domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
@Gravityz
No, I have not had time to look at this ...
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
MasterMD
Domoticz version: V3.9483
Post by MasterMD »
I am using the beta version for DSM6.2 (domoticz_88f6282-6.2_3.0.9483-7.spk) on a DS112+.
My DOmotics system states:
V3.9483
dzVents 2.4.5But I think I see exact the same problems as in this topic.
Empty directories and using different directories, and a message like "Lua script /usr/local/domoticz/var/dzVents/runtime/dzVents.lua did not return a commandArray" when I copy some script into the file dzVents.lua.
Any chance that there will be a new beta for DS112+?
MasterMD
Post by MasterMD »
Gravityz wrote: Sunday 24 June 2018 21:53 thanks
please also check why it is executing in /usr/local/domoticz/dzVents/runtime while installing it under /usr/local/domoticz/var/dzVents/runtime
V3.9483
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
i checked my setup and looked at the data of both directories
/usr/local/domoticz/dzVents/runtime has the most recent date so this one gets updated when i install a new package
/usr/local/domoticz/var/dzVents/runtime seems to have an old date
i moved this last(old) directory but everything kept on working
also when i check the logs the right new path is used
Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
i am running 4.10181 and use the apollolake build.
maybee the problem still exists in your build. @Jumbotroll, can you check
Davlent
Domoticz version: V4.10181
Post by Davlent »
Hi Jumbotroll,
Like said in previous message, driver is now recognized, but, it seems no connection are made, nor sensors (thermostat) nor relay.
Relay seems well binded, I received message in domoticz 'bind succeed' but it doesn't appear in 'devices' after that (and normally must appears after binding like domoticz has programmed I read).
Same problems for sensors, when asking to waiting after sensors (because sensors doesn't 'speak' always (every 4 minutes I read)) it never appears a sensor in the device list.
Can you check or tell me if it is related to Syno version release (then your compilation) or to Domoticz version release (in general) ?
kind regards,
David.
Gravityz
Post by Gravityz »
@Jumbotroll
with my limited knowledge i think i solved the ever irritating logrotate problem on synology(and probably every other platform)
it involves a minor change to the start-stop-status script in /var/packages/domoticz/scripts.
what i want to know is if you make/adjust this script customized for synology or that you do not touch it?
if you make/customize this i can tell you what to change in the build, if not i will tell the people at github(do not know how this pull request works so maybee you can let them know instead)
thanks
jumbotroll
Gravityz wrote: Friday 16 November 2018 18:27 @Jumbotroll
thanks
I can change the script if it does not affect other features.
Send me the change and I'll see if I can add it.
Jumbotroll
MasterMD
Post by MasterMD »
jumbotroll wrote: Friday 16 November 2018 20:00
thanks
My Domotics system states: V3.9483 - dzVents 2.4.5
I think I see exact the same problems as in this topic: empty directories and using different directories, and a message like "Lua script /usr/local/domoticz/var/dzVents/runtime/dzVents.lua did not return a commandArray" when I copy some script into the file dzVents.lua.
jumbotroll
MasterMD wrote: Saturday 17 November 2018 19:44
Sorry
I do not build domoticz for 88f6281/82 anymore, because of -std=c++11 is not supported in the old toolchain from synology.
I posted this many time before..
Jumbotroll
MasterMD
Post by MasterMD »
jumbotroll wrote: Saturday 17 November 2018 20:05
Sorry
I am quite new to this stuff. Does this mean: end-of-domoticz-life for the DS112+?
Or is there any possibility to use one of the DSM6.2 versions?
jumbotroll
MasterMD wrote: Saturday 17 November 2018 20:27
The changes in domoticz source code with c++11 is not supported with older gcc.
domoticz_88f6282-6.2_3.0.9483-7.spk was the last build for DS112+.
If not Synology in the future update kernel and gcc toolchain for arch-88f6281/82, but I don't think they will do that.
Jumbotroll
hkuit
Post by hkuit »
Hi, I want to install Domoticz on my Synology DS414j.
I have searched on jadahl.com and on this forum, and the most recent package I can find is Domoticz v3.0.8153-7, with Minimum DSM verison: 5.0-4458
My Synology DS414j is on DSM 6.2.1
Can I still use that package?
Or do I have to ask mr Jumbotroll to compile a more recent version?
jumbotroll
hkuit wrote: Sunday 18 November 2018 20:41 Hi, I want to install Domoticz on my Synology DS414j.
You have to use domoticz for DSM 6.2.
I have to build a version for you 8-)
Take a look here: http://www.jadahl.com/domoticz_beta_6.2/
domoticz_comcerto2k-6.2_4.0.10215-8.spk
You have to download and manual install the comcerto2k version.
Jumbotroll
hkuit
Post by hkuit »
jumbotroll wrote: Sunday 18 November 2018 22:20 You have to use domoticz for DSM 6.2.
Take a look here: http://www.jadahl.com/domoticz_beta_6.2 ... 0215-8.spk
You're the best, it's working!
I went straight to your website to make a donation 8-)
napalmcold
Post by napalmcold »
Hi! Is there latest beta for bromollow DSM 6.1?
Or it's impossible?
Thanks in advance!
m.versteegh
Post by m.versteegh »
napalmcold wrote: Wednesday 28 November 2018 16:28 Hi! Is there latest beta for bromollow DSM 6.1?
Or it's impossible?
Thanks in advance!
I need that as well, or can I use the DSM 6.2 package? (xpenology, ds3615xs)
napalmcold
m.versteegh wrote: Wednesday 28 November 2018 18:08
Or it's impossible?
Thanks in advance!
Same setup)
jumbotroll
napalmcold wrote: Wednesday 28 November 2018 18:15
Or it's impossible?
Thanks in advance!
Same setup)
I've really stopped building domoticz beta for DSM 6.1, but I can make an exception ;)
Take a look for arch-bromolow I think that is for DS3615xs? in Domoticz Beta for DSM 6.1 menu at http://www.jadahl.com
Uploaded now..
Jumbotroll
napalmcold
jumbotroll wrote: Wednesday 28 November 2018 18:51
Same setup)
Uploaded now..
You are fantastic!
In gratitude I made a modest donation.
Many thanks!!!
m.versteegh
Service :D thnx!!!
