heggink wrote: Friday 05 October 2018 9:06
The refreshiframe parameter determines the refresh rate. Just increase. Not sure why you don't get a forecast tho...
Thank you, decreased the refreshiframe to 100000, and it is not blinking now.
The tablet view is very confusing because the owm block is very ugly, the tempereature values are to big in that mode . Thats why I tried the forecast.io.
Dashticz should display the switch selector. Domoticz recently switched to a new way of encoding the selector values. Support for this has been added to Dashticz beta some time ago. Are you running the beta version of Dashticz?
DASHTICZ 🙃
P1 meter & solar panel
columns[5]['blocks'] = ['10'.'8','9','55']
Dot should be comma I think and you don't have to use an apostrophe if you only have digits: columns[5]['blocks'] = [10,8,9,55]
I'm trying to make a button change color on a specific value (or even better, when in between values). I added the classes in the custom.css ofcourse. It's a temperature device and i want it to change color when in between specific values
After the changes concerning dashticz.nl i cant get the garbage/ical working again but that's another problem, my dashticz is also super super slow.
is anybody having the same problem.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
gielie wrote: Thursday 25 October 2018 9:48
