Nest login error
Venzent
- Domoticz version: 3.8153
Nest login error
V4.9700, RBPI 3B
Since a couple of days my domoticz seems to have troubles logging in on the nest service:
Error: Nest: Error login!
I try'd rebooting domoticz and removing and adding my nest account.
I checked the password by logging in on the webportal, and the password is correct.
Anywhere else i can look, the error is not very informative.
Venzent
Re: Nest login error
Nobody else having this problem?
I still cannot login.
Tryed the Oauth method, but that also is giving an error, not getting a valid API key...
poudenes
- Domoticz version: 3.8993
I get this error since couple of days now
2018-10-05 20:55:56.454 Error: Nest: Error getting current state!
2018-10-05 20:56:21.393 Error: Nest hardware (12) nothing received for more than 1 Minute!....
2018-10-05 20:56:22.397 Error: Restarting: Nest
2018-10-06 12:15:52.432 Error: Nest: Error getting current state!
2018-10-06 12:16:21.656 Error: Nest hardware (12) nothing received for more than 1 Minute!....
2018-10-06 12:16:22.660 Error: Restarting: Nest
2018-10-06 12:16:25.686 Error: RxQueue: cannot retrieve hardware with id: 12
2018-10-06 13:20:22.498 Error: Nest: Error getting current state!
2018-10-06 13:20:53.304 Error: Nest hardware (12) nothing received for more than 1 Minute!....
2018-10-06 13:20:54.306 Error: Restarting: Nest
2018-10-06 13:20:54.995 Error: RxQueue: cannot retrieve hardware with id: 12
2018-10-06 13:20:54.995 Error: RxQueue: cannot retrieve hardware with id: 12RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
Venzent
That seems more of a problem the nest not reporting its status, that has nothing to do with not being able to login to the Nest portal.
djksage
same issue, can you find a solution for this prioblem?
i tried to add a new user for nest, make a new nest account, use Oauth nest account and instal last domoticz beta
nothing works
nothing works
zicht
- Domoticz version: 2023.1+
Same problem, Error on login with username and password.
- I tried to create a new user,
- asked for api key , site telles me they are upgrading the systems and not accepting new requests : The api key i get is not activated.
Just for info : Nest app and website work normal with same credentials.
So for now i have no Nest integration anymore.
To me it looks like nothing to do with domoticz, but with nest messing up
Hope it is soon solved.
I have received today my nest and I have been able to setup it properly without any login errors (for now)
2018-10-15 18:30:43.088 NestOAuthAPI: Access token appears to be valid.
2018-10-15 18:30:43.089 NestOAuthAPI: Login success. Token successfully validated.
I have some issues with the F/C conversion in Domoticz, but that's for another post
regards
Miguel
regards
Miguel
Venzent
Without changing anything it started working again.....
I think Google/Nest did some things on their server side.....
rgroothuis
Any idea what the solution is to this problem?
I still get:
Has it maybe something to do with two factor authentication? When I login from the web-browser I need to enter a code that I receive via the SMS on my mobile phone.
I still get:
2018-11-18 10:11:13.674 Error: Nest: Invalid data received, or invalid username/password!
poudenes
Does somebody have using latest BETA (Version #10228) moment of writing, where all the NEST errors are solved?
rgroothuis
Just upgraded to 10228 version and I still have the same problem when I enable the Nest.poudenes wrote: Sunday 25 November 2018 3:42 Does somebody have using latest BETA (Version #10228) moment of writing, where all the NEST errors are solved?
2018-11-25 20:07:13.899 Error: Nest: Invalid data received, or invalid username/password!
rgroothuis
Found the solution
You need to select a different Nest HW type, see screenshot. Then follow the instructions stated at: https://www.domoticz.com/wiki/NestDeveloperApiKey
uermend
- Domoticz version: 4.10055
hello,
I have got the NEST Thermostat/Protect OAuth configured and get the error below:
NESTOAuthAPI: No API key available
NESTOAuthAPI: Access token missing. Will request an API key based on Product Id, Product Secret and PIN code.
NESTOAuthAPI: Preparing URL
NESTOAuthAPI: Doing POST request to URL: https://api.home.nest.com/oauth2/access_token
NESTOAuthAPI: Will now attempt to fetch access token.
Error: NESTOAuthAPI: Error getting access token: failed to fetch token from API. Responce code: 0
Error: NESTOAuthAPI: Error retrieving access token: Received access token does not appear to be valid.
copied the all codes without any spaces.
Any idea what I'm doing wrong?
Regards Sander
Regards Sander
uermend
seems to be a Domoticz issue.
when I use the NestOauth PIN in homebridge I get a new token to use in my configuration.
Within Domoticz I only get an error:
2019-05-02 22:56:43.108 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 27
2019-05-02 22:56:43.108 Error: NestOAuthAPI: Login failed: token did not validate.
and do not get a token.
