Accessing the room plans.
brunonar
Post by brunonar »
How do I get the floor plan and room plan associated with my python plugin's Device?
I need it for context commands that I'm trying to create. I'd like to do something like "turn off all lights of Mary's room" or "Turn on John's TV".
Thanks.
brunonar
Re: Accessing the room plans.
Post by brunonar »
I tried everything but I think that it's not a feature currently supported.
What I did temporarily to solve the problem was use the device's description field as the device location, so the plugin could access it. But this is very bad.
brunonar wrote: Monday 08 October 2018 22:56 I tried everything but I think that it's not a feature currently supported.
http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command&param=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
Does that not help you ?
brunonar
Post by brunonar »
waaren wrote: Monday 08 October 2018 23:03 http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command&param=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
Thank you for the answer, Waaren!
My plugin would have to ask the user's username and password for that, wouldn't it?
mvzut
Post by mvzut »
Not if you use 127.0.0.1 and add this to the Local Networks list (under settings).
brunonar
Post by brunonar »
mvzut wrote: Tuesday 09 October 2018 7:34
Thank you very much! I'll try it!
