RPi3
Z-Stick
newest beta
Happy Christmas,
I have problems with Eurotronic spirit to switch them in different modes with dzvents. In control panel I can switch between mode Off/HeatEco/Full Power/Manufacturer specific. How can I do this with dzvents? I tried domoticz.devices('Heat Eco').updateMode('Off') got
Method updateMode is not available for device "Heat Eco " (deviceType=Thermostat, deviceSubType=SetPoint). If you believe this is not correct, please report.
Same for domoticz.devices('Heat Eco').switchOff()
Method switchOff is not available for device "Heat Eco" (deviceType=Thermostat, deviceSubType=SetPoint). If you believe this is not correct, please report.
Any hint?
Change mode of heat valve
- waaren
Re: Change mode of heat valve
The Eurotronic is recognized by dzVents as a Thermostat Setpoint device. This limit the possible dzVents commands for this device tosailmich wrote: Friday 28 December 2018 20:04 I have problems with Eurotronic spirit to switch them in different modes with dzvents. In control panel I can switch between mode Off/HeatEco/Full Power/Manufacturer specific. How can I do this with dzvents? I tried domoticz.devices('Heat Eco').updateMode('Off') got
Any hint?
setPoint as in
domoticz.devices('Heat Eco').setPointand the functions to
updateSetPoint() as in
domoticz.devices('Heat Eco').updateSetPoint(21)Debian buster, bullseye on RPI-4, Intel NUC.
sailmich
@waaren thanks for the offer! I believe I wouldn't be helpful I'm not good in coding I just took some code from here and there and put it together to my needs.
If dzvents recognized the Eurotronic in the wrong way, where can I report it?
- waaren
Send you a PMsailmich wrote: Sunday 30 December 2018 9:02 @waaren thanks for the offer! I believe I wouldn't be helpful I'm not good in coding I just took some code from here and there and put it together to my needs.
sailmich
e.g.
domoticz.devices('Thermostat Mode').updateMode('Off')
To many devices in domoticz came up with Eurotronics Spirit Z-Wave.
I believe for a heating system in Germany and maybe rest of Europe the follow devices are important.
Thermostat Mode = switch between the modes Heat/Heat Eco/Off/Full Power
Heat = here you set the comfort temperature the heating running under normal condition.
Heat Eco = here you can set a lower or higher temperature than comfort temperature.
What furnace are for, I don't know.
