dashticz: Important Request
edge
Re: IMPORTANT REQUEST!!!
Post by edge »
Grrrr can't get access-control-allow-origin header working with nginx. Anyone who can help me with that one? :)
Lokonli
Post by Lokonli »
poudenes wrote: Thursday 25 October 2018 9:41
gielie wrote: Thursday 25 October 2018 9:40
robgeerts wrote: Wednesday 24 October 2018 21:15 Wow had to read back a lot and good to see that most off you already have it working again!!
Nope, i cant get it to work.
I started from scratch, installed dashticz in var/www/html (instead of domoticz/www) with all the necessary dependencies.
I also tried to host the files on my synology and redirected to that address but still no luck.
Can someone make a clear tutorial how to change this.
And one question, if i change the icall/garbage file wont this be a problem with the next git pull update?
See my post 2 up... For me it work now. Only the custom icons part is gone now. But rest is working
The fontawesome update some time ago results in different names for the icons to be used.
The new name for fa-window-close is:
'far fa-window-close' for a regular icon.
or
'fas fa-window-close' for a solid icon.
On fontawesome.com you can find the correct names. Sometimes only fas or far is supported (not both). Sometimes there is a small change in the name as well.
poudenes
Domoticz version: 3.8993
Post by poudenes »
gielie wrote: Thursday 25 October 2018 9:40 Nope, i cant get it to work.
or
I will check it. As far as I could see this morning some where same. But will look again. Thanks!
Verzonden vanaf mijn iPhone met Tapatalk Pro
EastXIII
Post by EastXIII »
edge wrote:Grrrr can't get access-control-allow-origin header working with nginx. Anyone who can help me with that one? :)
Same here. Man I need to learn a lot...
gielie
Domoticz version: latest β
Post by gielie »
That is only the apache/server part and i'm sure this is working fine because i run other web applications using apache.
im sure It is the dashticz part that need a change which i cant get right.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
stuffer
Domoticz version: 3.6367
Post by stuffer »
Lokonli wrote: Wednesday 24 October 2018 22:14
stuffer wrote: Wednesday 24 October 2018 21:41
@robgeerts
Almost :-)
First I want to thank you for the project. A crate of beer is on his way when I get this working :-) (or at the Jumbo 1,5 for the price for one )
What I did on my Ubuntu 16 machine for domoticz:
apt install apache2
apt-get install python-software-properties
add-apt-repository ppa:ondrej/php
apt-get update
apt-get install php7.2
apt-get install php7.2-curl
service apache2 restart
nano /home/pi/domoticz/www/dashboard/js/calendar.js
//\\changed://\\
if (settings['calendar_parse_localy']){
curUrl = './vendor/dashticz/ical/?time=' + cache + '&url=' + curUrl;
} else {
curUrl = 'https://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
//\\to//\\
change curUrl = 'https://MYOWNDOMOTICZIP/ical/?time=' + cache + '&url=' + curUrl;
and add this in my CONFIG.js
config['calendar_parse_localy']=true;
With the result that the dutch tv section is working again. Only my 2 iCals are still not responding. (Google and RMN https://inzamelschema.rmn.nl/ical/0356200000014977)
What is the best way to look at this?
The CONFIG.js setting should be:
config['calendar_parse_localy']=1;
The change you made in calendar.js is not needed (and incorrect) so better to revert that one.
Ok, I reverted the calendar.js and changed: config['calendar_parse_localy']=true; --> config['calendar_parse_localy']=1;
Still no luck. Where i can start to debug this? It feels that i am pretty close but I don't no where to start searching.
(and I hope to create an how to for other users)
Lokonli
Post by Lokonli »
stuffer wrote: Thursday 25 October 2018 21:06 Ok, I reverted the calendar.js and changed: config['calendar_parse_localy']=true; --> config['calendar_parse_localy']=1;
For the debugging: press F12 in Chrome, and look for errors in the console.
poudenes
Post by poudenes »
gielie wrote: Thursday 25 October 2018 14:56
I didn't change anything inside the Dashticz code. Only add
to CONFIG.js
gielie
Post by gielie »
poudenes wrote: Friday 26 October 2018 8:14
to CONFIG.js
And that doesn’t make sense because it should be 1 or 0 instead of false/true.
But again am sure my server side is working fine, it’s the dashticz part I can’t figure out why it’s not working.
Looking at all the answers and solutions here there is more then 1 so if someone could update the wiki so everybody can get it to work again cause if I don’t fix this my wife’s gonna pull of the tablet off the wall and make me place back the normals thermostat back.
- FIBARO FGS223
- Toon
- Kodi Media Server
poudenes
Post by poudenes »
Only problem i still have is the Weather icons. Load very very slow in latest Dasthicz version.
jake
Post by jake »
poudenes wrote:Only problem i still have is the Weather icons. Load very very slow in latest Dasthicz version.
Yes, I experience the same. It would be nice if the weather part did not have to reload every time. How much does weather change in forecast? Not too much.
I wonder actually what the default 5 minute reload is good for? Will the calendar not update without that? In that case it would be awesome if only that block is reloaded.
gielie
Post by gielie »
poudenes wrote: Friday 26 October 2018 11:09 Only problem i still have is the Weather icons. Load very very slow in latest Dasthicz version.
Same problem, very very slow, not workable
- FIBARO FGS223
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
gielie wrote: Friday 26 October 2018 12:06
I cannot reproduce the problem. Which weather provider are you using? WU or OWM? In case of WU, try with OWM. WU is using cors-anywhere.herokuapp.com, which might introduce some delay.
You cannot use WU and OWM simultaneously.
In CONFIG.js add:
config['owm_api'] = 'your OpenWeatherMap key';
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = '';
config['owm_country'] = 'de';
then replace in your block 'weather' with 'weather_owm' and 'currentweather_big' with ' currentweather_big_owm'
EdwinK
Post by EdwinK »
No problems with OWM.
Derik
Post by Derik »
Is there perhaps someone that have a simple how to ...
To install all the nice stuf from rob on my RPi, r my Slave rpi..
I see servel solutions..
Only a simple one..:-)
Thanks!!
jake
Post by jake »
Lokonli wrote: Friday 26 October 2018 19:42 I cannot reproduce the problem. Which weather provider are you using? WU or OWM? In case of WU, try with OWM. WU is using cors-anywhere.herokuapp.com, which might introduce some delay.
In CONFIG.js add:
This makes sense. When the icons won't load and I have the browser in debugging mode, I see the following error:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource
at https://cors-anywhere.herokuapp.com/https://api.wunderground.com/api/1xxxxxxxxxxxxxxxxxd/forecast10day/q/NL/Dxxxxxxx.json.
(Reason: CORS header ‘Access-Control-Allow-Origin’ missing).[Learn More]
I once tried the OWM, but the layout is completely different, it shows a different type of forecast, I believe for the next coming 5x 3 hours or something like that? I like the 4 daily forecast from WU. However, we know that they will cancel their service as of beginning of 2019.
btw, a similar error shows up sometimes for the 'longfonds' block, it also has to do with the 'https://cors-anywhere.herokuapp.com'
jake
Post by jake »
Lokonli wrote: Thursday 25 October 2018 8:07 HVC is part of 'afvalstromen'. For afvalstromen all code already is implemented, except for HVC. I'll make the fix this weekend.
Thanks for fixing. I was happy to see the dates with their respective colors back. However, when I looked at the type of garbage being picked up next (Restafval: maandag), I realized that it is not correct. This was last Monday and not next Monday. Next Monday it will be GFT instead. Number 2 and 3 on my list (I limited it to 3) are correct for next week Thursday, (Papier and Plastic).
29-10-18: Code is updated by Lokonli and HVC works now as expected!
I updated the Dashticz wiki page with the new situation for the Module - Garbage collector. Please check my changes. I also put some comments in the Module - Calendar. I wonder if we still yes/no need the config.js parameter: config['calendar_parse_localy']=true;
Please also check / modify / add that section as well.
b00n
Post by b00n »
EastXIII wrote: Thursday 25 October 2018 12:30
Try this:
The easy way is to just add the extension in google chrome to allow access using CORS.
(https://chrome.google.com/webstore/deta ... ihlkkiljbi...)
Just enable this extension whenever you want allow access to no 'access-control-allow-origin'header request.
Freekers
Post by Freekers »
Are you still looking for webhosting? If so, what specs are you looking for? I might be able to help you out depending on your requirements.
Lokonli
Post by Lokonli »
jake wrote: Friday 26 October 2018 22:03
Thanks for updating the wiki! I've added a few garbage companies that are supported as well already.
The calendar_parse_localy setting is indeed not needed/not used anymore.
