Door contact, open/close IDX svalue MQTT
OTiby
Post by OTiby »
I also bought the cheap door contact
But connect it through a Sonoff RF bridge, which is flashed with Tasmota firmware.
The door contact sends different svalues for the status of 'open' and 'closed', however it is both sended by the same Idx (In my case Idx 5 (in Tasmota under "Sensor idx 6 Count/PM1") to Domoticz.
In the Log of Domoticz I'll get the following messages:
2018-11-18 15:18:49.967 MQTT: Topic: domoticz/in, Message: {"idx":5,"nvalue":0,"svalue":"9243402","Battery":64,"RSSI":8}
2018-11-18 15:18:52.276 MQTT: Topic: domoticz/in, Message: {"idx":5,"nvalue":0,"svalue":"9243406","Battery":64,"RSSI":8}
9243402 = Open
9243406 = Closed
But if I look in the Log of the Dummy switch with Idx 5 i'll see when I open ánd close the sensor:
2018-11-18 15:18:52	Off
2018-11-18 15:18:49	Off
Both messages are "Off"
So I want to make a switch that gives the right status.
I tried things with a LUA script, but I'm a noob :P So I don't understand it.
Can somebody help me with making the script, so I'll get a Dummy switch that distinguishes the different svalue and translate it to the right status of the dummy switch?
Thanks a lot!
OTiby
Re: Door contact, open/close IDX svalue MQTT
Post by OTiby »
Can somebody help? :)
OTiby
Post by OTiby »
Nobody?
OTiby wrote: Sunday 18 November 2018 15:23 The door contact sends different svalues for the status of 'open' and 'closed', however it is both sended by the same Idx (In my case Idx 5 (in Tasmota under "Sensor idx 6 Count/PM1") to Domoticz.
9243402 = Open
9243406 = Closed
If you cannot change the MQTT data that is send to domoticz then you indeed need a script.
Below is a working dzVents script for your situation. Please take the max 10 minutes needed, to read and understand the first page of dzVents wiki here and the Quickstart that will get you going with dzVents.
    on = { devices = { 5 } },
    execute = function(dz, item)
        if item.rawData[1] == "9243402" then
            item.switchOn().checkFirst().silent()
MikeF
Domoticz version: V2022.2
Post by MikeF »
As a variation of this, I've set up a 2-button remote (Home Easy HE301):
- so that button 'I' toggles my Inside lights, and button 'O' toggles my Outside lights (I / O - good WAF :lol: )
    on = { devices = { "dummy" } },
        local switch1 = dz.devices("Inside")
        local switch2 = dz.devices("Outside")
        if item.rawData[1] == "5325077" then
            switch1.toggleSwitch()
        elseif item.rawData[1] == "5325076" then
            switch2.toggleSwitch()
(I found that I needed to create a 'dummy' switch to associate the RF Bridge with, otherwise switch1 always got switched.)
MikeF
Post by MikeF »
waaren wrote: Thursday 29 November 2018 1:28 Below is a working dzVents script for your situation.
Shouldn't the 'else' clause be:
item.switchOff().checkFirst().silent()
MikeF wrote: Friday 30 November 2018 17:54
Yes you are right. My mistake
erasor2010
Post by erasor2010 »
MikeF wrote: Thursday 29 November 2018 17:49 As a variation of this, I've set up a 2-button remote (Home Easy HE301):
i tried it like schon in this example but i doesnt work.
This is my Code
on = { devices = { 4 } },
local switch1 = dz.devices("Wohnzimmer Stehlampe")
local switch2 = dz.devices("Wohnzimmer Esstisch")
if item.rawData[1] == "712753" then
elseif item.rawData[1] == "712756" then
nothing hapens an in the Domoticz Log i get this Message
Error: EventSystem: Lua script RF Bridge Licht did not return a commandArray
Is there A mistake in My code that i dont see?
Try saving the script as a type dzVents. You now saved it as a type Lua.
erasor2010
Hi, thank you that worked, but i have a new Problem now. The first two switches working perfektly, but the third wont toggle
        local switch1 = dz.devices(2)
        local switch2 = dz.devices(3)
        local switch3 = dz.devices(5)
        elseif item.rawData[1] == "712754" then
            switch3.toggleSwitch()
