Disclaimer: I'm new to Domoticz
I'm trying to use Lua scripts to run when some virtual switch is ON (on action ON).
I have written my Lua script in the Setup>More Options>Events GUI under "Lua". However, the script does not appear once saved in my /home/pi/domoticz/scripts/lua folder as it should (?). Therefore I cannot link to it from a switch starting with script:// ...
Am I missing something?
Cheers,
Frank
Where are my Lua scripts ?
- Siewert308SW
- Domoticz version: Stable
Re: Where are my Lua scripts ?
Lua scripts written in Domoticz it self are stored into the database and not as fiscal file
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
- waaren
domoticz Lua and dzVents scripts in domoticz are not to be used in the On or Off section as script:// types.fsabatie wrote: ↑Wednesday 02 January 2019 15:21 I'm trying to use Lua scripts to run when some virtual switch is ON (on action ON).
Cheers,
Frank
It will not work as they need domoticz data that is not available to OS level Lua scripts.
I think I understand
thanks !
thanks !
As an additional remark, just in case you didn't know yet:
You can still make your script run when your switch is operated (regardless of whether it is saved under ~/domoticz/scripts/lua or in the database). Just set the type to "device", and do a check such as
Change 'On' to whatever state you want your script to start on (also depends on the device type).
if devicechanged['Your device'] == 'On' then
... (your code)
