Can't add temperature sensor
NibblyPig
Post by NibblyPig »
I have a few temperature sensors already that I added ageeeeeeees ago.
Today I have a new temperature sensor I want to add.
However I can't see any option to add it. I can press add light/switch under 'switches' but in the dropdown there is nothing that looks like 'temperature sensor'. Under 'temperature', there is no add button although I see my existing sensors.
What am I missing?
Droll
Domoticz version: 2024.7
Re: Can't add temperature sensor
Post by Droll »
What type of temperature sensor are you trying to add ?
Z-wave, Nexa, Orgon , ??
If you know it's suported, you can go to > Setup > Devices ... you might be lucky to find it there :-)
If so, just click on the green arrow and give it a name ..
Arne Kjetil
SweetPants
Post by SweetPants »
Given the small amount of information provided, did you enable Settings->Accept new Hardware?
NibblyPig
Post by NibblyPig »
Sorry, should have put more info.
I'm using an RFXCom Transceiver.
Not 100% sure what make this is, as it's an unbranded chinese one. I am hoping it will work as a rubicson as it seems many do, it's 433mhz so fingers crossed.
Don't you add temperature sensors in the same way as lights? Maybe that's why I am confused. I couldn't find anything on google explaining how to add it and I can't remember how I got the others to work (which were also unbranded generics).
Accept New Hardware is checked.
Edit: This is the badger http://www.rfxcom.com/oregon/en#alecto
SweetPants
Have you tried RFX-manager if this can 'see' the sensor? Normally a Temp sensor is automatically detected by the RFXcom if the right protocols are selected.
Droll
Post by Droll »
Go to > Setup > Devices ... IF it's supported it will probably pop up here...
Most of the RFXCom gizmos will just pop up on the device list, find it and ADD it to the used devices and it will pop up in the temperatur tab ...
Arne Kjetil
NibblyPig
Post by NibblyPig »
Ah, I see, thanks. It looks like this particular device isn't supported on my RFXCom433, only the RFXCom433E :(
