dashticz: Important Request
- Thuis
Re: IMPORTANT REQUEST!!!
Im trying to instal Rasbian on a Xeon N270 to see if there is any difference when i use linux, so far, the installer is busy, installing it to the hard drive...
On windows no luck yet, but i think, luck has nothing to do with it :-p
I Love Domoticz ! And the community around it :-)
Can you please specify where to put this in Apache2? I get this error all the time. Header module enabled and added this to apache2.conflightmanster wrote: ↑Friday 19 October 2018 13:39
also add:
<IfModule mod_headers.c>
Header set Access-Control-Allow-Origin "*"
</IfModule>
to your webserver config if you get Access-Control_allow-origin error
Kind regards
LM
But I still get the mentioned error. I'm stuck!
In Linux you can change the php version for apache.
Login with ssh to your machine and :
sudo a2dismod php5.6
sudo a2enmod php7.2
sudo apt-get install php7.2-curl
sudo service apache2 restart
sudo a2enmod php7.2
@EastXII
I have set it in my virtual host config in /etc/apache2/sites-enabled/domoticz.sonnehoek.nl.conf
<VirtualHost 192.168.0.20:880>
# Always set these headers.
Header always set Access-Control-Allow-Origin "*"
DocumentRoot /var/www/dashticz_v2
ServerName domoticz.sonnehoek.nl
<Directory "/var/www/dashticz_v2">
allow from all
Options Indexes FollowSymLinks
Require all granted
</Directory>
</VirtualHost>
allow from all
Require all granted
</Directory>
</VirtualHost>
Thanks for all your tips and tricks guys. Over time my system must have become messy. I decided to wipe out everything that 'smelled' like PHP and start over.
To delete all PHP packages (I had 5.6, 7.0 and 7.2 packages installed)
Install PHP 7.2:
I followed the instructions (for the PHP7.2 part) on this website
After a restart of the apache2 webserver the agenda came back to life.
The garbage is still not working. To outrule possible not updated HVC code, I decided to use the postal code/house number in the file garbage.js from the 'mijnafvalwijzer' and add those to my CONFIG.js. I double checked the combination on the mijnafvalwijzer website and the postal code / house number is a valid one.
Unfortunately it doesn't help. The block still shows 'loading...'
Adaption on garbage.js:
sudo apt-get purge `dpkg -l | grep php| awk '{print $2}' |tr "\n" " "`
$.getJSON(getPrefixUrl() + 'http://127.0.0.1/beta2/dashboard/vendor/dashticz/afval/?service='+service+'&sub='+subservice+'&zipcode=' + address.zipcode + '&nr=' + address.housenumber + '&t=' + address.housenumberSuffix, function (data) {
If agenda is working then php is working.
I guess the url is not correct.
Press F12 in the browser. Probably there is an error.
What is the output in your browser if you go to: http://127.0.0.1/beta2/dashboard/vendor/dashticz/afval/
(should be: [])
If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:
(should be: [])
$.getJSON('./vendor/dashticz/afval/?service='+service+'&sub='+subservice+'&zipcode=' + address.zipcode + '&nr=' + address.housenumber + '&t=' + address.housenumberSuffix, function (data) {
- Domoticz version: 3.8993
skip. ignore this post
I'm booking progress now: instead of that the garbage block tells me 'laden...' it shows 'geen gegevens gevonden'.Lokonli wrote: If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:Code: Select all
Once again I changed company names /address (deafvalapp with corresponding and working address), but with the same result.
I loaded dashticz on my desktop to check for the error log in the browser. This is what it gives me:
- Spoiler: show
- EdwinK
- Domoticz version: BETA
Double check you have the correct settings in CONFIG.js:jake wrote: ↑Wednesday 24 October 2018 14:47I'm booking progress now: instead of that the garbage block tells me 'laden...' it shows 'geen gegevens gevonden'.Lokonli wrote: If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:Code: Select all
I loaded dashticz on my desktop to check for the error log in the browser. This is what it gives me:Doesn't seem related to garbage, but probably to the use of 'pihole' that blocks advertisements.
- Spoiler: show
config['garbage_company'] = 'deafvalapp';
config['garbage_icalurl'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '5692VG';
config['garbage_street'] = '0';
config['garbage_housenumber'] = '33';
- Domoticz version: 3.7067
Wow had to read back a lot and good to see that most off you already have it working again!!
- Domoticz version: 3.6367
@robgeerts
Almost
First I want to thank you for the project. A crate of beer is on his way when I get this working
What I did on my Ubuntu 16 machine for domoticz:
apt install apache2
apt-get install python-software-properties
add-apt-repository ppa:ondrej/php
apt-get update
nano /home/pi/domoticz/www/dashboard/js/calendar.js
//\\changed://\\
if (settings['calendar_parse_localy']){
curUrl = './vendor/dashticz/ical/?time=' + cache + '&url=' + curUrl;
} else {
curUrl = 'https://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
//\\to//\\
change curUrl = 'https://MYOWNDOMOTICZIP/ical/?time=' + cache + '&url=' + curUrl;
and add this in my CONFIG.js
config['calendar_parse_localy']=true;
With the result that the dutch tv section is working again. Only my 2 iCals are still not responding. (Google and RMN https://inzamelschema.rmn.nl/ical/0356200000014977)
What is the best way to look at this?
The CONFIG.js setting should be:stuffer wrote: ↑Wednesday 24 October 2018 21:41@robgeerts
Almost
First I want to thank you for the project. A crate of beer is on his way when I get this working(or at the Jumbo 1,5 for the price for one )
apt install apache2
apt-get update
//\\changed://\\
} else {
//\\to//\\
config['calendar_parse_localy']=1;
The change you made in calendar.js is not needed (and incorrect) so better to revert that one.
I can't get it to work. I see you are running Dashticz on your server to?peerkersezuuker wrote: ↑Tuesday 23 October 2018 17:14 @EastXII
allow from all
Require all granted
</Directory>
</VirtualHost>
I do not have that, is that why it does not work?
What I also noticed is that OV works on Firefox on Linux but my tablet does not show OV...
I could live without OV but I really, really like the garbage part. In the short time I used Dashticz, it was my, and my wife's, favorite and most used block.
In my CONFIG.js I disabled all 'garbage' related lines with the '//' Then I simply copied your complete example in there. However no change and still showing the text 'geen gegevens gevonden'Lokonli wrote: ↑Wednesday 24 October 2018 20:38 ...
Double check you have the correct settings in CONFIG.js:Code: Select all
config['garbage_company'] = 'deafvalapp'; config['garbage_icalurl'] = ''; config['garbage_calendar_id'] = ''; config['garbage_zipcode'] = '5692VG'; config['garbage_street'] = '0'; config['garbage_housenumber'] = '33';
Is there possibly something wrong with my 'afval folder'? I downloaded the ZIP file that Rob shared and this one contained only index.php in the /afval folder.
Shame on me, I copy pasted the string to modify garbage.js
Some smart program changed the '&sub' into a special character, avoiding the complete json to complete. So, garbage works as well. Hurray!
One more thing, I already opened a github request for it, HVC changed their code. It seems that you first need to check your 'bagID', and put that into the next json request to get the pick-up dates. Although it explained in this topic, I wouldn't know how to fix up the Dashticz code.
HVC is part of 'afvalstromen'. For afvalstromen all code already is implemented, except for HVC. I'll make the fix this weekend.jake wrote: ↑Wednesday 24 October 2018 22:53In my CONFIG.js I disabled all 'garbage' related lines with the '//' Then I simply copied your complete example in there. However no change and still showing the text 'geen gegevens gevonden'Lokonli wrote: ↑Wednesday 24 October 2018 20:38 ...
Hi All,
Almost perfect working. Did everything below. After that reboot Raspberry. Domoticz UP, Apache UP, Dasthicz page load fast. Calendar, TVGuide and Public Transport loads OK.
Only thing i don't have now are the fontawesome icons you can add like:
Here steps i did:
edit Port listen 80 > 82
edit Virtual Host
add
and change <VirtualHost *: 80> to
Create a Symbolic Link into /var/www/html/ because i backup the Domoticz Folder every night. Then everything is save.
icon: 'fa-window-close'
apt-get install apache2 apache2-doc apache2-utils php7.0-zip
apt-get install libapache2-mod-php7.0 php7.0 php7.0-opcache php7.0-mbstring php7.0-mysql php7.0-curl php7.0-gd
apt-get install libapache2-mod-php php-curl
nano /etc/apache2/ports.conf
listen 82
nano /etc/apache2/sites-available/000-default.conf
</IfModule>
<VirtualHost *: 82>
ln -s /home/pi/domoticz/www/dashbeta/ /var/www/html/
Last edited by poudenes on Thursday 25 October 2018 9:49, edited 12 times in total.
In my situation Domoticz is running at :8080. If I start a new webserver at :8081 where the scripts are 'hosted' I receive a
"No access-control-allow-origin' header is present on the requested resource" within Chrome.
Workaround:
Start Chrome with the following parameters:
chrome.exe --user-data-dir="C:/Chrome dev session" --disable-web-security
So that's why I would like to host the scripts behind :8080 (at the domoticz port). But when I try to access the scripts I receive a "Domoticz offline" message.
Anyone with this problem?
Edit: I will try what's mentioned here above first!
Workaround:
- gielie
- Domoticz version: latest β
Nope, i cant get it to work.
I started from scratch, installed dashticz in var/www/html (instead of domoticz/www) with all the necessary dependencies.
I also tried to host the files on my synology and redirected to that address but still no luck.
Can someone make a clear tutorial how to change this.
And one question, if i change the icall/garbage file wont this be a problem with the next git pull update?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
See my post 2 up... For me it work now. Only the custom icons part is gone now. But rest is workinggielie wrote: ↑Thursday 25 October 2018 9:40Nope, i cant get it to work.
