Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Sway06
- Domoticz version: 4.9700
How can I find this wallplug in Domoticz when using Rfxtrx433E transceiver? I don't have any remote control and when I use the learn switch function and click on the plug button it just times out and does not recognize it. Thanks for your help!
- Capture.PNG (228.71 KiB) Viewed 1450 times
b_weijenberg
- Target OS: -
Re: Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
check with RFXmngr if you can pair it using Lighting2 - Anslut and try with a few different ID's
reset the module to remove all paired remotes.
RFX-433, RFX-433EMC, RFX-868
bjacobse
Why not purchase a new set from Jula, SEK 149 (might be easiest and fastest)
and then you get 2 wallplugs and a remote. then you can use the remote to program your Rfxtrx433 gateway
https://www.jula.se/catalog/el-och-bely ... re-408084/
Sway06
Thanks for your replies. I bought newer switches from Telldus that are smaller and worked like a charm.
