Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Sway06
Domoticz version: 4.9700
Post by Sway06 »
How can I find this wallplug in Domoticz when using Rfxtrx433E transceiver? I don't have any remote control and when I use the learn switch function and click on the plug button it just times out and does not recognize it. Thanks for your help!
b_weijenberg
Re: Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Post by b_weijenberg »
check with RFXmngr if you can pair it using Lighting2 - Anslut and try with a few different ID's
reset the module to remove all paired remotes.
RFX-433, RFX-433EMC, RFX-868
bjacobse
Post by bjacobse »
Why not purchase a new set from Jula, SEK 149 (might be easiest and fastest)
and then you get 2 wallplugs and a remote. then you can use the remote to program your Rfxtrx433 gateway
https://www.jula.se/catalog/el-och-bely ... re-408084/
Sway06
Post by Sway06 »
Thanks for your replies. I bought newer switches from Telldus that are smaller and worked like a charm.
