Voltage logging for built in P1 logging script
roblom
Post by roblom »
Because in my region the grid voltage sometimes gets so high (around 250v) the inverter of my solar panels shuts off.
So I was wondering why this voltage isn't being logged by the built in P1 logger script in Domoticz? Hopefully someone can add this to the script.
roblom
Re: Voltage logging for built in P1 logging script
Post by roblom »
Nobody?
roblom
Post by roblom »
Still nobody knows?
roblom wrote: Monday 22 April 2019 11:25 Still nobody knows?
Not sure to what script you refer. The P1 readout is coded in the core domoticz program.
roblom
Post by roblom »
That's the script I meant, but in the mean time I found out that my meter is an older one which strange enough doesn't Log the voltage.
assenzuid
Post by assenzuid »
Interesting, I have only Energy, Gas, Usage L1 and deliver L1. No grid voltage.
Any idea how to show the Grid Voltage?
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Doubt that grid Voltage is included in the standard P1-protocol.
At least not contained in this protocol description
If not available from the Smart Meter's P1 port, you have to find another data-source.
Often PV-inverters and PV-Loggers have this info as part of the package at their data-interface.
Also available from most kWh-meters with RS485-interface.
roblom
Post by roblom »
Toulon7559 wrote:Doubt that grid Voltage is included in the standard P1-protocol.
That's probably because that's the document for the old meters.
Here is a more recent version
https://www.netbeheernederland.nl/_uplo ... fce1f1.pdf
The net voltage is becoming more important because a high net voltage is an indication of an overloaded network. That fact isn't new so I found it strange that they didn't thought of it before to log this.
assenzuid
Post by assenzuid »
I already use one of my UPS as data-source, but closer to the source always better.
Attached a sample of my UPS and the voltage recorded.
roblom wrote: Monday 20 May 2019 7:16 That's the script I meant, but in the mean time I found out that my meter is an older one which strange enough doesn't Log the voltage.
In the P1 source you will see that that the voltage handling is already in.
Unfortunate voltage is only included in DSMRv5 and my meter is of type DSMRv4.2.
Confirmed by reading the meter with
cu -l /dev/ttyUSB-P1 -s 115200 --parity=none -E q
1-3:0.2.8(42)
0-0:1.0.0(190520225948S)
0-0:96.1.1(4530303235313030303234363334313135)
1-0:1.8.1(007535.446*kWh)
1-0:1.8.2(005470.879*kWh)
1-0:2.8.1(003243.875*kWh)
1-0:2.8.2(007359.075*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.490*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00004)
1-0:99.97.0(1)(0-0:96.7.19)(000101000001W)(2147483647*s)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(004*A)
1-0:21.7.0(00.490*kW)
1-0:22.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303032333430313938393636393135)
0-1:24.2.1(190520220000S)(02723.313*m3)
