Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
- Domoticz version: 2020beta
Re: Domoboard - General Discussions
Its running as a service on the same raspberry pi as Domoticz.
What is the command to test the python import?
- Domoticz version: 3.5837
i think that its installed in an env that way. in that case you need to install geocoder also in the env.
it should work with this code:
/home/<user>/domoboard/bin/pip install geocoder
where <user> is you're pi user (possibly "pi")
it doesn't crash anymore, but underground is empty.
I've already figured it out, you can only choose English.
A new question.
Installed the iCloud plugin.
Now when I open the dashboard I got on my iPhone and Mac that a new device want to have access to iCloud.
Of course this correct, but I can't type the verification code at any place.
Is there a solution for this?
thats a good question, i don't use the 2 factor authentication so i wont get that message but my colleague does so i will ask it for you.
First of all, i'm really suprised there is so less activity in this sub forum. Domoboard looks really cool!
I've got a question about light control. I can add my light IDX to domoboard, but it shows up with a RGB selector.
The lights that I want to control (Milight FUT103) are RGBWW/CCT. I don't have an option in domoboard to use a RGBWW selector, so I can control Kelvin/White.
Does someone knows how to implement a RGBWW selector?
Hi there,
Thank you for the kind words and my apologies for the low activity. (having an baby and building an house are some things that are on the priority list otherwise the misses will get angry
I think that that function isn't fully supported in domoboard. With the new release of domoticz we will try to get back on strack a.s.a.p because they did also made some changes to the selector switches.
Greetings, Squandor
Greetings, Squandor
You're totally right! No need to apologysquandor wrote: ↑Tuesday 03 July 2018 12:39 Hi there,
Thank you for the kind words and my apologies for the low activity. (having an baby and building an house are some things that are on the priority list otherwise the misses will get angry)
Greetings, Squandor
Wish you all the best with your house and family.
In the config file you can specify different users as configured in domoticz.
Also the login page of the domoboard server works accordingly.
however, there don't seem to be a way to have custom pages/layout per user.
In domoticz you can designate specific devices to a user so only these devices show up when logged in as that user.
It would even be better that you could use the config file to make specific configurations per user.
This way you could have an admin account and a 'kids' account look completely different.
maybe this is already possible but I don't know how to configure this.
Please help
Please help
I am getting a keyerror on the ANWB plugin?
Anyone else still using this?
- DewGew
- Domoticz version: V4.10618
Anyone still using domoboard?
- Domoticz version: 2024.7
i used to use it, but some time ago it got lost (needed the raspberry were it was running on for other stuff)
however , recently wanted to reintroduce domoboard but can't install it anymores due to dependencies :/
also tried to install in a docker container but that failed too
does anyone has a working environment?
