How do I get the floor plan and room plan associated with my python plugin's Device?
I need it for context commands that I'm trying to create. I'd like to do something like "turn off all lights of Mary's room" or "Turn on John's TV".
Thanks.
Accessing the room plans.
brunonar
Re: Accessing the room plans.
I tried everything but I think that it's not a feature currently supported.
What I did temporarily to solve the problem was use the device's description field as the device location, so the plugin could access it. But this is very bad.
- waaren
http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command¶m=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>brunonar wrote: Monday 08 October 2018 22:56 I tried everything but I think that it's not a feature currently supported.
Does that not help you ?
brunonar
Thank you for the answer, Waaren!waaren wrote: Monday 08 October 2018 23:03 http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command¶m=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
My plugin would have to ask the user's username and password for that, wouldn't it?
mvzut
Not if you use 127.0.0.1 and add this to the Local Networks list (under settings).brunonar wrote:Thank you for the answer, Waaren!waaren wrote: Monday 08 October 2018 23:03 http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command¶m=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
brunonar
Thank you very much! I'll try it!mvzut wrote: Tuesday 09 October 2018 7:34Not if you use 127.0.0.1 and add this to the Local Networks list (under settings).brunonar wrote:Thank you for the answer, Waaren!waaren wrote: Monday 08 October 2018 23:03 http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command¶m=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
