What am I doing wrong here?
Melotron
Post by Melotron »
What am I doing wrong here ?
Im trying to get a night light script going.
We have a switch that we toggle when we go to sleep. Virt_SLEEP
So when this switch are on and there are motion in the kithchen or hallway so should the light go on and 35sec after no motion so should they go off.
But when Virt_SLEEP are off so will the script go on any way.
-- Night Light in Hallway and Kitchen --
    on = { devices = {'PIR*','Virt_SLEEP'} },
    execute = function(domoticz)
        if  domoticz.devices('Virt_SLEEP').state        == "On"      and
            domoticz.devices('PIR_Kök').state           == "Off"     and
            domoticz.devices('PIR_Hall').state          == "Off"     and
            domoticz.devices('Presence detection - Anyone').state    == "On"	  then
            domoticz.devices('Kök: Led MI').switchOff().afterSec(35)
	    domoticz.devices('Hall: Led MI').switchOff().afterSec(35)
	    print("Night Light Off")
            domoticz.devices('PIR_Kök').state           == "On"     or
            domoticz.devices('PIR_Hall').state          == "On"     and
            domoticz.devices('Kök: Led MI').dimTo(40)
	    domoticz.devices('Hall: Led MI').dimTo(40)
	    print("Night Light 40%")
Is it the or command when the turns on or what is it that I am doing wrong here ??
Regards Magnus Svensson
Re: What am I doing wrong here?
Melotron wrote: Thursday 16 August 2018 18:19 What am I doing wrong here ?
With the or command, the second if is very hard to understand.
To make it easier to understand my advice is to break it down in a couple of nested if's and add some extra print- or log statements while testing.
Melotron
Post by Melotron »
waaren wrote: Thursday 16 August 2018 19:13
That's what I've been doing.
The script are really simple now.
    on = { devices = { 'PIR*','23' } },
        if  domoticz.devices('23').state        == "On"     and
            domoticz.devices("PIR_Kök").state     == "On"     or
            domoticz.devices("PIR_Hall").state     == "On"     then
            print("TESTY")
I've changed the name to ID to make it simpler. But no luck.
Status: dzVents: Info: Handling events for: "PIR_Hall", value: "On"
Status: dzVents: Info: ------ Start internal script: dz testy: Device: "PIR_Hall (RFXCOM)", Index: 49
Status: dzVents: Error (2.4.7): There is no device with that name or id: 23
Status: dzVents: Error (2.4.7): An error occured when calling event handler dz testy
Status: dzVents: Error (2.4.7): .../domoticz/scripts/dzVents/generated_scripts/dz testy.lua:11: attempt to index a nil value
Status: dzVents: Info: ------ Finished dz testy
I'm lost at why this isn't working.
SweetPants
Post by SweetPants »
IDX is a number, not a string. Try:
on = { devices = { 'PIR*',23 } },
Melotron wrote: Thursday 16 August 2018 19:36
I was more thinking to debug / find the error in the logic like
        if  domoticz.devices(23).state        == "On" then
            print(domoticz.devices(23).name .. " state is: On")
            if domoticz.devices("PIR_Kök").state     == "On" then
                print("PIR_Kökstate is: On")
                if domoticz.devices("PIR_Hall").state     == "On" then
                    print("PIR_Hall is: On")
Melotron
Post by Melotron »
waaren wrote: Thursday 16 August 2018 20:17 I was more thinking to debug / find the error in the logic like
Didn't think of that :oops:
With that it is working as it should.
With 23 off :
Status: dzVents: Info: Handling events for: "PIR_Kök", value: "On"
Status: dzVents: Info: ------ Start internal script: dz testy: Device: "PIR_Kök (RFXCOM)", Index: 112
With 23 on:
Status: dzVents: Virt_SLEEP state is: On
Status: dzVents: PIR_Kök state is: On
Status: dzVents: PIR_Hall state is: On
The blocky version are working and its basically the same.
Melotron wrote: Thursday 16 August 2018 20:51 The blocky version are working and its basically the same.
Not quite... I see two or's in the blockly and only one in your first dzVents script
Melotron
Post by Melotron »
waaren wrote: Thursday 16 August 2018 21:17
Yes, the last PIR are removed from the dzvent script as I haven't set it up after we repainted the wall.
Going to do that this weekend.
Melotron
Post by Melotron »
It looks as its working. So this looks to be solved :)
No error logs and and the light turns on and off as I want to.
But are this the right way to do it, or are there any better way to handle this ??
It took a few days, but its working =)
Also are there any pros on building says 2 or 3 huge scripts ? Or should I keep them separated.
It feels little easier to keep them in one scrips when you are trying to get an overview, but also easier that everything stops working with one small error.
What are the recommendation on this as I am really green on programming lol
    -- Run enviromental scene LED -----
    -- Night Light for LED stripe -----
	-- Switch for when we are going to sleep.---------
	--  23 = Virt_SLEEP                             --
	--  78 = Virt_Morning                           --
	-- 645 = Presence detection - Anyone            --
	-- The id of the PIR and name of them.          --
	--  49 = Pir_Hallway                            --
	--  97 = Pir_Livingroom                         --
	-- 112 = Pir_Kitchen                            --
	-- The id of the Lamps and name of them. ---------
	-- 635 = Kitchen: Led MI                        --
	-- 636 = Hallway Led MI                         --
	-- Updated 2018-08-20                           --
	on = { devices = { 49, 97, 112, 23 } },
	     if domoticz.devices(645).state         == "On"     and
            domoticz.devices(23).state    == "On"    and
            domoticz.devices(78).state    == "Off"    then
            if    domoticz.devices(49).state           == "On"     or
                  domoticz.devices(97).state          == "On"     or
                  domoticz.devices(112).state     == "On" then
				  domoticz.devices(635).dimTo(50)
			          domoticz.devices(636).dimTo(50)
			          print("Motion is: On Turning on Night Light")
            if    domoticz.devices(49).state           == "Off"     and
                  domoticz.devices(97).state          == "Off"     and
                  domoticz.devices(112).state     == "Off" then
		              domoticz.devices(635).switchOff().afterSec(35)
			      domoticz.devices(636).switchOff().afterSec(35)
			      print("Motion is: Off: Turning off Night Light")
//Magnus Svensson
felix63
Domoticz version: 2020.1
Post by felix63 »
Hi Magnus,
Definitely small separate scripts. Much easier to maintain and as you said one error doesn't mess up too much. I currently have 30 -40 scripts active. I do try to maintain a clear naming convention (Status xxx, Switch xxx, Movement xxx etc) and use some system in assigning different log-labels to each script. This facilitates debugging. And I add a lot of comments. Because some times I write very clever stuff only to find that 6 months down the line I can't work out anymore how it's supposed to work...
Melotron
Post by Melotron »
Thanks.
Ive started to split up the scripts in rooms and then what they should do. Only keeping one for the day, dusk and dark environment and night light.
But the rest are getting separated.
Its more note keeping to have a couple of scripts then just a few long.
I had to add notes on one of my longer script on where I was in the script and what the parts abow should do.
But I guess it's a good learning experience.
The script are still in Domoticz but once they are in a almost a final version so will I start to move them in to the system.
//Magnus Svensson
