Dashticz - Module - Calendar
Re: Dashticz - Module - Calendar
I have the same problem.
I also have afval kalender enabled and that is working perfect with the local php.
How did you get the 'afval kalender' block working again? Mine doesn't work, but it possibly has to do with both ther server shutdown and HVC who changed access to their data some weeks ago. I don't know yet if anybody updated the code for HVC. Before it was stored on Rob's server, so nobody had access to it.peerkersezuuker wrote:I have the same problem.
@Jake, We have Cure as our local garbage disposal company.
I changed function getGeneralData in garbage.js, ther you se an url pointing to dashticz.nl.
Change it to you own.
- Spoiler: show
Thanks, allthough according git pull everything is up to date, I see that I have in /dashboard/vendor/dashticz only the folder ical, while the zip of Rob shows afval and tv as well. I added the additional folders to the dashticz folder and pointed towards that accordingly (192.168.x.x/dashticz/dashboard/vendor/dashticz/afval) but it still doesn't work. I assume this is because of the change in the HVC call that I don't fully understand.
- Siewert308SW
- Domoticz version: Stable
Is there a max amount of combined calendars in the beta version?
My code below works.
But if i add a third or fourth calendar then only the first two are shown.
var calendars = {}
calendars.fcg = { width:6 ,maxitems: 10, icalurl: 'https://calendar.google.com/calendar/ical/xxxx%40import.calendar.google.com/public/basic.ics' }
calendars.prive = { width:6 ,maxitems: 10, icalurl: 'https://calendar.google.com/calendar/ical/xxxx/basic.ics' }
calendars.feestdagen = { width:6 ,maxitems: 10, icalurl:'https://calendar.google.com/calendar/ical/xxxx%40group.v.calendar.google.com/public/basic.ics' }
//calendars.vakanties = { width:6 ,maxitems: 10, icalurl:'https://calendar.google.com/calendar/ical/xxxx%40import.calendar.google.com/public/basic.ics' }
calendars.combined = {}
calendars.combined.maxitems = 6;
calendars.combined.width = 9
calendars.combined.icon = 'far fa-calendar-alt';
calendars.combined.calendars = [
{ color:'white',calendar:calendars.vakanties },
{ color:'green',calendar:calendars.fcg },
//{ color:'white',calendar:calendars.prive },
//{ color:'red',calendar:calendars.feestdagen }
calendars.combined.url = 'https://calendar.google.com/calendar';
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
Is there any solution how to shown calendars that repeating? I have lots of calendar items that is repeating every 5 weeks. Somedays more then 2 on a day.
- Domoticz version: BETA
Dear...
Update to last beta
Is the way to use the new calendar:
Because in the calendar.js i see the dashticz.nl not any more?
Only when i try this the calendar is not working yet
Update to last beta
{maxitems: 35, icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/ical/demxxxxxx
- EdwinK
dashticz.nl isn't being used for some time now.
Yes i read that...
Only where do i need to make a change to use the calendar function again..
I did:
config['default_cors_url'] ='https://cors-anywhere.herokuapp.com/';
{maxitems: 35, icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/ical/xxxxxxxxxx
Or otherwise how do i get the calendar working/
Do you have it working already?Derik wrote: ↑Saturday 05 January 2019 22:57
Yes i read that...
I did:I did:Code: Select all
where do i go wrong?Code: Select all
With the latest beta you can remove config['default_cors_url']. You also can just use the normal calendar url (without the cors-anywhere part in front)
please a simple how to use the/this calendar option..
First install Dashticz, including Apache and PHP, according the info on the wiki:
Then add the following lines to your CONFIG.js:
var calendars = {}
calendars.me = { maxitems: 10, url: 'https://calendar.google.com/calendar/embed?src=youremail%40gmail.com&ctz=Europe%2FAmsterdam', icalurl: 'https://calendar.google.com/calendar/ical/youremail%40gmail.com/private-yourprivatekey/basic.ics' }
Add the calendar to a column:
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [
calendars.me
Apache en php?Lokonli wrote: ↑Saturday 19 January 2019 19:29First install Dashticz, including Apache and PHP, according the info on the wiki:
Your calendar must be in ical format. When you click on the agenda the url is opened in a frame. The example above works for a google agenda. You can find the links on the settings page of your agenda on calendar.google.com.Code: Select all
var calendars = {} calendars.me = { maxitems: 10, url: 'https://calendar.google.com/calendar/embed?src=youremail%40gmail.com&ctz=Europe%2FAmsterdam', icalurl: 'https://calendar.google.com/calendar/ical/youremail%40gmail.com/private-yourprivatekey/basic.ics' }
Add the calendar to a column:And then it should workCode: Select all
var columns = {} columns[1] = {} columns[1]['blocks'] = [ calendars.me ]
In the wiki from?
https://www.domoticz.com/wiki/Dashticz_V2Derik wrote: ↑Saturday 19 January 2019 19:38Apache en php?Lokonli wrote: ↑Saturday 19 January 2019 19:29First install Dashticz, including Apache and PHP, according the info on the wiki:
In the wiki from?
First start with the installation part.
Lokonli wrote: ↑Saturday 19 January 2019 20:05https://www.domoticz.com/wiki/Dashticz_V2Derik wrote: ↑Saturday 19 January 2019 19:38Apache en php?Lokonli wrote: ↑Saturday 19 January 2019 19:29
In the wiki from?
Still running for long time only the calendar part is missing after the "big" change
If you want to use calendar you have to install apache, PHP and a recent beta version of Dashticz.Derik wrote: ↑Saturday 19 January 2019 20:08Lokonli wrote: ↑Saturday 19 January 2019 20:05https://www.domoticz.com/wiki/Dashticz_V2
Yes i read something...Lokonli wrote: ↑Saturday 19 January 2019 20:14If you want to use calendar you have to install apache, PHP and a recent beta version of Dashticz.Derik wrote: ↑Saturday 19 January 2019 20:08Lokonli wrote: ↑Saturday 19 January 2019 20:05
Only that's my problem..
Can i this direct install on the same hardware where domoticz is on running...
And then where to start to get the calendar working fine
Yes, you can install it on the same hardware. What kind of system are you using?
RPi 3 or Xu4 odroid [ testing ]Lokonli wrote: ↑Saturday 19 January 2019 20:54Yes, you can install it on the same hardware. What kind of system are you using?
so what are the commands i need to use?
the wiki from domoticz is very great..
