Update daily gas usage
Joep123
Post by Joep123 »
I use script below to update a custom sensor to monitor my daily gas usage based on degree days. It works fine.
Actually I want to use a gas sensor (or a RFX sensor). I tried to update these sensors with
domoticz.devices('Gas per graaddag').updateGas(GasUsageperDegreesday)
but then the gas counter will be updated in stead of the daily usage.
Can anyone help me to update the daily usage?
          on   = { timer    = { "at 23:58"}},
  execute = function(domoticz)
        local Date = domoticz.time.year..domoticz.time.month..domoticz.time.day
        local meantempOutside = domoticz.devices('Gemiddelde Temp buiten').temperature
        local baseTemp = 18
        local factor = 1
        local degreesday = baseTemp - meantempOutside
        if (domoticz.time.month >= 4 and domoticz.time.month <= 9) then factor = 0.8 end
        if (domoticz.time.month >= 11 or domoticz.time.month <= 2) then factor = 1.1 end
        degreesdays = degreesday * factor
        local GasUsage = domoticz.devices('Gas').counterToday
        local GasUsageperDegreesday = domoticz.round((GasUsage / degreesdays),3)
        if (degreesday <= 0) then
            degreesdays = 0
            GasUsageperDegreesday = 0
        domoticz.log('Gemiddelde temperatuur buiten (laatste 24u): '..meantempOutside)
        domoticz.log('Gasverbruik vandaag: '..GasUsage..' m3')
        domoticz.log('Aantal graaddagen: '..degreesdays)
        domoticz.log('Gasverbruik: '..GasUsageperDegreesday..' m3 per graaddag')
        domoticz.devices('Gas per graaddag').updateCustomSensor(GasUsageperDegreesday)
Re: Update daily gas usage
Joep123 wrote: Wednesday 31 October 2018 18:47 I use script below to update a custom sensor to monitor my daily gas usage based on degree days. It works fine.
@Joep123, the daily usage of a domoticz gas sensor is a calculated value. In the database only the total is stored and domoticz "knows" the total amount at 0:00 (from another table)
select ID,Name,sValue from deviceStatus where id = 36;
ID|Name|sValue
36|Gas|2113123
select * from meter_calendar where deviceRowid=36 and Date=date("now","-1 day") ;
DeviceRowID|Value|Counter|Date
36|3427|2109548|2018-10-30
2113123
2109548 -
3575
Gas meter (36)
Gas meter (36)
So trying to store GasUsageperDegreesday in a gas sensor device is not going to give you the information you want to see.
Joep123
Post by Joep123 »
Thanks for your clear post Waaren.
I guess a RFX Meter (type gas) will be the same?
I'm looking for a nice way the store GasUsageperDegreesday into a chart (like gas, energy).
hendrikenrenny
Post by hendrikenrenny »
The script is running perfectly and everyday I get the m3/graaddag. I used the script on ehoco.nl.
However, the dummy sensor m3/graaddag doesnot generate a report as you can see with every sensor (eg electricity), where it is reported per day/month the m3/graaddag.
Does anybody know how-to do that?
Second question: the sensor does produce a graph, but it is a line graph where I would prefer a bar. Do you have suggestions how to change that?
Thanks,
