Dashticz - Module - Calendar
Cletus
- Domoticz version: Latest
Re: Dashticz - Module - Calendar
Excelent, that change fixed it for me! Thanks!
This is our world now... the world of the electron and the switch, the beauty of the baud.
emoncuit
Hello Axel2906,
I confirm your code has fixed the "loading" issue.
Thanks a lot!
Thanks a lot!
Hey guys,
I still have the problem that the calendar block in dashticz keeps saying 'loading' and doesn't give my calendar appointments. But when I paste the private Ical url in my browser, the browser starts downloading the Ical information. Can anyone explain how I can add axel2906's workaround to the CONFIG.js?
axel2906
- Domoticz version: V3.8926
Hey,RiHa wrote: Sunday 11 March 2018 20:20 Hey guys,
the changes must be made in CALENDAR.js not in config.js. Find this line in calendar.js (dashticz_v2/js folder) line 56
var cache = new Date().getTime();
curUrl = http://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
moment.locale(settings['calendarlanguage']);
$.getJSON(curUrl,function(data,textstatus,jqXHR){Code: Select all
'https://cors-anywhere.herokuapp.com/RPi3 - RfxComm - Milight - OWL160
Oh thanks for the quick response.axel2906 wrote:Hey,RiHa wrote: Sunday 11 March 2018 20:20 Hey guys,
and addCode: Select all
var cache = new Date().getTime(); curUrl = http://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl; moment.locale(settings['calendarlanguage']); $.getJSON(curUrl,function(data,textstatus,jqXHR){before http://dashticz.nlCode: Select all
My calendar.js file looked a bit different, especially the URL I had to change. But by pasting your URL in my calendar.js I got it working again.
Thank!
Sent from my Pixel XL using Tapatalk
Amsterdam020
- Domoticz version: 3.5629
If you use the code then herokuapp.com gets your full agenda. For private agendas i would be very reluctant to use this solution. Dont you value your privacy?
Is there a solution that does not require a third party?
Rp3, youlesss, rfxcom, philips hue, dsb1820
- DewGew
- Domoticz version: V4.10618
One solution is to run your own crossorgin server. see wiki https://www.domoticz.com/wiki/Dashticz_ ... sers.21.29Amsterdam020 wrote: Monday 12 March 2018 22:54 If you use the code then herokuapp.com gets your full agenda. For private agendas i would be very reluctant to use this solution. Dont you value your privacy?
Derik
- Domoticz version: BETA
mm does anyone have a working ical for the F1..
I do have :
Only this is not working any more i see:-(
I do have :
calendars.F1 = {maxitems: 1, icalurl: 'https://calendar.google.com/calendar/ical/8apmubhi25j8vfcqqbfralm54oj8ddb1%40import.calendar.google.com/public/basic.ics' }
EdwinH
- Domoticz version: 3.8153
Zoiets ? :Derik wrote: Friday 25 May 2018 17:21 mm does anyone have a working ical for the F1..
I do have :Code: Select all
calendars.formule1 = { maxitems: 15, icalurl: 'https://www.formula1.com/sp/static/f1/2018/calendar/ical.ics' }- mvveelen
I can't seem to find a solution for this: I have 2 combined calendars. For both, I set an icon, but I don't get to see any icon when using the combined calendar. The code I use:
and:
var _ICALENDAR_DATEFORMAT = 'dddd DD MMMM YYYY HH:mm';
var _ICALENDAR_LOCALE = 'nl'; //en,hu, etc.
var calendars = {}
calendars.een = { maxitems: 3, title:'Agenda een', icon:'fa-calendar', icalurl: 'https://p49-calendars.icloud.com/published/2/vjbladiebladieI' }
calendars.twee = { maxitems: 3, title:'Agenda twee', icon:'fa-calendar', icalurl: 'https://p49-calendars.icloud.com/published/2/hkmjadajada' }
calendars.combined = {}
calendars.combined.maxitems = 5;
calendars.combined.calendars = [
{ color:'white',calendar:calendars.een },
{ color:'pink',calendar:calendars.twee }
calendars.combined.url = 'https://calendar.google.com/calendar';
columns[2] = {}
columns[2]['width'] = 5;
columns[2]['blocks'] = ['garbage',calendars.combined,tvguide.dutch]
- mvveelen
Nobody?
at least I assume that it would be possible to get the calendar-icon when you're using the combined calendars, right?
Getting both calendars separate will take too much space and I want the dates to be displayed in a chronological order.
I hope someone can get the the solution for this.
Dlanor
first of all nice work!
I am trying to add the trash calendar. There are two but only one is shown. Any idea?
var calendars = {}
calendars.trash = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/8r0tm9d1kkm34bfdemq1dg53h53h1tco%40import.calendar.google.com/public/basic.ics'}
Domoticz| Zigbee | SONOFF
Derik
EdwinH wrote: Thursday 21 June 2018 9:57Zoiets ? :Derik wrote: Friday 25 May 2018 17:21 mm does anyone have a working ical for the F1..
Only this is not working any more i see:-(Werkt als een tierelierCode: Select all
Thanks!!!
See now your message...[ en heb nu ff tijd om aan te passen..]
Do you have more dutch working calenders? [ holidays of christmas and other importend days? ]
And do you have in the normal google calendars multiple events working??
Derik
Dear all
Please does everyone have the multiple events visible in daschticz?
All the repeating items are not showing up?
I try different calendars and all the same problem.
No event that have more then 1 day
En event repeating for every Monday or something are not showing up..
In the earlier editions was there no problem with it..
Hope there is a solution..
- mvveelen
Nobody knows a solution for this ?mvveelen wrote: Sunday 22 July 2018 16:02 I can't seem to find a solution for this: I have 2 combined calendars. For both, I set an icon, but I don't get to see any icon when using the combined calendar. The code I use:
and:Code: Select all
var _ICALENDAR_DATEFORMAT = 'dddd DD MMMM YYYY HH:mm'; var _ICALENDAR_LOCALE = 'nl'; //en,hu, etc. var calendars = {} calendars.een = { maxitems: 3, title:'Agenda een', icon:'fa-calendar', icalurl: 'https://p49-calendars.icloud.com/published/2/vjbladiebladieI' } calendars.twee = { maxitems: 3, title:'Agenda twee', icon:'fa-calendar', icalurl: 'https://p49-calendars.icloud.com/published/2/hkmjadajada' } calendars.combined = {} calendars.combined.maxitems = 5; calendars.combined.calendars = [ { color:'white',calendar:calendars.een }, { color:'pink',calendar:calendars.twee } ] calendars.combined.url = 'https://calendar.google.com/calendar';
columns[2] = {} columns[2]['width'] = 5; columns[2]['blocks'] = ['garbage',calendars.combined,tvguide.dutch]
Derik
Kick no one have this problem??Derik wrote: Saturday 25 August 2018 20:35 Dear all
Please
- EdwinK
No problems here with repeating events.
Derik
dear...
Now i see no thing @ all in the calendar.. from my Gmail..
Only changed my pass in the gmail acocunt..
Cannot see anything, ical doesnot change..
Reboot my system
So is there perhaps something else wrong
Did upload the past beta...
Make no differnets..
Reboot my system
- gielie
- Domoticz version: latest β
http://domoticz.com/forum/viewtopic.php ... 20#p194635Derik wrote: Friday 19 October 2018 11:23 dear...
Reboot my system
This is the reason
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
jake
I'm running the latest beta and did add the extra line to config.js (config['calendar_parse_localy']=true;) However, Dashticz doesn't show the calendar.
In the root of /var/www/html I have the file phpinfo.php. When I run that file from the browser, it returns me the information abot php. Therefore I assume PHP is running properly
