I don't know why it doesn't work
- Domoticz version: V4.9700
Who could explain to me why it does not seem to work. Here is my script:
timer = { 'every minute' }
execute = function(domoticz, timer)
if (device'Fin_chauffage'.state == 'On')
then
device'prise ordi'.switchOff()
device'prise TV Chambre'.switchOff()
domoticz.notify('Hey pas mal')
device'prise TV Chambre'.switchOn()
device'prise ordi'.switchOn()
Thanks for your help
Pascal
then
Pascal
- waaren
Re: I don't know why it doesn't work
You missed a couple of () in your code. Do you see anything in the domoticz logfile ?
Please use code tags around your code to improve readability on the forum.
on = { timer = { 'every minute'} },
logging = { level = domoticz.LOG_ERROR,
marker = "chauffage actions" },
if (device('Fin_chauffage').state == 'On') then
device('prise ordi').switchOff()
device('prise TV Chambre').switchOff()
device('prise TV Chambre').switchOn()
device('prise ordi').switchOn()
No I don't see anything in logfile. even with yours. Amazing
- waaren
Did you enable logging in your /etc/init.d/domoticz.sh ?
by removing the # on the line
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
I just did, but nothing happens. Probably something I did not do properly, but I don't know what.
Here is the error I have:
2018-07-18 21:10:56.190 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call global 'device' (a nil value)
- waaren
We are getting somewhere now. Please try this modified script.
execute = function(domoticz, trigger)
if (domoticz.devices('Fin_chauffage').state == 'On') then
domoticz.devices('prise ordi').switchOff()
domoticz.devices('prise TV Chambre').switchOff()
domoticz.devices('prise TV Chambre').switchOn()
domoticz.devices('prise ordi').switchOn()
here it is:
2018-07-18 21:39:00.664 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call local 'device' (a table value)
- waaren
My mistake. I edited the previous post
any clue?
- waaren
Did you try the edited version ?
the logic in your script causes dzVents to send you a notifications every minute for as long as "Fin_chauffage" state is On. It will also switch the other devices with a delay varying from 1 - 60 seconds. If you want to change the script in such a way that it triggers direct and only when the state of "Fin_chauffage" changes; modify it to:
on = { devices = { 'Fin_chauffage'} },
marker = 'chauffage actions' },
if trigger.state == 'On' then
execute = function(domoticz, trigger) and execute = function(domoticz, Device)?
Thanks again.
Pascal
Please check the wiki:pascal wrote:Thanks a lot Waaren. It is working exactly how I wanted. What is the difference between:
Thanks again.
Pascal![]()
https://www.domoticz.com/wiki/DzVents:_ ... gerInfo.29
There they use the word 'item'. It is your choice what word to use. In your script you didn't make use of the'trigger word', so you can skip it as well:
execute = function(domoticz)
- waaren
@Jake, in the example based on the device state change trigger is used so better to leave it like it is.jake wrote: ↑Thursday 19 July 2018 14:18Please check the wiki:pascal wrote:What is the difference between:
@pascal, the the second parm in the function(domoticz,Device) (or function(domoticz,trigger) ) is the object that is triggering the script.
It can be a device, variable, scene, group, timer, security or httpResponse depending on what you defined in the on = (....) section.
@waaren, I based my comment on the initial scripts. Now I see in your suggested improved script (which I think is much better in this situation) that you used the 'trigger' in your script as intended.
