Error getting http data!
pa0esh
Domoticz version: 4.10701
Post by pa0esh »
Hi There,
I'm new to Domoticz, but have managed so far to transform a couple of Sonoff decvices to tasmota and get them up and working in Domoticz. Same with my cpu data.
But whatever i do with a virtual weather (Darksky and or OpenWeather), i always end up with these messages
2018-07-16 12:45:35.477 Error: OpenWeatherMap: Error getting http data!
2018-07-16 12:46:41.008 Error: DarkSky: Error getting http data!.
2018-07-16 12:49:40.693 Status: New sensors allowed for 5 minutes...
2018-07-16 12:50:07.494 Status: OpenWeatherMap: Worker stopped...
2018-07-16 12:50:07.494 Status: OpenWeatherMap: Started
2018-07-16 12:50:11.383 Status: New sensors allowed for 5 minutes...
2018-07-16 12:50:12.520 Error: OpenWeatherMap: Error getting http data!
2018-07-16 12:51:41.866 Error: DarkSky: Error getting http data!.
I run domoticz on an ubuntu server 18.04 and Domoticz itsself is
Version: 4.9785
Build Hash: 7bd0f5f4
Compile Date: 2018-07-15 16:41:39
dzVents Version: 2.4.7
Python Version: 3.5.2 (default, Nov 23 2017, 16:37:01) [GCC 5.4.0 20160609]
De linux machine is behind a router at my home with port forwarding for 8080 and 1883 (MQTT)
Anyone who can point me into the right direction ?
Both the api calls with Darksky and Openweather work when done to a browser...
Erik
Gianni
Re: Error getting http data!
Post by Gianni »
i fix this problem just by entering my location egg Kortrijk and not my gps cordinates.
pa0esh
Post by pa0esh »
Will try tomorrow
alacran
Domoticz version: 4.10717
Post by alacran »
Hey
Did you got the solution?
I have the same issue...And do not know how to fix it...
Thank you
domotica22
Post by domotica22 »
I read, and solved the same issue by deleting the hardware, and re-adding this. Also don't use the coordinates, but the actual place like "Utrecht, NL", without the quotes of course.
This solved the issue at once.
Hope it helps!
Users browsing this forum: lost and 1 guest
