dashticz: Important Request
- Thuis
Re: IMPORTANT REQUEST!!!
Im trying to instal Rasbian on a Xeon N270 to see if there is any difference when i use linux, so far, the installer is busy, installing it to the hard drive...
On windows no luck yet, but i think, luck has nothing to do with it :-p
Fun for everyone!
EastXIII
Can you please specify where to put this in Apache2? I get this error all the time. Header module enabled and added this to apache2.conflightmanster wrote: Friday 19 October 2018 13:39
also add:
<IfModule mod_headers.c>
Header set Access-Control-Allow-Origin "*"
</IfModule>
to your webserver config if you get Access-Control_allow-origin error
Kind regards
LM
But I still get the mentioned error. I'm stuck!
peerkersezuuker
In Linux you can change the php version for apache.
Login with ssh to your machine and :
sudo a2dismod php5.6
sudo a2enmod php7.2
sudo apt-get install php7.2-curl
sudo service apache2 restart
sudo a2enmod php7.2
peerkersezuuker
@EastXII
I have set it in my virtual host config in /etc/apache2/sites-enabled/domoticz.sonnehoek.nl.conf
<VirtualHost 192.168.0.20:880>
# Always set these headers.
Header always set Access-Control-Allow-Origin "*"
DocumentRoot /var/www/dashticz_v2
ServerName domoticz.sonnehoek.nl
<Directory "/var/www/dashticz_v2">
allow from all
Options Indexes FollowSymLinks
Require all granted
</Directory>
</VirtualHost>
allow from all
Require all granted
</Directory>
</VirtualHost>
jake
Thanks for all your tips and tricks guys. Over time my system must have become messy. I decided to wipe out everything that 'smelled' like PHP and start over.
To delete all PHP packages (I had 5.6, 7.0 and 7.2 packages installed)
Install PHP 7.2:
I followed the instructions (for the PHP7.2 part) on this website
After a restart of the apache2 webserver the agenda came back to life.
The garbage is still not working. To outrule possible not updated HVC code, I decided to use the postal code/house number in the file garbage.js from the 'mijnafvalwijzer' and add those to my CONFIG.js. I double checked the combination on the mijnafvalwijzer website and the postal code / house number is a valid one.
Unfortunately it doesn't help. The block still shows 'loading...'
Adaption on garbage.js:
sudo apt-get purge `dpkg -l | grep php| awk '{print $2}' |tr "\n" " "`I followed the instructions (for the PHP7.2 part) on this website
sudo service apache2 restartThe garbage is still not working. To outrule possible not updated HVC code, I decided to use the postal code/house number in the file garbage.js from the 'mijnafvalwijzer' and add those to my CONFIG.js. I double checked the combination on the mijnafvalwijzer website and the postal code / house number is a valid one.
$.getJSON(getPrefixUrl() + 'http://127.0.0.1/beta2/dashboard/vendor/dashticz/afval/?service='+service+'&sub='+subservice+'&zipcode=' + address.zipcode + '&nr=' + address.housenumber + '&t=' + address.housenumberSuffix, function (data) {
Lokonli
If agenda is working then php is working.
I guess the url is not correct.
Press F12 in the browser. Probably there is an error.
What is the output in your browser if you go to: http://127.0.0.1/beta2/dashboard/vendor/dashticz/afval/
(should be: [])
If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:
(should be: [])
$.getJSON('./vendor/dashticz/afval/?service='+service+'&sub='+subservice+'&zipcode=' + address.zipcode + '&nr=' + address.housenumber + '&t=' + address.housenumberSuffix, function (data) {-
poudenes
- Domoticz version: 3.8993
skip. ignore this post
jake
I'm booking progress now: instead of that the garbage block tells me 'laden...' it shows 'geen gegevens gevonden'.Lokonli wrote: If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:Code: Select all
Once again I changed company names /address (deafvalapp with corresponding and working address), but with the same result.
I loaded dashticz on my desktop to check for the error log in the browser. This is what it gives me:
- Spoiler: show
- EdwinK
- Domoticz version: BETA
Sorry, no can do
Lokonli
Double check you have the correct settings in CONFIG.js:jake wrote: Wednesday 24 October 2018 14:47I'm booking progress now: instead of that the garbage block tells me 'laden...' it shows 'geen gegevens gevonden'.Lokonli wrote: If dashticz and the afval module are installed on the same server, same location then in garbage.js you can try the following:Code: Select all
I loaded dashticz on my desktop to check for the error log in the browser. This is what it gives me:Doesn't seem related to garbage, but probably to the use of 'pihole' that blocks advertisements.
- Spoiler: show
config['garbage_company'] = 'deafvalapp';
config['garbage_icalurl'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '5692VG';
config['garbage_street'] = '0';
config['garbage_housenumber'] = '33';
robgeerts
- Domoticz version: 3.7067
Wow had to read back a lot and good to see that most off you already have it working again!!
stuffer
- Domoticz version: 3.6367
@robgeertsrobgeerts wrote: Wednesday 24 October 2018 21:15 Wow had to read back a lot and good to see that most off you already have it working again!!
Almost
First I want to thank you for the project. A crate of beer is on his way when I get this working
What I did on my Ubuntu 16 machine for domoticz:
apt install apache2
apt-get install python-software-properties
add-apt-repository ppa:ondrej/php
apt-get update
nano /home/pi/domoticz/www/dashboard/js/calendar.js
//\\changed://\\
if (settings['calendar_parse_localy']){
curUrl = './vendor/dashticz/ical/?time=' + cache + '&url=' + curUrl;
} else {
curUrl = 'https://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
//\\to//\\
change curUrl = 'https://MYOWNDOMOTICZIP/ical/?time=' + cache + '&url=' + curUrl;
and add this in my CONFIG.js
config['calendar_parse_localy']=true;
With the result that the dutch tv section is working again. Only my 2 iCals are still not responding. (Google and RMN https://inzamelschema.rmn.nl/ical/0356200000014977)
What is the best way to look at this?
Lokonli
The CONFIG.js setting should be:stuffer wrote: Wednesday 24 October 2018 21:41@robgeertsrobgeerts wrote: Wednesday 24 October 2018 21:15 Wow had to read back a lot and good to see that most off you already have it working again!!
Almost
First I want to thank you for the project. A crate of beer is on his way when I get this working(or at the Jumbo 1,5 for the price for one )
apt install apache2
apt-get update
//\\changed://\\
} else {
//\\to//\\
config['calendar_parse_localy']=1;
The change you made in calendar.js is not needed (and incorrect) so better to revert that one.
EastXIII
I can't get it to work. I see you are running Dashticz on your server to?peerkersezuuker wrote: Tuesday 23 October 2018 17:14 @EastXII
allow from all
Require all granted
</Directory>
</VirtualHost>
I do not have that, is that why it does not work?
What I also noticed is that OV works on Firefox on Linux but my tablet does not show OV...
I could live without OV but I really, really like the garbage part. In the short time I used Dashticz, it was my, and my wife's, favorite and most used block.
jake
In my CONFIG.js I disabled all 'garbage' related lines with the '//' Then I simply copied your complete example in there. However no change and still showing the text 'geen gegevens gevonden'Lokonli wrote: Wednesday 24 October 2018 20:38 ...
Double check you have the correct settings in CONFIG.js:Code: Select all
config['garbage_company'] = 'deafvalapp'; config['garbage_icalurl'] = ''; config['garbage_calendar_id'] = ''; config['garbage_zipcode'] = '5692VG'; config['garbage_street'] = '0'; config['garbage_housenumber'] = '33';
Is there possibly something wrong with my 'afval folder'? I downloaded the ZIP file that Rob shared and this one contained only index.php in the /afval folder.
Shame on me, I copy pasted the string to modify garbage.js
Some smart program changed the '&sub' into a special character, avoiding the complete json to complete. So, garbage works as well. Hurray!
One more thing, I already opened a github request for it, HVC changed their code. It seems that you first need to check your 'bagID', and put that into the next json request to get the pick-up dates. Although it explained in this topic, I wouldn't know how to fix up the Dashticz code.
Lokonli
HVC is part of 'afvalstromen'. For afvalstromen all code already is implemented, except for HVC. I'll make the fix this weekend.jake wrote: Wednesday 24 October 2018 22:53In my CONFIG.js I disabled all 'garbage' related lines with the '//' Then I simply copied your complete example in there. However no change and still showing the text 'geen gegevens gevonden'Lokonli wrote: Wednesday 24 October 2018 20:38 ...
poudenes
Hi All,
Almost perfect working. Did everything below. After that reboot Raspberry. Domoticz UP, Apache UP, Dasthicz page load fast. Calendar, TVGuide and Public Transport loads OK.
Only thing i don't have now are the fontawesome icons you can add like:
Here steps i did:
edit Port listen 80 > 82
edit Virtual Host
add
and change <VirtualHost *: 80> to
Create a Symbolic Link into /var/www/html/ because i backup the Domoticz Folder every night. Then everything is save.
icon: 'fa-window-close'Code: Select all
apt-get install apache2 apache2-doc apache2-utils php7.0-zip
apt-get install libapache2-mod-php7.0 php7.0 php7.0-opcache php7.0-mbstring php7.0-mysql php7.0-curl php7.0-gd
apt-get install libapache2-mod-php php-curlCode: Select all
nano /etc/apache2/ports.conf
listen 82Code: Select all
nano /etc/apache2/sites-available/000-default.confCode: Select all
</IfModule> and change <VirtualHost *: 80> to
<VirtualHost *: 82>Code: Select all
ln -s /home/pi/domoticz/www/dashbeta/ /var/www/html/
Last edited by poudenes on Thursday 25 October 2018 9:49, edited 12 times in total.
edge
In my situation Domoticz is running at :8080. If I start a new webserver at :8081 where the scripts are 'hosted' I receive a
"No access-control-allow-origin' header is present on the requested resource" within Chrome.
Workaround:
Start Chrome with the following parameters:
chrome.exe --user-data-dir="C:/Chrome dev session" --disable-web-security
So that's why I would like to host the scripts behind :8080 (at the domoticz port). But when I try to access the scripts I receive a "Domoticz offline" message.
Anyone with this problem?
Edit: I will try what's mentioned here above first!
Workaround:
- gielie
- Domoticz version: latest β
Nope, i cant get it to work.robgeerts wrote: Wednesday 24 October 2018 21:15 Wow had to read back a lot and good to see that most off you already have it working again!!
I started from scratch, installed dashticz in var/www/html (instead of domoticz/www) with all the necessary dependencies.
I also tried to host the files on my synology and redirected to that address but still no luck.
Can someone make a clear tutorial how to change this.
And one question, if i change the icall/garbage file wont this be a problem with the next git pull update?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
poudenes
See my post 2 up... For me it work now. Only the custom icons part is gone now. But rest is workinggielie wrote: Thursday 25 October 2018 9:40Nope, i cant get it to work.robgeerts wrote: Wednesday 24 October 2018 21:15 Wow had to read back a lot and good to see that most off you already have it working again!!
