galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
NiklasO wrote: Thursday 18 October 2018 15:12 It shows my name three times. Should be max one niklas?
Yes it should only show one niklas..
Can you test if this is maybe an update/old settings issue? So clear all app cache/data and reconfigure the connection?
Think that that should solve this issue
galadril
Post by galadril »
galadril
Post by galadril »
osiris1337 wrote: Friday 19 October 2018 22:57 EDIT: Nevermind, I'm an idiot. I gave the account viewing rights instead of user rights.. I'll leave the post here if anyone else is stupid enough to do the same.. :P @devs: maybe some error feedback could be useful instead of everything just disappearing.
Thanks for the feedback.. everything should not just disappear indeed!
galadril
Post by galadril »
Think that i've covered all the crash reports from the beta.
Looking forward to push the beta to production today :D
NiklasO
Post by NiklasO »
galadril wrote: Saturday 20 October 2018 11:52
I reconfigured the app from scratch, (clear data, removing domoticz dir on SD and so on). They are still there. Maybe try again..
C4rtm4N
Post by C4rtm4N »
galadril wrote: Saturday 20 October 2018 11:50 its a combination of local & remote settings to connect to domoticz
Is there any chance that you'll be able to support certificate based authentication via the usual NGINX reverse proxy at some point in the future? I love the app but can only use it when I'm physically sat in my house.
galadril
Post by galadril »
The new version is available in the App Stores (we promoted beta to prod)
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
Just updated, when I open the app it crashes immediately. Except when I long press and then choose dashboard it works fine. After this I can normally open it (as long as it's in memory).
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
tun0
Post by tun0 »
The temperature tab didn't work before updating just now, it just showed an empty page. Now it shows this:Image
Edit: apparently it doesn't handle "stale" devices very well. Got some old laying around for historical purposes, but those don't get any updates any more.
galadril
Post by galadril »
MarcelMAH wrote: Sunday 21 October 2018 15:12 Just updated, when I open the app it crashes immediately. Except when I long press and then choose dashboard it works fine. After this I can normally open it (as long as it's in memory).
Im looking for a fix, thanks
galadril
Post by galadril »
tun0 wrote: Sunday 21 October 2018 15:41 The temperature tab didn't work before updating just now, it just showed an empty page.
Can you send (PM) me a view-only account so i can debug against your system??
galadril
Post by galadril »
Did you had a different startup page selected in the setting instead of Dashbaord???
MarcelMAH
Post by MarcelMAH »
galadril wrote: Sunday 21 October 2018 17:14
No, I always open in dashboard (99% certain). When I had the update it opened first in the wizard (short version), wich I disabled, then the problems started.
galadril
Post by galadril »
MarcelMAH wrote: Sunday 21 October 2018 17:24
But you use it now without issues?
MarcelMAH
Post by MarcelMAH »
galadril wrote: Sunday 21 October 2018 17:47
No, I can only start it when I long press the icon and then choose Dashboard, after this it will work normally (normal press icon) as long as the app is in memory.
buutske
Post by buutske »
Just updated, the sliders for ex. Windows screens should be always visible, then you can slide the slider to the desired %.
sdmg
Post by sdmg »
Good job, but since the last stable version 4.9700, we can not see the status or error loglevel in the app at least in the Android, we can only see the normal loglevel. Previously, everything was seen.
It would be good to put several tabs in the Windows registry.
Thank you
salvacalatayud
Post by salvacalatayud »
In new version milight can't change to warm white like in old version.
Enviado desde mi Redmi 4X mediante Tapatalk
tun0
Post by tun0 »
And it's fixed! Thanks for the quick support.
EddyG
Post by EddyG »
I am on version 0.2.8 (4831), Android 8.1.0 on Xiaomi A2 64Gb
It works fine a few App versions before.
I am not able to select the Switches anymore. It always shows the Dashboard.
I did clear the cache.
