Kodi state update
puls8
Kodi state update
Post by puls8 »
I have a script made in blockly to turn off the lights at a given time. This works just fine. Now I added a logic rule to not turn off the lights when Kodi has not the "off" state. To my suprise it turns off the lights no regards the state of Kodi. When I press the "Show current states" button, it shows Kodi off for more than 2 days, while Kodi is running and in the Switches tab it shows which movie is playing. Apparently kodi state is not (always) updating. What could I do to fix this?
puls8
Re: Kodi state update
Post by puls8 »
Meanwhile I tried to add a dummy switch as a slave of Kodi, but that doesn't work neither.
The only working solution for now is to ping the Kodi (libreelec box): https://www.domoticz.com/wiki/System_Al ... ker_(Ping) It 's not as neat, but it looks like it works.
jake
Post by jake »
I use the Kodi python plugin an it works fine. My scripts act on 'audio', 'video'and 'on'.
I added a plugin to Kodi that now updates a virtual switch in domoticz to see when Kodi is 'idle' (interface is dimmed because of no user input)
I never had domoticz guessing incorrectly what the actual state is.
Is it correct that you completely shutdown the pi? I can imagine in that case that domoticz doesn't know.
puls8
Post by puls8 »
You mean this plugin: https://github.com/dnpwwo/Domoticz-Kodi-Plugin ?
Strange to use a plugin to for build-in functionality...
BTW I am using Kodi (libreelec) on a NUC and yes, I do a full shutdown (and power off)
Dnpwwo
Post by Dnpwwo »
@puls8,
The native functionality has not been developed for some time but was left in the code base for backwards compatibility.
The plugin version has more functionality and is more actively supported. Your choice which one you go with of course.
puls8
Post by puls8 »
@Dnpwwo
Thanks for your explanation. I installed the plugin following the instructions: https://github.com/dnpwwo/Domoticz-Kodi ... stallation
so I installed it in: /opt/domoticz/plugins but after restarting (sudo /etc/init.d/domoticz.sh restart) it won't show in the hardware list. A raspberry reboot resulted in "offline" state of domoticz. A cold boot restored domoticz but still no "Kodi players" in the hardware list.
puls8
Post by puls8 »
Update: I did a browser cache clean up, but also no "Kodi player" in the hardware list.
I have installed it here:
/opt/domoticz/plugins# ls
AwoxSMP  Domoticz-Kodi-Plugin  examples
Is this correct?
Dnpwwo
Post by Dnpwwo »
@puls8,
Have a look at https://www.domoticz.com/forum/viewtopi ... 2f#p202680, sounds like Domoticz isn't finding Python.
puls8
Post by puls8 »
python --version
Python 2.7.13
Is this version too old/outdated?
Dnpwwo
Post by Dnpwwo »
@puls8,
Yes, Domoticz requires 3.4 as a minimum, have a look at https://www.domoticz.com/wiki/Using_Python_plugins
