i'm sorry if the question is alredy solved , but i havn't found and it seems that i'm the only one who doesn't find the way to display domoticz devices in imperihome.
{"devices":[{"id":"S0","name":"MyDomoAtHome","type":"DevGenericSensor","params":[{"key":"Value","value":"0.2.39","unit":"","graphable":"false"}]},{"id":"5","name":"peynier Temp Programmée","type":"DevThermostat","room":"Switches","params":[{"key":"cursetpoint","value":"21.0"},{"key":"curtemp","value":"21.0"},{"key":"step","value":"0.5"},{"key":"curmode","value":"default"},{"key":"availablemodes","value":"default"}]},{"id":"6","name":"peynier Salon Temp Hum","type":"DevTempHygro","room":"Temp","params":[{"key":"Hygro","value":46,"unit":"%","graphable":"true"},{"key":"Temp","value":18.5,"unit":"°C","graphable":"true"}]},{"id":"7","name":"peynier Salon Chauffe On/Off","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"1"}]},{"id":"8","name":"peynier Absence","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"9","name":"peynier Mode Eco Manuel","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"10","name":"ampli yamaha - Status","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"11","name":"ampli yamaha - Volume","type":"DevDimmer","room":"Switches","params":[{"key":"Status","value":"1"},{"key":"Level","value":"56"}]},{"id":"12","name":"ampli yamaha - Source","type":"DevMultiSwitch","room":"Switches","params":[{"key":"LastRun","value":1544904090000},{"key":"Value","value":"HDMI1"},{"key":"Choices","value":"HDMI1,HDMI2,HDMI3,HDMI4,HDMI5,HDMI6,HDMI7"}]},{"id":"13","name":"ampli yamaha - AV Source","type":"DevMultiSwitch","room":"Switches","params":[{"key":"LastRun","value":1542184740000},{"key":"Value","value":"Off"},{"key":"Choices","value":"AV1,AV2,AV3,AV4,AV5,AV6"}]},{"id":"14","name":"Samsung TV - Status","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"15","name":"Samsung TV - Source","type":"DevMultiSwitch","room":"Switches","params":[{"key":"LastRun","value":1544917581000},{"key":"Value","value":"Off"},{"key":"Choices","value":"TV,HDMI,HDMI1,HDMI2"}]},{"id":"16","name":"Samsung TV - Volume","type":"DevMultiSwitch","room":"Switches","params":[{"key":"LastRun","value":1544917581000},{"key":"Value","value":"Off"},{"key":"Choices","value":"Off,VOL+,VOL-"}]},{"id":"17","name":"Samsung TV - Input","type":"DevMultiSwitch","room":"Switches","params":[{"key":"LastRun","value":1544917581000},{"key":"Value","value":"Off"},{"key":"Choices","value":"SOURCE,ANYNET,ENTER"}]},{"id":"18","name":"SolarEdge Production en kWh","type":"DevElectricity","room":"Utility","params":[{"key":"Watts","value":"232","unit":"W"},
i have installed imperihome Pro on my android smartphone (version 8.4) and start with myobjets mapping (right now ok with Myharmony, Hue, spotify, ....)
i have added a mapping on address web (which return the contents above), but no picture, graphic, just display the code like a json envelopp ?
but couldn't find in parameters/general preferences or Myobjects add an object how to set domoticz system
