Neo CoolCam Wall Switch problem
terrorsource
I've installed a few Neo CoolCam Wall Switches 1CH/1-Gang and a few 2CH/2-Gang in my house.
2CH/2-Gang's are working fine, when i press the physical button Domoticz "sees" the state changed
Press from OFF > ON = Domoticz ON
Press from ON > OFF = Domoticz OFF
1CH/1-Gang's dont have that direct feedback.
The physical button needs to be pressed 3 times to get the status in Domoticz. First ON and OFF is not send to the controller from the Wall Switch.
I have this issue with all 5 1CH/1-Gang Wall Switches in my house.
1. Press from OFF > ON = > lights go ON > domoticz = switch did not change
2. Press from ON > OFF = > lights go OFF > domoticz = switch did not change
3. Press from OFF > ON = > lights go ON > domoticz = light is ON
4. Press from ON > OFF = > lights go OFF> domoticz = light is OFF
Is this issue Domoticz related or hardware/sensor related?
- jvdz
- Domoticz version: 4.107
Re: Neo CoolCam Wall Switch problem
Do you have enough zwave powered devices in the mesh to ensure you have a stable path to the server?
Jos
Jos
terrorsource
5x Wall Switch 1CHjvdz wrote: Thursday 19 July 2018 16:47 Do you have enough zwave powered devices in the mesh to ensure you have a stable path to the server?
Jos
2x Wall Switch 2CH
1x Aeotech Switch 6
5x Fibaro Wall Plug
So that shouldn't be an issue.
Also having the issue if the Wall Switch is approx 1.5m from the Aeotec Gen.5 controller.
Gianni
did you fix this issue?
I have the same problem ,first i thought it was my script but after some testing and debugging is notice the same issue?
SO my hotelswitch only works when i push 3 times
terrorsource
Still have the same issue. Bought a Fibaro HC lite to test it out but results are not reliable (gf does not tell me when she pushes the buttonsGianni wrote: Sunday 30 September 2018 21:34 did you fix this issue?
Going to buy a Fibaro Home Center(big one) to test it out a bit more.
But to be clear, the 3-presses (on>off>on) is not always needed. Only after a few hours (exact time still not known).
- LouiS22
Have you changed anything within the parameters? The 1st on should be disabled (remember relay on/off state). Other guess: defective hardwareterrorsource wrote: Monday 01 October 2018 8:05Still have the same issue. Bought a Fibaro HC lite to test it out but results are not reliable (gf does not tell me when she pushes the buttonsGianni wrote: Sunday 30 September 2018 21:34 did you fix this issue?
SO my hotelswitch only works when i push 3 times)
terrorsource
These are the settings of the 1-button switch at the moment. This switch is used in a "hotel switch setup".LouiS22 wrote: Monday 01 October 2018 10:53Have you changed anything within the parameters? The 1st on should be disabled (remember relay on/off state). Other guess: defective hardwareterrorsource wrote: Monday 01 October 2018 8:05Still have the same issue. Bought a Fibaro HC lite to test it out but results are not reliable (gf does not tell me when she pushes the buttonsGianni wrote: Sunday 30 September 2018 21:34 did you fix this issue?
But to be clear, the 3-presses (on>off>on) is not always needed. Only after a few hours (exact time still not known).![]()
Should i change the first option to "Disable" ?
terrorsource
First option is now "Disabled" and still have the same issue.LouiS22 wrote: Monday 01 October 2018 10:53Have you changed anything within the parameters? The 1st on should be disabled (remember relay on/off state). Other guess: defective hardwareterrorsource wrote: Monday 01 October 2018 8:05Still have the same issue. Bought a Fibaro HC lite to test it out but results are not reliable (gf does not tell me when she pushes the buttonsGianni wrote: Sunday 30 September 2018 21:34 did you fix this issue?
I have 2x 1-button Wall Switch which do not have this issue
And i have 10x 1-button Wall Wwitch which do have this issue. Already have received 4 new ones from Neo CoolCam. All new one's have this issue too.
- Eddiever
- Domoticz version: 2022.1
I know it is an older thread but I ran into the same issue. Is there anybody outthere who has a solution to this problem?
terrorsource
No, there is no working solution.Eddiever wrote: Tuesday 28 May 2019 9:58 I know it is an older thread but I ran into the same issue. Is there anybody outthere who has a solution to this problem?
Already spoke with more people who have this issue.
really looks like there's a time-out in the firmware of the devices somehow.
Going to move to Fibaro Walli soon as replacements.
- Eddiever
Thanks for the quick response.
Ixxy
I have the 3-channel version of the wallswitch. It has the same problem as the 1-channel.
I have the following Neo Coolcam Z-wave devices:
4 x 1-channel (no on/off signal to Domoticz on fysical operation)
3 x 2-channel (on/off signal to domoticz ok) 1 switch is defect with black burnmarks on the print
1 x 3-channel (no on/off signal to Domoticz on fysical operation)
5 x powerplug (kWh not working correct.)
Update: better solution at bottom!
I have the wallswitches working better by enabling polling on the 1 and 3 channel switches with an interval of 5 seconds (on the controller). This way you have to wait max. 5 seconds for domoticz to see the switch.
If anyone found a better solution for this problem, please tell me / us.
Domoticz 4.11605 on Raspberry 3B+
RF Link
AEON Labs ZW090 Z-Stick Gen5 EU
Update:
I have managed to get the wallswitches working. They now return the on/off signal to Domoticz after fysical operation!
In Hardware click Settings for open -Zwave, then click the Groups TAB.
In the Groups screen: (click refresh after each change!)
1CH wallswitch: remove and add again a 1 in group 1 (nr. 1 is the controller.)
3CH wallswitch: remove and add again a 1 in group 1. Strange enough the 1 is changed to 1.1 by the program, but it works.
remark: The 3-channel wallswitch is not available in the open Z-Wave database yet. You can get it working but some things are missing.
RF Link
Update:
