mozo78
Post by mozo78 »
heggink wrote: Friday 05 October 2018 9:06 The refreshiframe parameter determines the refresh rate. Just increase. Not sure why you don't get a forecast tho...
Thank you, decreased the refreshiframe to 100000, and it is not blinking now.
The tablet view is very confusing because the owm block is very ugly, the tempereature values are to big in that mode . Thats why I tried the forecast.io.
GrOOt
Post by GrOOt »
I can't use Sonos on dashticz, it's ok when I used Domoticz (switch selector with play/pause/volume up & down)
no links of Sonos in main.js, normal ?
grep -r "Logitech Media" *
js/main.js: case 'Logitech Media Server':
pi@raspberrypi:~/domoticz/www/dash $ grep -r "Sonos" *
custom/CONFIG.js:// {"track":1,"name":"Sonos","file":"http://xx:5005/salon/play"}, (--> my test with VAR)
custom/CONFIG.js:blocks[18] = {} //Sonos
GrOOt
Post by GrOOt »
something is wrong ?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 101,
"Data" : "Set Level: 20 %",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00014062",
"Image" : "Sonos",
"IsSubDevice" : false,
"LastUpdate" : "2018-10-09 22:25:38",
"Level" : 20,
"LevelActions" : "fGh0dHA6Ly8xOTIuMTY4LjEuNTI6NTAwNS9zYWxvbi9wbGF5fGh0dHA6Ly8xOTIuMTY4LjEuNTI6NTAwNS9zYWxvbi9wYXVzZXxodHRwOi8vMTkyLjE2OC4xLjUyOjUwMDUvc2Fsb24vcGxheWxpc3QvU29ub3N8aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3ZvbHVtZS8rNXxodHRwOi8vMTkyLjE2OC4xLjUyOjUwMDUvc2Fsb24vdm9sdW1lLy01",
"LevelInt" : 20,
"LevelNames" : "T2ZmfFBsYXl8UGF1c2V8UGxheWxpc3R8VXB8RG93bg==",
"LevelOffHidden" : true,
"MaxDimLevel" : 100,
"Name" : "Sonos",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SelectorStyle" : 0,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Set Level: 20 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Selector Switch",
"SwitchType" : "Selector",
"SwitchTypeVal" : 18,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "Light",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "18"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 12,
"Data" : "",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HaveDimmer" : false,
"ID" : "65",
"Image" : "Media",
"LastUpdate" : "2018-10-09 22:23:10",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Sonos Salon",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "On",
"StrParam1" : "aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3BsYXk=",
"StrParam2" : "aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3BhdXNl",
"SubType" : "X10",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "Media",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "19"
Lokonli
Post by Lokonli »
Dashticz should display the switch selector. Domoticz recently switched to a new way of encoding the selector values. Support for this has been added to Dashticz beta some time ago. Are you running the beta version of Dashticz?
GrOOt
Post by GrOOt »
no i'm running the stable version. you suggest to install the beta version ?
heggink
Domoticz version: 12451
Post by heggink »
Yes. Stable doesn't have it.
DASHTICZ 🙃
P1 meter & solar panel
GrOOt
Post by GrOOt »
Ok thank you
DarkG
Domoticz version: 4.10076
Post by DarkG »
When I add those lines, I get an error when I open the webpage. What could be fault?
blocks['10'] = {}
blocks['10']['width'] = 4;
blocks['8'] = {}
blocks['8']['width'] = 4;
blocks['9'] = {}
blocks['9']['width'] = 4;
blocks['55'] = {}
blocks['55']['width'] = 4;
columns[5] = {}
columns[5]['blocks'] = ['10'.'8','9','55']
columns[5]['width'] = 5;
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
HansieNL
Post by HansieNL »
Dot should be comma I think and you don't have to use an apostrophe if you only have digits: columns[5]['blocks'] = [10,8,9,55]
Blah blah blah
DarkG
Post by DarkG »
omg, I looked 100 times over and over. Thank you
JimmyH1969
Post by JimmyH1969 »
I'm trying to make a button change color on a specific value (or even better, when in between values). I added the classes in the custom.css ofcourse. It's a temperature device and i want it to change color when in between specific values :-)
This works:
function getStatus_2(idx,value,device){
   if(parseFloat(device['Data'])<21){
      $('div.block_2').addClass('yellow');
This does not:
   if(parseFloat(device['Data'])>23){
      $('div.block_2').addClass('red');
This does not:
   if(parseFloat(device['Data'])>=17&&<=19){
      $('div.block_2').addClass('lightblue');
Any ideas? I'm probably doing something wrong but can't seem to find it. Tnx in advance!
HansieNL
Post by HansieNL »
@JimmyH1969 :
Maybe this post can help you: http://www.domoticz.com/forum/viewtopic ... ss#p137692
Blah blah blah
Lokonli
Post by Lokonli »
JimmyH1969 wrote: Tuesday 23 October 2018 22:34 This does not:
For this part try:
   if(parseFloat(device['Data'])>=17 && parseFloat(device['Data'])<=19){
JimmyH1969
Thanks to all for pointing me in the right direction. I solved it like this:
   if(parseFloat(device['Data'])>22){
      $('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('yellow').removeClass('orange').addClass('red');
   else if(parseFloat(device['Data'])>21){
      $('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('yellow').removeClass('red').addClass('orange');
   else if(parseFloat(device['Data'])>20){
      $('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('orange').removeClass('red').addClass('yellow');
   else if(parseFloat(device['Data'])>19){
      $('div.block_2').removeClass('darkblue').removeClass('yellow').removeClass('orange').removeClass('red').addClass('lightblue');
   else if(parseFloat(device['Data'])>15){
      $('div.block_2').removeClass('lightblue').removeClass('yellow').removeClass('orange').removeClass('red').addClass('darkblue');
houtumj
Post by houtumj »
Is www.dashticz.nl down???
Garbage not working anymore
HansieNL
Post by HansieNL »
houtumj wrote: Wednesday 24 October 2018 16:04 Is www.dashticz.nl down???
See viewtopic.php?f=67&t=24907
Blah blah blah
gielie
Domoticz version: latest β
Post by gielie »
After the changes concerning dashticz.nl i cant get the garbage/ical working again but that's another problem, my dashticz is also super super slow.
is anybody having the same problem.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
poudenes
Domoticz version: 3.8993
Post by poudenes »
gielie wrote: Thursday 25 October 2018 9:48 After the changes concerning dashticz.nl i cant get the garbage/ical working again but that's another problem, my dashticz is also super super slow.
http://www.domoticz.com/forum/viewtopic ... 87#p195387
edge
Post by edge »
I managed to got the scripts working again. But somehow the fontawesome icons aren't working.
fas fa-calendar-alt
fa-calendar-alt
fas.fa-calendar-al
All without luck :(
poudenes
Post by poudenes »
edge wrote: Friday 26 October 2018 11:19 I managed to got the scripts working again. But somehow the fontawesome icons aren't working.
fas fa-calendar-alt
fa-calendar-alt
fas.fa-calendar-al
All without luck :(
check https://fontawesome.com/icons?d=gallery
some names are changed. I corrected mine and have icons back
Locked
