Timer for evotouch
TheChief
Domoticz version: V4.9700
Timer for evotouch
Post by TheChief »
If installed a Honeywell Round Connected Modulation on my domoticz and raspberry. If I want to make a timer I can only choose on or off, is it possible to put in the temperature? Example;
Dayly 0800 20,5 degrees
Dayly 2200 15,5 degrees
TheChiefImage
Verstuurd vanaf mijn SM-N950F met Tapatalk
Re: Timer for evotouch
TheChief wrote: Saturday 27 October 2018 14:42 If installed a Honeywell Round touch on my domoticz and raspberry. If I want to make a timer I can only choose on or off, is it possible to put in the temperature? Example;
It is not possible to do this on the timer screen. As a workaround I created this dzVents script that will take a string from the description field and process the setpoint accordingly.
Example on how to enter the string in the description field
Further description is in the comments.
-- EvoSchedule
 this script will update setpoints based on schedules entered in the description field of (Evo) setpoint devices.
 schedule should be formatted like:
  schedule:{"saturday":{"08:10":"22.3","16:50":"27.2"},"wednesday":{"08:05":"22","15:40":"23"},"weekend":{"17:25":"41.33"}}
    for valid days look in convertKey function (keys are case sensitive)
    time can be entered with a granularity of 5 minutes. If that is not granular enough,
    the on = { timer string below must be changed to "every minute)"
    your setpointDevice(s) are to be entered in the variable allSetpoints
    on      =   {   timer   =     { "every 5 minutes"  }},
    logging =   {   level      =   domoticz.LOG_DEBUG,
                    marker     =   "EvoSchedule"    },
    execute = function(dz)
        local allSetpoints         = {"EvoTouch","EvoTouch2","Zolder"}  -- all evo devices (minimal 1)
        local function convertKey(key)
            if          key == "allDays" or key == "alleDagen" then return true end
            if          key == "weekend" then return dz.time.matchesRule("on sat,sun")
            elseif      key == "workday"    or key == "werkdag"     then return dz.time.matchesRule("on mon,tue,wed,thu,fri")
            elseif      key == "sunday"     or key == "zondag"      then return dz.time.matchesRule("on sun")
            elseif      key == "saturday"   or key == "zaterdag"    then return dz.time.matchesRule("on sat")
            elseif      key == "monday"     or key == "maandag"     then return dz.time.matchesRule("on mon")
            elseif      key == "tuesday"    or key == "dinsdag"     then return dz.time.matchesRule("on tue")
            elseif      key == "wednesday"  or key == "woensdag"    then return dz.time.matchesRule("on wed")
            elseif      key == "thursday"   or key == "donderdag"   then return dz.time.matchesRule("on thu")
            elseif      key == "friday"     or key == "vrijdag"     then return dz.time.matchesRule("on fri")
            return true
        local function processAllSetpoints()
            for i=1,#allSetpoints do                                 -- walk over all declared setPoint devices
                local mySetpoint = dz.devices(allSetpoints[i])
                -- string.find(mySetpoint.description,"schedule:(%d+)"
                dz.log("Looking at device " .. mySetpoint.name .. ". This device is type: " .. mySetpoint.deviceType .. ", subtype: " .. mySetpoint.deviceSubType,dz.LOG_DEBUG)
                if (mySetpoint.description):find("schedule:") then
                    local _,_,schedule =  (mySetpoint.description):find("schedule:(.*)")
                    dz.log(schedule,dz.LOG_DEBUG)
                    local control = dz.utils.fromJSON(schedule)
                    for day,setpoints in pairs(control) do
                        local msg = "evaluating " .. day
                        if convertKey(day) then
                             dz.log(msg .. " <<== true",dz.LOG_DEBUG)
                            for clockTime,setpoint in pairs(setpoints) do
                                msg = "evaluating setpoint of " .. mySetpoint.name .. " on " .. day ..  " at " .. clockTime .. " to " .. setpoint .. " degrees"
                                if dz.time.matchesRule("at " .. clockTime) then
                                    dz.log(msg .. " <<== will be set now",dz.LOG_DEBUG)
                                    mySetpoint.updateSetPoint(setpoint,dz.EVOHOME_MODE_PERMANENT_OVERRIDE)
                                    -- 2nd parm necessary for evo Devices
                                    -- and will be ignored by standard setPoint devices
                                    dz.log(msg .. " <<== NOT now",dz.LOG_DEBUG)
                            dz.log(msg .. " <<== false",dz.LOG_DEBUG)
                    dz.log("Device " .. mySetpoint.name .. " does not have a schedule in description field",dz.LOG_DEBUG)
TheChief
Post by TheChief »
Hello waren,
Thanks for your reply. If I try editing my devices I can't find the discription box like in your screenshot??
If I go to devices and try to edit the 3 devices that are visible after adding the "Evihome via web api" hardware are the ones in this screenshot......
TheChief
TheChief wrote: Saturday 27 October 2018 23:41 ... If I try editing my devices I can't find the discription box like in your screenshot??
You have to use the edit button on your device on the temperature or utility tab
http://domoticz_IP:domoticz_PORT/#/Temperature or http://domoticz_IP:domoticz_PORT/#/Utility
TheChief
Post by TheChief »
Found it.... Thanks.... And sorry... Just new and testing everything. Just edit your script what's the best way for me and paste it in de discription and it must work? Or do I need to do more?
TheChief wrote: Saturday 27 October 2018 23:50 Found it.... Thanks.... And sorry... Just new and testing everything. Just edit your script what's the best way for me and paste it in de discription and it must work? Or do I need to do more?
Yes. Just edit the line
in such a way that it contains all setpoint devices that you want to control with this script and in all these devices put the string
in the description field (modified to suit your requirements )
TheChief
Post by TheChief »
Do i need to paste te complete script? i tried it but it dit not work......
Here is the complete code and edited by myself whats the best for me....
Nothing happend at 09:30 en 09:35 today....
-- EvoSchedule
  schedule:{"sunday":{"09:30":"21.5”,”09:35”:”18.5”},”wednesday":{"08:05":"22","15:40":"23"}}
        local allSetpoints         = {"Thuis: Thermostat","EvoTouch woonkamer 3","Thuis: EvoTouch"}  -- all evo devices (minimal 1)
            return true
TheChief wrote: Sunday 28 October 2018 11:22 Do i need to paste te complete script? i tried it but it dit not work......
I sent you a PM. Best to discuss further there. No need to bather other forum members until solved. OK ?
