Error getting http data!
pa0esh
Domoticz version: 4.10701
Post by pa0esh »
Hi There,
I'm new to Domoticz, but have managed so far to transform a couple of Sonoff decvices to tasmota and get them up and working in Domoticz. Same with my cpu data.
But whatever i do with a virtual weather (Darksky and or OpenWeather), i always end up with these messages
2018-07-16 12:45:35.477 Error: OpenWeatherMap: Error getting http data!
2018-07-16 12:46:41.008 Error: DarkSky: Error getting http data!.
2018-07-16 12:49:40.693 Status: New sensors allowed for 5 minutes...
2018-07-16 12:50:07.494 Status: OpenWeatherMap: Worker stopped...
2018-07-16 12:50:07.494 Status: OpenWeatherMap: Started
2018-07-16 12:50:11.383 Status: New sensors allowed for 5 minutes...
2018-07-16 12:50:12.520 Error: OpenWeatherMap: Error getting http data!
2018-07-16 12:51:41.866 Error: DarkSky: Error getting http data!.
I run domoticz on an ubuntu server 18.04 and Domoticz itsself is
Version: 4.9785
Build Hash: 7bd0f5f4
Compile Date: 2018-07-15 16:41:39
dzVents Version: 2.4.7
Python Version: 3.5.2 (default, Nov 23 2017, 16:37:01) [GCC 5.4.0 20160609]
De linux machine is behind a router at my home with port forwarding for 8080 and 1883 (MQTT)
Anyone who can point me into the right direction ?
Both the api calls with Darksky and Openweather work when done to a browser...
Erik
Gianni
Re: Error getting http data!
Post by Gianni »
i fix this problem just by entering my location egg Kortrijk and not my gps cordinates.
pa0esh
Post by pa0esh »
Will try tomorrow
alacran
Domoticz version: 4.10717
Post by alacran »
Hey
Did you got the solution?
I have the same issue...And do not know how to fix it...
Thank you
domotica22
Post by domotica22 »
I read, and solved the same issue by deleting the hardware, and re-adding this. Also don't use the coordinates, but the actual place like "Utrecht, NL", without the quotes of course.
This solved the issue at once.
Hope it helps!
