Google Home voice control for Domoticz: the easy way!
Alexa, Google Home and Siri
irab
Target OS: OS X
Post by irab »
If you would like to control Domoticz devices (like Milight) with Google Home voice control here is an easy implementation:
- Assumption is that Domoticz is running on an RPi + RFXcom
- Purchase an ICS-2000 (Trust/Klikaanklikuit = Kaku), it will link the Google Home to Domoticz. Dutch website here : https://www.klikaanklikuit.nl/nl/ics-20 ... ation.html
- Link your Google Home to the ICS-2000 using the Google Home App.
- Setup Domoticz “scenes” to control your devices, set the activation devices for these scenes as Kaku compliant RF commands.
-Generate Kaku rf codes with the ICS-2000. Use these to activate scenes in Domoticz. You do not need any Kaku remotes or switches (It is not required to define a switch in Domoticz)
The communication path is now as follows:
(Voice —->(air)—-> Google Home —->(cloud)—-> ICS-2000 —->(rf 433)—-> RFXcom+RPi —-> Milight, Kaku switches, etc.)
That’s all. Now your Google Home can control the ICS-2000 which commands your Domoticz system.
Summarised: "Google Home plus ICS-2000" == "Voice controlled RF remote for Domoticz"
Works like a charm!
gerardwr
Re: Google Home voice control for Domoticz: the easy way!
Post by gerardwr »
Excellent use of standard equipment in a creative way. Well done!
Madgeni
Post by Madgeni »
Did you look at Controlicz? Or was it a security issue? I would, humbly, suggest that Controlicz is the easiest way, and doesn't require any additional hardware costs
irab
Target OS: OS X
Post by irab »
Madgeni wrote: Tuesday 24 April 2018 16:31 Did you look at Controlicz? Or was it a security issue? I would, humbly, suggest that Controlicz is the easiest way, and doesn't require any additional hardware costs
Yes. I have installed Controlicz. But encountered some issues.
Could you PM me. (I’m still not authorised to do so myself)
Madgeni
Post by Madgeni »
you can email me from your Controlicz profile
irab
Target OS: OS X
Post by irab »
Madgeni wrote: Wednesday 25 April 2018 20:00 you can email me from your Controlicz profile
Hi Madgeni,
Issues have been solved. Controlicz is now fully operational.
Congratulations with your new website. It is a great improvement.
Thank you!
metttiu
Post by metttiu »
I've sent you my email
ayasystems
Post by ayasystems »
You can use ifttt and webhook
It is very simple. Try it!
You can call to domoticz API from webhook
Stief
Post by Stief »
irab wrote:If you would like to control Domoticz devices (like Milight) with Google Home voice control here is an easy implementation:
Works like a charm!
@irab
I know It's an old topic but how did you generate de kaku rf codes?
irab
Target OS: OS X
Post by irab »
@ stief
In Domoticz
Add Manual light/switch device
Hardware: RF Tranceiver
Switch type: on/off
Type AC
Use any code
Then learn this rf code into the ics2000
Stief
Post by Stief »
Thanx for your awnser.
In de meen time I had solved this by creating a group (to switch the device in Domotics) and added a device, wich I created on de ICS-2000 at that moment.
Yout solution seems cleaner though.
AndrevdBerg
Domoticz version: 4.384
Post by AndrevdBerg »
I like the idea but have a question on one of the steps:
How do you do this exactly in the ICS-2000 app? :?:
I wasn't able to find anything to find something like this anywhere in the ICS-2000 :shock:
in The communication path I think you forgot to mention Domoticz scene triggered by RF433 and sending commands to switches in the group: :roll:
(Voice —->(air)—-> Google Home —->(cloud)—-> ICS-2000 —->(rf 433)—-> RFXcom+RPi —-> Domoticz Scene --> (rf433) --> Milight, Kaku switches, etc.) :mrgreen:
André
NishaChavan
Post by NishaChavan »
Great Information was very useful form...
