2 minutes delay in device trigger DZVents in log
klaaspiet
Re: 2 minutes delay in device trigger DZVents in log
Post by klaaspiet »
Hey. Thank al for the help. I dit der that the rate limit of the p1 USB hardware is 0. If i increase that the CPU is going down.
klaaspiet wrote: Sunday 30 December 2018 15:19 the rate limit of the p1 USB hardware is 0. If i increase that the CPU is going down.
The value of 0 is the default. The CPU usage will go down if you raise it but I expect that this is not the root cause of your CPU usage problem.
klaaspiet
Post by klaaspiet »
I set the rate limit on 120sec. And now my CPU is 21 25%. And my scrips are working fine.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Even 20% is way to high. My cpu usage is 0,2 to 0,5% with zwave, rfxcom, xiaomi, 150 used devices, 400 variables and lots of scripts.
Egregius wrote: Sunday 30 December 2018 16:59 Even 20% is way to high. My cpu usage is 0,2 to 0,5% with zwave, rfxcom, xiaomi, 150 used devices, 400 variables and lots of scripts.
Wow these Raspberries must be much faster in Belgium than they sell them in the Netherlands... :D
klaaspiet
Post by klaaspiet »
waaren wrote: Sunday 30 December 2018 17:51
:D
