Checking Dreambox state
Morcegolas
Re: Checking Dreambox state
Post by Morcegolas »
Sure, here they are:
D'rMorris
Post by D'rMorris »
That's the python folder :-). Now the contents of the Screens subfolder please ;-).
Morcegolas
Sorry. ;)
kabouter
Domoticz version: 2336
Post by kabouter »
I think I found an better way to do this.
Just create an dummy...
Just use http://dreambox_ipaddress/web/powerstate?newstate=4 for the on action.
and use http://dreambox_ipaddress/web/powerstate?newstate=5 for the standby action.
You can use this on every linux machine. e.q. as Dreambox or Vuduo etc.
V3.9460(beta)
2 x RPI (remote) B 2.0 512MB
2 x RPI (remote) B+ 512MB
2 x RPI (remote) 2B 1024MB
2 x PiFace 2 - 1 x RFXtrx433E Firmware 1024 - 4 x RFLink_r48 - 3 x RFLink_r48 - RFLink Gateway
3 x Action (Impuls) - 2 x AMST606 - 9 x MySensors
free_nsc
Post by free_nsc »
Alternatively, to check current Enigma 2 status ie if it's in Standby , send:
http://e2ipaddress/web/powerstate?=
it will return:
<e2powerstate>
<e2instandby>true</e2instandby>
</e2powerstate>
I also thought of alternative ways of using dreambox for home automation mainly around sending a messages back to dreambox to notify user on certain conditions. A bit like Push notifications at the moment. E.g. doorbell rang so someone at the door (it might be even possible to switch channel to an IPCam stream) or if temperature downstairs dropped to certain level message could be produced to inform user. You could also ask for Yes/No type of question so could even turn the central heating on from the dreambox remote. Here with the documenation on message facility:
Requests:
http://dreambox/web/message?text={messa ... agetimeout}
Parameter:
messagetext=Text of Message
messagetype=Number from 0 to 3, 0= Yes/No, 1= Info, 2=Message, 3=Attention
timeout=Can be empty or the Number of seconds the Message should disappear after.
Result:
<e2message>
   <e2result>True</e2result>
   <e2resulttext>Message send to screen</e2resulttext>
</e2message>
Requests:
http://dreambox/web/messageanswer?getanswer=now
Result:
<e2message>
   <e2resulttext>Answer is (YES|NO)!</e2resulttext>
</e2message>
Very handy
PeterFleur
Domoticz version: 2.4739
Post by PeterFleur »
So if we would combine Kabouter and free_nsc posts (Because you also turn on the dreambox with the remote sometimes) how could we get an accurate script that updates Domoticz with Luo on the device Dreambox?
Peter
RaspberryPI
ZWave
RFXtrx433E
D'rMorris
Post by D'rMorris »
Morcegolas wrote:
D'rMorris wrote: ...
Then in the directory /usr/lib/enigma2/python/Screens, there is a script called Standby.py. In this script, I added (made bold what I added):
I have Standby.pyo :/ can't edit that on vi, Using Dreambox 7020HD with Openatv 4.1.
Hope you can help me.
Thanks.
Don't know if it is still of interest to you, but I found out how you can install the .py files:
- Login in via SSH to your dreambox
- Execute command: opkg install enigma2-src
- Then edit the .py file as described in this thread
- Reboot box
tuspam
Post by tuspam »
I modded a lite code for my 2 STB with enigma2.
Script check state STB and change state virtual switch in domoticz (only change state without any action). You don't need make any changes in Your enigma2 device.
Script recognize states: ON, OFF, POWER OFF
Add to crone -e for checking state every minute
*/1 * * * * /home/pi/domoticz/scripts/enigma2/check_enigma2_online.sh
Install xmlstartlet for domoticz if You need
sudo apt-get install xmlstarlet
#!/bin/bash
curl http://YOUR_stb1_IP/web/powerstate > /home/pi/domoticz/scripts/enigma2/powerstate_enigma2_living.xml
enigma2LivingStatus=`xmlstarlet sel -t -m '//e2instandby' -v . -n </home/pi/domoticz/scripts/enigma2/powerstate_enigma2_living.xml`
if [ $enigma2LivingStatus = "true" ]
then
curl 'http://domoticzIP:Port/json.htm?type=command&param=udevice&idx=142&nvalue=0&svalue=0'
    echo "$enigma2LivingStatus"
    echo enigma2 Living is in standby
elif [ $enigma2LivingStatus = "false" ]
then
curl 'http://domoticzIP:Port/json.htm?type=command&param=udevice&idx=142&nvalue=1&svalue=1'
    echo enigma2 Living is not in standby
    echo enigma2 Living not found
rm -r /home/pi/domoticz/scripts/enigma2/powerstate_enigma2_living.xml
fi
curl http://YOUR_stb1_IP/web/powerstate > /home/pi/domoticz/scripts/enigma2/powerstate_enigma2_bedroom.xml
enigma2BedroomStatus=`xmlstarlet sel -t -m '//e2instandby' -v . -n </home/pi/domoticz/scripts/enigma2/powerstate_enigma2_bedroom.xml`
if [ $enigma2BedroomStatus = "true" ]
then
curl 'http://domoticzIP:Port/json.htm?type=command&param=udevice&idx=139&nvalue=0&svalue=0'
    echo "$enigma2BedroomStatus"
    echo enigma2 Bedroom is in standby
elif [ $enigma2BedroomStatus = "false" ]
then
curl 'http://domoticzIP:Port/json.htm?type=command&param=udevice&idx=139&nvalue=1&svalue=1'
    echo enigma2 Bedroom is not in standby
    echo enigma2 Bedroom not found
rm -r /home/pi/domoticz/scripts/enigma2/powerstate_enigma2_bedroom.xml
fi
In my case stb1 got idx 142 and second one 139
Sorry for my lang
simon_rb
Post by simon_rb »
Does anyone know the command to grab the play time/status bar when playing a recording. It's the bar along the bottom so you can fast forward 30 mins or whatever really quickly.. Know what I mean?
Cheers
Derik
Post by Derik »
simon_rb
Post by simon_rb »
Can't find any reference to what I'm after
Thanks anyways
madrian
Post by madrian »
I need little help with volume control. I have a dummy slider for volume control and this lua script:
if devicechanged['VU'] then
	print('Level : '..tonumber(otherdevices_svalues['VU']))
	commandArray['OpenURL']="http://192.168.1.99/web/vol?set=set" .. otherdevices_svalues['VU']
It works like a charm, but the slider does not change when I change volume from remote control...for obvious reasons.
I thought that simple script like:
STATE=$(curl -s "http://192.168.1.99/web/vol??set=state" | xmllint --xpath '//e2volume/e2current/text()' -)
curl "192.168.1.54:8080/json.htm?type=command&param=udevice&idx=37&nvalue=1&svalue=$STATE"
(running every minutes) solves the problem, but it is not 100% good. If I change volume on remote, then when this script runs the volume OSD is showing again on the TV (because Domoticz is registering the devicechanged['VU'] and the lua script get running.
The real question is:
It is possible to change slider value, without triggering devicechanged['VU']?
zicht
Domoticz version: 2023.1+
Post by zicht »
free_nsc wrote: Sunday 01 March 2015 1:55 Alternatively, to check current Enigma 2 status ie if it's in Standby , send:
it will return:
<e2powerstate>
</e2powerstate>
Requests:
Parameter:
Result:
<e2message>
</e2message>
Requests:
Result:
<e2message>
</e2message>
Very handy
All commands can be found here if you want to construct a remote for enigma
https://dream.reichholf.net/wiki/Enigma ... cellaneous
I have created a slector switch with simple HTTP commands in place in domoticz for :
Off - turn from on to standby
On - turn on from standby
r- reboot enigma box
Chup - next channel
Chdwn - prev channel
Vup- volume up
Vdwn- volume down
Rec - Instand record only current program (and it ends after program finishes
i have created a text sensor in domoticz showing current station and program
I check with isAlive if the box is reachable --> if hard turned off from mainswitch no polling is done.
All in lua... Anything in the link above can be done in domoticz,..your imagination is the limit.
BUT it would be nice to have something like a kodi remote for enigma in domoticz !
kofec
Post by kofec »
If some want. I have created python plugin for Domoticz. Any comment are welcome.
https://github.com/kofec/Domoticz-Enigma2
NoProfesor
Post by NoProfesor »
kofec wrote: Thursday 07 December 2017 22:57 If some want. I have created python plugin for Domoticz. Any comment are welcome.
I installed it,
I added the hardware,
but i do not see device. What can be wrong?
I do not understand this as;
""First use script "tinycontrol.py" to verify if you have needed python modules e.g:
./enigma2.py 192.168.1.1
./enigma2.py -h
usage: enigma2.py [-h] [--user USER] [--password PASSWORD] IPaddress
Comunicate with Enigma2.
positional arguments:
IPaddress IP address of Enigma2
optional arguments:
-h, --help show this help message and exit
--user USER Username to login to
--password PASSWORD Password to login to""
kofec
Post by kofec »
you have to provide IP address of your Tuner: probably it is not 192.168.1.1
./enigma2.py x.x.x.x
