Cheap 433MHz door sensor (with open and close)
oasisnl
Re: Cheap 433MHz door sensor (with open and close)
these are dzvents scripts.
they should be placed in /path/to/domoticz/scripts/dzVents/scripts . Just activated the first contact and works great.
BarnaM7
I'm going to buy same of this sensor.
I have some mysensor nodes and sonoff switches with ESPurna firmware, but I'm not familiar with 433Mhz based sensors. I would like to buy an sonoff 433 bridge for the 433mhz door sensors and replace the firmware too.
I think this could be a good setup, am I right ? Or build a RFLINK gateway ?
Do you have any tip for 433Mhz based temp sensor?
thanks
Barna
thanks
Barna
marhar
Hello, I orderd a few at aliexpress.
When I add one in domoticz (v3.8153 on synology with RFXtrx44e) as mentioned in the movie I only get one device and not 2.
The device is added as a "x10 security" motion detector.
How can I get 2 devices so that I can see on or off ?
Can someone helpme out??
cheers Marc
cheers Marc
bjacobse
How long batterylifetime have you experienced?
marhar
I just got them so I don't know.
JelteV
Still running on the original battery.
sadly mine are not being detected by domoticz, might be a faulty one
weird... turned the magnet, now it worked for the open detection.
no closing device turned up in the list
nope.. no luck. not updating realtime. think i have a faulty product
plampix
Even simpler would be this generic solution (follow JelteV's instructions, just call the on/off devices $device/close and $device/open, and the main device $device). This will work for all your */close and */open devices!
active = true, -- set to false to disable this script
devices = {
'*/close',
'*/open'
-- in case of a timer event or security event, device == nil
if (device.changed) then
target, action = string.match(device.name, '(.+)/(.+)');
if (action == 'close') then
domoticz.devices(target).close();
elseif (action == 'open') then
domoticz.devices(target).open();
harolds
Super cool script! Working like a charm
lucdc
Great script plampix, thank you! The only inconvenience that I found is that, when you hide the on/off devices by starting their name with a "$" sign, the name of the main device will also have to start with a "$" sign, and will be hidden as well. I solved it by slightly modifying one line in your script: I changedplampix wrote: Wednesday 11 April 2018 21:02 Even simpler would be this generic solution (follow JelteV's instructions, just call the on/off devices $device/close and $device/open, and the main device $device). This will work for all your */close and */open devices!
target, action = string.match(device.name, '$?(.+)/(.+)');
cherowley
Thanks for the heads-up on these, modded them to monitor locked status on all my uPVC doors.
Surprisingly easy, just moved the reed switch to behind the dead bolt recess and glued a tiny magnet on the end of the dead bolt.
Simples! Now Alexa warns me when going out or to bed if any door is unlocked
Jubbes
Hallo, where must i write in the script the 2 names from the devices front door open/close (event) and the name from the virtual button front door?
cherowley
I used a lua script (setup/more options/events):Jubbes wrote: Tuesday 06 November 2018 4:36 Hallo, where must i write in the script the 2 names from the devices front door open/close (event) and the name from the virtual button front door?
if devicechanged["$Open3"] and devicechanged["$Open3"]=='On' then
commandArray['Front Door'] = "Off"
if devicechanged["$Close3"] and devicechanged["$Close3"]=='On' then
commandArray['Front Door'] = "On"
Dave21w
- Domoticz version: Stable
I have a couple of these :-
https://www.ebay.co.uk/itm/KERUI-D026-W ... 2394768280
That I am using on my doors, not quite as cheap but you see them as one X10 Security device, status is shown as Normal when closed and Alarm when open, I'm fairly new to Domoticz so not sure if the status could be changed to Open and Closed instead, either way they seem reliable, if used with the kerui alarm system they apparently report low battery too but not had mine long enough to see if thats the case with Domoticz too. Also if you don't like the blue writing on the side a little rubbing with isopropanol alcohol removes its so just plain white goes well with UPC.
Also the D026 model is the newer one, the previous D025 only report an open not a close so don't get that one.
Not tried the below yet but I assume they will work too.
https://www.ebay.co.uk/itm/KERUI-433Mh- ... 3457750875
Hope the info helps
P.S A search for Kerui D026 on amazon will get you some too
Hope the info helps
Those KERU D026 don't last a year with a battery. I'm guessing more like 8 months. I use 3 of them, indoors. Because they use the expensive A23 battery, I was hoping for better.
brjhaverkamp
I recently got a bunch of D026 as well.
I operate domoticz on a Rpi with an RFlink gateway attached. This is probably different than your Rfxcon setup.
in my case rflink detects 3 independent switches on the device.
Switch 00 emits off when the door opens
Switch 02 is the tamperswitch on the back and ends an On signal when pressed
Switch 03 emits on when the door closes
There is probably a signal for low battery, but I havent gotten that far.
My question now is, what does it exactly look like when using an Rfxcon? I would rather have one single device. Is this something that is should be done on the rflink/rfxcon side, or is that a config file for the device in domoticz itself?
I have a similar issue with the Keriu P829 PIRs. They show up as 1 switch where the motion is an off signal and the tamper the on signal. Very handy. I solved that for now with 2 dummy devices and some json magic.
But I now have 3 devices in domoticz for each physical one. I would like to clean that up a bit.
Bert
Bert
Joep123
With a RFXCom the D026 sensor shows up as just 1 device.brjhaverkamp wrote: Thursday 15 November 2018 21:01 My question now is, what does it exactly look like when using an Rfxcon? I would rather have one single device. Is this something that is should be done on the rflink/rfxcon side, or is that a config file for the device in domoticz itself?
brjhaverkamp
Hi Joep,
Can you give me a bit more detail? Does the device have 3 states then: Open/Close/Tamper/Low battery, or how does that work?
Could you share a screenshot maybe?
Dave21w
I'm at work at the moment but I'll see what I can sort out when I get home, can certainly do some screen shots.
Dave
Dave
Dave21w
Here's a few screen grabs of what my sensor reports as and its states, when I added it to my system all i did well tell domoticz to learn a new switch and then activated it by closing the door.
Hope it helps.
Hope it helps.
- back door closed devices table.jpg (8.21 KiB) Viewed 3497 times
- back door closed.jpg (10.08 KiB) Viewed 3497 times
- back door open.jpg (9.45 KiB) Viewed 3497 times
