Change mode of heat valve
sailmich
Post by sailmich »
RPi3
Z-Stick
newest beta
Happy Christmas,
I have problems with Eurotronic spirit to switch them in different modes with dzvents. In control panel I can switch between mode Off/HeatEco/Full Power/Manufacturer specific. How can I do this with dzvents? I tried domoticz.devices('Heat Eco').updateMode('Off') got
Method updateMode is not available for device "Heat Eco " (deviceType=Thermostat, deviceSubType=SetPoint). If you believe this is not correct, please report.
Same for domoticz.devices('Heat Eco').switchOff()
Method switchOff is not available for device "Heat Eco" (deviceType=Thermostat, deviceSubType=SetPoint). If you believe this is not correct, please report.
Any hint?
Re: Change mode of heat valve
sailmich wrote: Friday 28 December 2018 20:04 I have problems with Eurotronic spirit to switch them in different modes with dzvents. In control panel I can switch between mode Off/HeatEco/Full Power/Manufacturer specific. How can I do this with dzvents? I tried domoticz.devices('Heat Eco').updateMode('Off') got
Any hint?
The Eurotronic is recognized by dzVents as a Thermostat Setpoint device. This limit the possible dzVents commands for this device to
setPoint as in
domoticz.devices('Heat Eco').setPoint
and the functions to
updateSetPoint() as in
domoticz.devices('Heat Eco').updateSetPoint(21)
If you are interested I can work with you to create a new dzVents device-adapter or update an existing one to enable more of the device controls in dzVents for this device. If so please send me a PM.
sailmich
Post by sailmich »
@waaren thanks for the offer! I believe I wouldn't be helpful I'm not good in coding I just took some code from here and there and put it together to my needs.
If dzvents recognized the Eurotronic in the wrong way, where can I report it?
sailmich wrote: Sunday 30 December 2018 9:02 @waaren thanks for the offer! I believe I wouldn't be helpful I'm not good in coding I just took some code from here and there and put it together to my needs.
Send you a PM
sailmich
Post by sailmich »
:oops: I didn't recognized the Thermostat Mode in domoticz device. When select this as used device I can easily switch the mode :o
e.g.
domoticz.devices('Thermostat Mode').updateMode('Off')
To many devices in domoticz came up with Eurotronics Spirit Z-Wave.
I believe for a heating system in Germany and maybe rest of Europe the follow devices are important.
Thermostat Mode = switch between the modes Heat/Heat Eco/Off/Full Power
Heat = here you set the comfort temperature the heating running under normal condition.
Heat Eco = here you can set a lower or higher temperature than comfort temperature.
What furnace are for, I don't know.
