hi i want to trie to set off some lights together with my tv
this between times
i tried a couple of ways i tought this could work but nothing seems to
anyone know how to do this?
turn off lights together with tv
- Egregius
- Domoticz version: v2024.7
Re: turn off lights together with tv
How can it be before 18 and after 19 at the same time?
jessy1984
Thats cous i was messing around with it . Tried it the other way around also
CyberE
- Domoticz version: 2020.2
I'm just guessing here, as I'm no expert but you might want to try the following:
To clarify, use seperate sets for every different lamp.
Also make sure to set the blocky to "devices".
if TV kijken = off and time > 1800 and time < 19:00
Do
set Staande lamp = off
set kast living color = off
jessy1984
just tried it again like you said but lights do not react
when turning off the tv
status of tv dous change to off and time is set correct
- Egregius
Begin small, if tv is off switch light off. Then add one time condition and then add the second.
That way you'll learn better what happens.
jessy1984
thank you it workes i had the wrong control block
