I also bought the cheap door contact
But connect it through a Sonoff RF bridge, which is flashed with Tasmota firmware.
The door contact sends different svalues for the status of 'open' and 'closed', however it is both sended by the same Idx (In my case Idx 5 (in Tasmota under "Sensor idx 6 Count/PM1") to Domoticz.
In the Log of Domoticz I'll get the following messages:
2018-11-18 15:18:49.967 MQTT: Topic: domoticz/in, Message: {"idx":5,"nvalue":0,"svalue":"9243402","Battery":64,"RSSI":8}
2018-11-18 15:18:52.276 MQTT: Topic: domoticz/in, Message: {"idx":5,"nvalue":0,"svalue":"9243406","Battery":64,"RSSI":8}9243406 = Closed
But if I look in the Log of the Dummy switch with Idx 5 i'll see when I open ánd close the sensor:
2018-11-18 15:18:52 Off
2018-11-18 15:18:49 OffSo I want to make a switch that gives the right status.
I tried things with a LUA script, but I'm a noob
Can somebody help me with making the script, so I'll get a Dummy switch that distinguishes the different svalue and translate it to the right status of the dummy switch?
Thanks a lot!
