Where are my Lua scripts ?
fsabatie
Post by fsabatie »
Disclaimer: I'm new to Domoticz
I'm trying to use Lua scripts to run when some virtual switch is ON (on action ON).
I have written my Lua script in the Setup>More Options>Events GUI under "Lua". However, the script does not appear once saved in my /home/pi/domoticz/scripts/lua folder as it should (?). Therefore I cannot link to it from a switch starting with script:// ...
Am I missing something?
Cheers,
Frank
Siewert308SW
Domoticz version: Stable
Re: Where are my Lua scripts ?
Post by Siewert308SW »
Lua scripts written in Domoticz it self are stored into the database and not as fiscal file
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
fsabatie wrote: Wednesday 02 January 2019 15:21 I'm trying to use Lua scripts to run when some virtual switch is ON (on action ON).
Cheers,
Frank
domoticz Lua and dzVents scripts in domoticz are not to be used in the On or Off section as script:// types.
It will not work as they need domoticz data that is not available to OS level Lua scripts.
fsabatie
Post by fsabatie »
I think I understand :)
thanks !
mvzut
Post by mvzut »
As an additional remark, just in case you didn't know yet:
You can still make your script run when your switch is operated (regardless of whether it is saved under ~/domoticz/scripts/lua or in the database). Just set the type to "device", and do a check such as
if devicechanged['Your device'] == 'On' then
 ... (your code)
Change 'On' to whatever state you want your script to start on (also depends on the device type).
