Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
florisi
Domoticz version: 2020beta
Re: Domoboard - General Discussions
Post by florisi »
Its running as a service on the same raspberry pi as Domoticz.
What is the command to test the python import?
squandor
Domoticz version: 3.5837
Post by squandor »
florisi wrote: Tuesday 10 April 2018 13:14 Its running as a service on the same raspberry pi as Domoticz.
i think that its installed in an env that way. in that case you need to install geocoder also in the env.
it should work with this code:
/home/<user>/domoboard/bin/pip install geocoder
where <user> is you're pi user (possibly "pi")
florisi
Post by florisi »
it doesn't crash anymore, but underground is empty.
squandor
Post by squandor »
florisi wrote: Tuesday 10 April 2018 15:09 it doesn't crash anymore, but underground is empty.
i think that thats an configuration issue. How is you're wunderground config?
florisi
Post by florisi »
I've already figured it out, you can only choose English.
florisi
Post by florisi »
A new question.
Installed the iCloud plugin.
Now when I open the dashboard I got on my iPhone and Mac that a new device want to have access to iCloud.
Of course this correct, but I can't type the verification code at any place.
Is there a solution for this?
squandor
Post by squandor »
thats a good question, i don't use the 2 factor authentication so i wont get that message but my colleague does so i will ask it for you.
nvb9
Post by nvb9 »
First of all, i'm really suprised there is so less activity in this sub forum. Domoboard looks really cool!
I've got a question about light control. I can add my light IDX to domoboard, but it shows up with a RGB selector.
The lights that I want to control (Milight FUT103) are RGBWW/CCT. I don't have an option in domoboard to use a RGBWW selector, so I can control Kelvin/White.
Does someone knows how to implement a RGBWW selector?
squandor
Post by squandor »
Hi there,
Thank you for the kind words and my apologies for the low activity. (having an baby and building an house are some things that are on the priority list otherwise the misses will get angry ;) )
I think that that function isn't fully supported in domoboard. With the new release of domoticz we will try to get back on strack a.s.a.p because they did also made some changes to the selector switches.
Greetings, Squandor
nvb9
Post by nvb9 »
squandor wrote: Tuesday 03 July 2018 12:39 Hi there,
Greetings, Squandor
You're totally right! No need to apology :) Thank you for your answer and I'm looking forward to the next update.
Wish you all the best with your house and family.
philleaerts
Post by philleaerts »
In the config file you can specify different users as configured in domoticz.
Also the login page of the domoboard server works accordingly.
however, there don't seem to be a way to have custom pages/layout per user.
In domoticz you can designate specific devices to a user so only these devices show up when logged in as that user.
It would even be better that you could use the config file to make specific configurations per user.
This way you could have an admin account and a 'kids' account look completely different.
maybe this is already possible but I don't know how to configure this. :?
Please help
patricknooijen
Post by patricknooijen »
I am getting a keyerror on the ANWB plugin?
Anyone else still using this?
DewGew
Domoticz version: V4.10618
Post by DewGew »
Anyone still using domoboard?
haeewee
Domoticz version: 2024.7
Post by haeewee »
i used to use it, but some time ago it got lost (needed the raspberry were it was running on for other stuff)
however , recently wanted to reintroduce domoboard but can't install it anymores due to dependencies :/
also tried to install in a docker container but that failed too
does anyone has a working environment?
