The light stays on while there is movement.
ReWiG
Post by ReWiG »
I have a xiaomi motion sensor and a lamp. I want to turn on the lamp when motion is detected and turn it off only when the movement stops. But I can not. Can you help me write a script dzvents?
Re: The light stays on while there is movement.
ReWiG wrote: Tuesday 16 October 2018 23:16 I have a xiaomi motion sensor and a lamp. I want to turn on the lamp when motion is detected and turn it off only when the movement stops. But I can not. Can you help me write a script dzvents?
This is almost the same as one of the examples on the wiki
- XMotion
 local motionDetector = 670            -- device idx of your motion detector
 local light          = 535            -- device idx of your light
          on   = { devices = { motionDetector }},          -- your motion detector
    execute = function(dz, XMotion)
        if XMotion.state == "On" then
           dz.devices(light).switchOn().checkFirst()
           dz.devices(light).switchOff().checkFirst()
ReWiG
Post by ReWiG »
I do not have the opportunity to check now, but I think that it does not work. I used the condition
"if (device.state == 'Off') then devices.switchOn ()"
end instead of checkFirst () and it did not work. The fact is that the xiaomi sensor regains its state at least once a minute. That is, what happens is: Motion is detected, the sensor changes to the On state, the lamp turns on. Then exactly 1 minute it burns. All this time in the area of ​​the sensor movement occurs. Further, when 1 minute expires, the sensor goes to the Off state and immediately again to the On state. Accordingly, the lamp turns off first and then turns on again. I would not want this to happen, I would like it to burn continuously as long as there is movement.
ReWiG wrote: Wednesday 17 October 2018 8:03 I do not have the opportunity to check now, but I think that it does not work. I used the condition
Not sure if it is the same sensor and if something can be configured in these sensors but the log of my xiaomi motion sensor does not show the behavior that you describe.
loglines of one of my xiaomi motion sensors
But maybe for your situation this works better.
-- XMotion
local motionDetector = 70            -- device idx of your motion detector
local lightID        = 71            -- device idx of your light
        local light = dz.devices(lightID)
            if light.state ~= "On" then
                light.cancelQueuedCommands()
                light.switchOn()
           light.switchOff().afterSec(30)
ReWiG
Post by ReWiG »
I use this sensor https://www.gearbest.com/alarm-systems/pp_659226.html
It shows this behavior https://yadi.sk/i/_scN-UYlXlaGDw https://yadi.sk/i/VU-6Zcxbi7sxfg That is, it turns on, turns off and on again after a minute. At the same time, in the sensor settings, I have this https://yadi.sk/i/Aq-JS0M3Fywy-A. If the shutdown delay is set to 0, then it will work every 2 minutes, and it takes a very long time.
The setting in the Off delay field explains why you see a different behavior. If you leave that out the sensor.state won't go to "Off" while there is movement detected.
So if you want to keep that Off delay of 60 seconds you should use the 2nd script. If you take it out the first script will do.
