
else:
if (now.minute % 5 == 0):
- if not checkTemp():
- UpdateDevice(1,0,'Off')
- if broadlinkConnect():
- UpdateDevice(1,1,'10')
- bypass = True
+ if isConnected:
+ if not checkTemp():
+ UpdateDevice(1,0,'Off')
+ if broadlinkConnect():
+ UpdateDevice(1,1,'10')
+ bypass = True
+ else:
+ broadlinkConnect()
return True
# executed once when HW updated/removed
fvdp80
- Domoticz version: 4.10303
I can confirm the issue Bogey has found. Same for me.
Whatsek
- Domoticz version: Latest B
I have the same behavior after a wifi restart. If I disable the rm3 pro in domoticz, and enable it again all iss working again. Will test the data timeout function in domoticz now.
Verstuurd vanaf mijn MI MAX 3 met Tapatalk
