I got a new Wifi module and everything is working again. Guess if was bricked somehow.
So installed last Beta 2 days ago and started testing again.
The Osram Smart+ wall plug work fine. Is detected very fast and works flawless.
The Ikea Leds take long time to be detected but get there eventually.
They are pretty slow in responding. Sometimes it takes minutes before action is taken on a on/off command. This happens even if Zigate and Led are within 1 mtr distance of each other. Also think the Leds don't send status back to Zigate.
The Aquara wall switch (the flat battery driven one) is detected wrongly I think since Domoticz thinks it is a XCube and it creates 2 devices.
- Aquarabutton.png (27.52 KiB) Viewed 2600 times
Also pressing a button on the switch creates a python error in the log.
The log is attached.
The Ikea Wall plug is not detected. Couldn't find if it was announcing itself but tried to grab it in the log I attached.
The Aquara motion sensor was detected fine and works fine too. Only drawback is that it only sends LUX data when motion is detected. Would like to be able to pull that info now and then to switch on light on low light conditions.
