I have a question how to establish the following with dzVents.
I have
Switch with IDX=1
Voltage indicator with IDX=2
Voltage indicator with IDX=3
When Switch with IDX=1 is "ON" then copy the measured voltage from IDX=2 to the voltage indicator with IDX=3
Can some help me with this?
Analog measurement
- waaren
Re: Analog measurement
Do you want to copy the value from 2 to 3 only when the switch state change from Off to On or do you want to copy from 2 to 3 every x minutes for as long as the switch state is On ?Knibor wrote: Saturday 27 October 2018 9:46 When Switch with IDX=1 is "ON" then copy the measured voltage from IDX=2 to the voltage indicator with IDX=3
Knibor
- Domoticz version: Stable
Thanks for you reply, I want copy the value from 2 to 3 every x seconds for as long as the switch state is On ?
And when the Switch is Off the last On value keeps in IDX 3
- waaren
This script is triggered on any update to the voltage sensor with IDX 2 and copy the voltage value to (virtual) voltage sensor with IDX 3 when Switch is On and values in the voltage sensors are not already equal.Knibor wrote: Saturday 27 October 2018 12:42 I want copy the value from 2 to 3 every x seconds for as long as the switch state is On ?
-- voltageCopy
on = { devices = { 2 }}, -- Master voltage sensor
logging = { level = domoticz.LOG_DEBUG, -- commment these 2 lines when script execute without any issues
marker = "voltageCopy" },
execute = function(dz, item) -- item is the Master voltage sensot
local slaveVoltageSensor = dz.devices(3)
local voltageCopySwitch = dz.devices(1)
if voltageCopySwitch.state == "On" then
if slaveVoltageSensor.voltage ~= item.voltage then
dz.log("Script is triggered by " .. item.name .. "; new voltage (" .. item.voltage .. ") will be copied to " .. slave.name,dz.LOG_DEBUG)
slaveVoltageSensor.updateVoltage(item.voltage) - the actual copy
dz.log("Script is triggered by " .. item.name .. "; voltage (" .. item.voltage .. ") will NOT be copied to " .. slave.name .. "(voltages are equal)",dz.LOG_DEBUG)
dz.log("Script is triggered by " .. item.name .. "; voltage (" .. item.voltage .. ") will NOT be copied to " .. slave.name .. "(control switch is Off)",dz.LOG_DEBUG)
Knibor
Hi, thanks for the code.
I tried this code with the actual IDX from my Domoticz system, but until now no succes.
Domoticz says there is an Error in line ...slaveVoltageSensor.updateVoltage(item.voltage) - the actual copy
I tried to delete this part. The error was gone but, I don't know should i delete this part? When I delete this part, still no succes.
Here is my actual code
- Schermafbeelding 2018-10-27 om 16.26.57.png (320.7 KiB) Viewed 825 times
- waaren
the part "- the actual copy" is missing 1 "-"Knibor wrote: Saturday 27 October 2018 16:27 Domoticz says there is an Error in line ...slaveVoltageSensor.updateVoltage(item.voltage) - the actual copy
the line should have been
slaveVoltageSensor.updateVoltage(item.voltage) -- the actual copy To be complete I post the corrected script.
-- voltageCopy
Knibor
I tried this latest code with a fresh installed Domoticz, so only this code and the new IDX
IDX 14 is the master voltage sensor, were I can read now the value 80.
IDX 13 is the slave sensor, and I read now the value "0".
IDX 15 is the voltage Switch and I with it on and off serval times. Also tried when the switch is on change the value off IDX 14 master voltage.
But no copy from IDX 14 to IDX15.
Do I something wrong?
Here is my log
Here is my log
- Schermafbeelding 2018-10-27 om 20.12.55.png (34.94 KiB) Viewed 797 times
- Schermafbeelding 2018-10-27 om 20.12.27.png (62.5 KiB) Viewed 797 times
- Schermafbeelding 2018-10-27 om 20.11.45.png (390.75 KiB) Viewed 797 times
- waaren
As you described it, the copy should go from 14 to 13Knibor wrote: Saturday 27 October 2018 20:14 Hi,
Here is my log
Can you show the script how it is now and at least show the log with the debug lines of the script? Preferable in textformat within "[ code]" "[ \code]" tags
Knibor
Hi, it works now
I don't now why? I only changed the file name from the script from Sample/Hold to SampleHold.
Suddenly it works!
Thank you very much for the support.
I have made a battery cell monitor. It reads the battery voltage value with Espeasy mini D1and send it (wireless) to Domoticz. The Espeasy is connected with a multiplexer and can measure 16 channels.
I send with Domotics a binary code for battery cell 1(switch) to cell 13 with an interval of 15 seconds. So when Cell 1 is measured it will go to this Sample/Hold script.....and so on until to cell 13. Now I can use 13 voltage indicators in Domoticz with the actual value.
Robin
Suddenly it works!
Robin
