Weather underground rain not working
Argarath
- Domoticz version: 4.9700
Hi guys,
domoticz 4.9700 on RPI3 running.
I've got a problem with this blocky script, somehow the rain-sensor does not trigger anything. It's the rain-sensor from Weather Underground. Can somebody help me? Thanks in advance!
- regen_dom.jpg (43.15 KiB) Viewed 1666 times
Argarath
Re: Weather underground rain not working
Not much, but yesterday it did
SweetPants
If it's working again, can you close this one?
Argarath
Well, it is definitely not working. Somehow it seems that domoticz isn’t “grabbing” the data from Weather Underground properly.
- andreo
- Domoticz version: 2024.3
WU works fine for me, no problems here.Argarath wrote: Sunday 26 August 2018 22:20 Well, it is definitely not working. Somehow it seems that domoticz isn’t “grabbing” the data from Weather Underground properly.
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
SweetPants
Working fine here too, we had a few showers yesterday and they popped up in WU/Domoticz. Maybe you selected a station without rain?
Argarath
Unfortunately still not working. WU gives the amount of rain. But Blocky does not do anything.
The regen_switch (which is a dummy) does not switch.
SweetPants
Balkondeur is a real contact? Then it should be Open instead of On
vizion88
Try to first write a log entry when you expect rain is there, so only on the Regen > 1. Kind of debugging, then see what happens. Maybe as SweetPants suggested the problem lays somewhere else
