Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
Hi -
the issue with doing that is that it isn't a light - i'm guessing it doesn't behave like one in Domoticz (not really), i.e you can't set brightness, you can't change colour.
In terms of interacting with it in Google, you can still put them both into the same Room, and say "turn everything off in <room>" - if you start using the Home app, or a smart display, it won't return info, as it will be trying to return data the switch doesn't have.
Saying that, ping me your Controlicz ID, and i'll take a look :)
bueno79
Domoticz version: 4.9700
Post by bueno79 »
hi,
thx for your support, I apreciate. here is my ID : 5a4134589bf85c0e5c4e83db
schrh1
Post by schrh1 »
I have domoticz setup on a raspberry pi. Installed Controlicz on my phone. Created an account and have a subscription.
I can control the lights with my phone and Google Home.
All my devices appear.
But the blinds stay offline.
Someone any ideas?
Madgeni
Post by Madgeni »
schrh1 wrote: Friday 16 November 2018 13:29 I have domoticz setup on a raspberry pi. Installed Controlicz on my phone. Created an account and have a subscription.
Someone any ideas?
Hi - sorry, does that mean you can't control them?
schrh1
Post by schrh1 »
Madgeni wrote: Friday 16 November 2018 17:51
Someone any ideas?
I can control my lights and also temp sensors work. But my blinds i can't control. If i set the blind to on/off switch in domoticz it seems to work.
Madgeni
Post by Madgeni »
Can i ask you to try something? Can you try saying the opposite (so on for off, off for on), i wonder if you're blinds are inverted, but i've missed the logic..
dagasoft
Post by dagasoft »
By the way, I'm having problems with Google Home recognizing blinds as switches. I see in controlicz that they are identified as blinds. How can I change the device type?
Is there any way that I can force to be blinds instead of switches?
In fact they are rflink controllers switch type, but I can't tell Google home to open a blind being a switch.
Madgeni
Post by Madgeni »
Hi dagasoft - *i* know they're blinds, but Google haven't released blinds as a native type (yet). So for now it's on or off, rather than open/close
Varazir
Post by Varazir »
I have managed to setup Controlicz/Domoticz and Google Home app on my phone to work for my switches.
But my Blind shows as a switch and not as a "dimmer", is that working as designed ?
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Madgeni
Post by Madgeni »
Hi - it is yes, however you should be able to set percentages as well as on/off
Varazir
Post by Varazir »
Madgeni wrote: Monday 19 November 2018 10:36 Hi - it is yes, however you should be able to set percentages as well as on/off
Ok thanks how do I do that ?
In google home app it just say it's ON / off
Madgeni
Post by Madgeni »
Hi - functionally, the Home app needs work - if it's a switch, you can only turn on/off, despite me having applied other behaviours to certain types of switch.
Can you ask Google Home to set percentages with your blinds? "Hey google, set the blinds to 50%"
Varazir
Post by Varazir »
Madgeni wrote: Tuesday 20 November 2018 11:01 Hi - functionally, the Home app needs work - if it's a switch, you can only turn on/off, despite me having applied other behaviours to certain types of switch.
Okay then it's Home free side, thanks
m.versteegh
Post by m.versteegh »
Firewall question.... Which ports should I open for controllicz. I'm also doing geobased IP blocking, so which country should be allowed inbound access?
dagasoft
Post by dagasoft »
You should nat inbound connections to your domoticz port 8081. You can use any external port you want and then specify in controlicz config.
By the way, instead of using geoip blocking, you should only allow source IP from controlicz. You can ping controlicz.com to find static IP address.
m.versteegh wrote:Firewall question.... Which ports should I open for controllicz. I'm also doing geobased IP blocking, so which country should be allowed inbound access?
EddyG
Post by EddyG »
bueno79 wrote: Tuesday 13 November 2018 10:22 hi,
In the same room I have zwave module and a RF wall plug. The first one control one light, the second another one. So both control lights. In Google home the Zwave module is seen as a LIGHT (cool) but the RF plug is seen as a switch. However in domoticz both are lights with the right icon.
How to force google home to see the wall plug as a light ?
best regards.
I am having several zwave wall plug, with lights connected, and all are the same brand and type.
Some of them appear as lights and some of them as switches.
If I look in the domoticz database they all are identical as type "Light/Switch" (244) and Subtype "Switch" (73)
If I look in Controlicz the they all are type "Light/Switch" but in the column Google/Alexa some are "Switch" and others "Light"
Anyone any idea how to change/influence that so all can be Lights?
Madgeni
Post by Madgeni »
EddyG wrote: Thursday 22 November 2018 19:08
best regards.
Can you mail me from your Controlicz profile, and i'll take a look at why i'm interpreting them differently
EddyG
Post by EddyG »
I send you a PM.
Would it be an idea to have the user change the Google/Alexa type between Switch and Light?
Madgeni
Post by Madgeni »
I don't store your devices in Controlicz, for very good reason, so don't have the ability to inject different behaviours. Additionally, Google understands lights and switches differently, they have different behaviours.
freijn
Domoticz version: Stable
Post by freijn »
@Dutch members Google Home mini 29Euri at Albert de Gein Black Friday.
