NiklasO wrote: ↑Thursday 18 October 2018 15:12
It shows my name three times. Should be max one niklas?
Yes it should only show one niklas..
Can you test if this is maybe an update/old settings issue? So clear all app cache/data and reconfigure the connection?
osiris1337 wrote: ↑Friday 19 October 2018 22:57
EDIT: Nevermind, I'm an idiot. I gave the account viewing rights instead of user rights.. I'll leave the post here if anyone else is stupid enough to do the same.. @devs: maybe some error feedback could be useful instead of everything just disappearing.
Thanks for the feedback.. everything should not just disappear indeed!
Think that that should solve this issue
I reconfigured the app from scratch, (clear data, removing domoticz dir on SD and so on). They are still there. Maybe try again..
galadril wrote: ↑Saturday 20 October 2018 11:50
its a combination of local & remote settings to connect to domoticz
Is there any chance that you'll be able to support certificate based authentication via the usual NGINX reverse proxy at some point in the future? I love the app but can only use it when I'm physically sat in my house.
Just updated, when I open the app it crashes immediately. Except when I long press and then choose dashboard it works fine. After this I can normally open it (as long as it's in memory).
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
The temperature tab didn't work before updating just now, it just showed an empty page. Now it shows this:
Edit: apparently it doesn't handle "stale" devices very well. Got some old laying around for historical purposes, but those don't get any updates any more.
MarcelMAH wrote: ↑Sunday 21 October 2018 15:12
tun0 wrote: ↑Sunday 21 October 2018 15:41
Can you send (PM) me a view-only account so i can debug against your system??
Did you had a different startup page selected in the setting instead of Dashbaord???
No, I always open in dashboard (99% certain). When I had the update it opened first in the wizard (short version), wich I disabled, then the problems started.
But you use it now without issues?
No, I can only start it when I long press the icon and then choose Dashboard, after this it will work normally (normal press icon) as long as the app is in memory.
Good job, but since the last stable version 4.9700, we can not see the status or error loglevel in the app at least in the Android, we can only see the normal loglevel. Previously, everything was seen.
It would be good to put several tabs in the Windows registry.
Thank you
I am on version 0.2.8 (4831), Android 8.1.0 on Xiaomi A2 64Gb
It works fine a few App versions before.
I am not able to select the Switches anymore. It always shows the Dashboard.
I did clear the cache.
