device title color
jackslayter
- Domoticz version: stable
device title color
Hi, I seen which when I don't use a device during period the title become red (see attached)
its possible to put manually by lua/json the desired color ?
e.g. : for visual notice
thank you
thank you
- color.png (9.77 KiB) Viewed 7953 times
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
- gizmocuz
Re: device title color
Nope, because we have different colors for normal, battery problem, device problem, protected device, and so on.
If you overrule this color, then you wont notice the above
jackslayter
ok , and it is possible to force the for example a "device problem" for not force debug colors ?
or maybe create new icons (red orange green) can you control in lua or new virtual device with icons?
- gizmocuz
yes, but this has to be in the database (json udevice)
if the device is received again, and there is no problem, the color will be normal
jackslayter
ok so with json command I can change colour ?
what is the parameter ?
juankar
- Domoticz version: 4.
Hello
And which is the key to understand the meaning of colors?
I can't find it.
thanks
I can't find it.
thanks
jackslayter
yellow = low battery
red = no data received during +3 days
other ?
other ?
Last edited by jackslayter on Saturday 14 March 2015 16:06, edited 1 time in total.
juankar
Thanks,
And I get red color in a PIR sensor with two days without temperature report, although it reports presence and lux every few hours.
jackslayter
'blue'
-> normal 'dark blue'
-> Device who is Protected 'yellow'
-> low battery
-> low battery
jackslayter
'red'
-> no data received during +3 days
gcoupe
- Domoticz version: v4.10717
jackslayter - thanks for documenting this so far.gizmocuz wrote:...we have different colors for normal, battery problem, device problem, protected device, and so on.
I note that Gizmocuz says "and so on" in his reply. That would seem to indicate that there are further colours to be discovered and documented. Gizmocuz, is this in fact the case? Thanks.
ramesses
- Domoticz version: 3.8755
I have Vision ZP3102 PIR Motion Sensor and it works great, but the title bar is read. See the picture (right - "Pokoj Alarm..")
There are several of them in my Domoticz and all are with red title bar. Can somebody explane to me why? Battery is ok and sensor works correctly.
Domoticz on RaZberry, OZW 1.4-2713
Aeotec MultiSensor 6, Aeotec LED Bulb, Vision ZD2102 Door/Window Sensor, Vision ZP3102 PIR Motion Sensor, D-Link Siren DCH-Z510, Fibaro Smoke Sensor FGSD002, Aeotec Key Fob, Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer
ramesses
I solved the issue with red title bar of my Vision ZP3102 PIR motion sensor "Pokoj alarm...". I choose "another row" from Devices list to indicate PIR's motion which is not red in Dashboard.
- luberth
- Domoticz version: 4.9700
Hello
Do not realy get it
device status color turns red on devicetitlebar of dummy thermostat setting
why its only a setpoint?
another thing
is it possible to set/change the temperature setting of dummy thermostat setting from the floorplan
http://test:[email protected]:8080/#/Floorplans
ok as user test it is not possible
but as admin i also can not change temp setting on floorplan
greet luberth
Do not realy get it
another thing
greet luberth
- bewo
- Domoticz version: 2021.1
Yes. If there is no new entry in the timeout you configured in your settings, then the device turns red.luberth wrote: Tuesday 06 November 2018 9:27 device status color turns red on devicetitlebar of dummy thermostat setting
There is no option to deactivate this feature for dummy devices.
If you don't want a red bar in your devices you can keep the setpoint active with an short lua script. Not a beautiful way, but it works without any problems for years now...
If it's useful for somebody:
-- Script for "holding active" an dummy setpoint
-- After the configured timeout (in settings) an dummy setpoint will turn red, if there is no new entry.
-- This is only an optical problem, the device is working probably. But i don't like an red bar in my devices,
-- this sript renews the devices before it is going red. My setted timeout are 60 minutes, so if choosen
-- 3500 seconds as the renew-time.
-- So you have to chance the name of the dummy device, and perhaps the time in seconds.
-- Date: 06.11.2018 -- Domoticz forum -- bewo
-- Here set your setpoint:
local thermostat = 'Thermostat Heizautomatik'
function timedifference(timestamp)
y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
difference = os.difftime(os.time(), os.time{year=y, month=m, day=d, hour=H, min=M, sec=S})
return difference
local function updatenum(dev, value1)
local cmd = string.format("%d|0|%d", otherdevices_idx[dev], value1)
table.insert (commandArray, { ['UpdateDevice'] = cmd } )
for deviceName,deviceValue in pairs(otherdevices) do
if (deviceName== thermostat ) then
if tonumber(deviceValue) > 0 then
-- And here you have to set a time in seconds shorter than your timeout.
if timedifference(otherdevices_lastupdate[thermostat]) > 3500
then
print ("The setpoint was renewed with the same temperature.")
updatenum(thermostat, tonumber(otherdevices[thermostat]) + 0)
return commandArrayIndividual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
- luberth
Thank you bewo
anybody has an answer to the second question?
another thing
greet luberth
another thing
greet luberth
- luberth
did code it a litle different but does the same
another thing
greet luberth
now=os.date("*t")
-- domoticz lua timed script to prevent red titlebars on dummy thermostat
-- http://test:[email protected]:8080/#/Floorplans
-- change % 1 to your desired reload minutes
if now.min % 1 == 0 then
local SetTempVent = tonumber(otherdevices_svalues['Ventilate Living start >']) -- get setting
commandArray[#commandArray+1] = {['UpdateDevice']='32|1|'..SetTempVent} -- set setting wih get setting
print("SetTemp ventilator updated to prevent red titlebars "..SetTempVent) -- print in log
local SetTempPump = tonumber(otherdevices_svalues['cv pomp setting pomp aanbij Berkhout<']) -- get setting
commandArray[#commandArray+1] = {['UpdateDevice']='31|1|'..SetTempPump} -- set setting wih get setting
print("SetTempPump updated to prevent red titlebars "..SetTempPump) -- print in log
another thing
greet luberth
- andrehj
- Domoticz version: 2026.4
Thanks for this tip! I also have sensors updated only once a day and just changed the setting to 1440!andreazan wrote: Thursday 23 May 2019 21:50 I have sensors that are updated once /day.
In a fresh installation of Domoticz 4.10717, the default in
settings -> Other settings -> Sensor Timeout is 60 minutes, not 3 days !
So, to consider acceptable a full day delay for an update and avoid the device title color to become red,
you should set this value to 60*24 = 1440.
